Question about Thermador SGS36GS Gas Cooktop
I have a Thermador SGC365RW cooktop which is around 10 years old. Lately when I turn it on, the starter begins to click but it doesn´t light the burner. After a few seconds (up to a minute later) the burner lights but since there is accumulation of gas it creates a small explosion. I am wondering what parts I should change to relieve the problem.
mikedurland
  • 481 Answers
SOURCE: Electric coils for old Thermador cooktop Model #TMH45
i just checked repairclinic.com and they seem to have a lot of parts for Thermador. you just need your model number. if the burners look anything like this, then you might be able to buy aftermarket burners a lot cheaper at lowes or home depot. thermadore parts are very expensive.38e8186.jpg
Posted on Jul 20, 2008
SOURCE: Cleaning Thermador Cooktop?
To clean the stainless around the star burners try applying Easy-Off oven cleaner around the stars with a Q-tip (spray the cleaner onto the stainless surface first because it's very hard to control the spray output). The cleaner will make your stainless sparkle and the Q-tips allow you to get close enough while controlling the application. Scrub gently with the Q-tip and the stains will disappear within minutes. Wash thoroughly with a wet cloth. I've used this on my older model Thermador stainless cooktop for 5 years.
Posted on Jan 25, 2009
  • 408 Answers
SOURCE: Thermador gas cooktop explosion
I would say that pop was one of you igniters.  either that or the stove is not installed correctly and when it gets warm, thermal expansion makes the metal pop.  I would say that I would use caution and discontinue its use.  Most problems with these need to fixed professionally.
Posted on Mar 04, 2009
  • 10865 Answers
SOURCE: natural gas to lp conversion kit for a Thermador GGNCV30 cooktop
Your LP gas provider will get the orifices for you just call them with the model number of your thermador. They have gotten them for me many times.
Posted on May 07, 2009
  • 69 Answers
SOURCE: Thermador cooktop won't light it has the ignite
try to clean a little bit the head of the sparkler and push the button for gas a little bit longer
Posted on Mar 11, 2010
I have a Wolf gourmet 30" stove. it's about 10
Interesting, I'm looking for a solution to a similar issue. Our new (7 month old) 30'' Wolf Range has this issue. When both front burners are light, the back burner's electronic starter begins to click, but only when you put a pan on the front left burner. I believe the iron/steel in the pan is causing a magnetic field thats starting the rear burner to go off.. just don't know.. will report back after the repair person comes.
Jan 22, 2011 | Wolf Range 18 in. SPR-100 Gas Cooktop
Gas burners won't light
Make sure the little tiny flash holes are open. They allow a little bit of gas to seep out so the igniter can light the burner. If you can light the burners with a match, check those holes.
If yours are the "sealed" type burners, make sure they are not a half a turn out (180° around)
Jan 10, 2010 | GE Cooktops
Trying to remove stains around the gas unit where temp is the hottest.
have you tried cooktop cleaner? this seams to work pretty good at getting stains out of stainless steal. (You know...cooktop cleaner is really just car wax if you had some try this on a little area and see how it works and if you like the results...there you go.) let me know what you think. But like i said always do a test point before doing the whole surface.
Apr 22, 2009 | Thermador 37 in. SGSX365 Gas Cooktop
Mar 04, 2009 | Thermador PC36 36 in. Gas Cooktop
Obsolete Thermador
Hi Iniro
It is true that thermador has permanently discontinued some of its models - alternative supplier have not beeen identified
Regards
Sep 09, 2008 | Thermador SGS36GS Gas Cooktop
Thermador Vent Gas Cooktop Model GGCV36 Serial # 89020071
Just google the repair clinic and partselect,they are selling spare parts online..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Thermador SGS36GS Gas Cooktop
Range wont light
Hi
It sounds to me like a switch problem.
You should check the Gas Valve that correspond to that switch, and also check the Manifolds, there should be one manifold for each set of gas valve switches.
Hope this help.
Eddie Rentas
Tupper Lake NY
Jun 21, 2008 | Thermador PSC364GDZS Gas Cooktop
Mar 20, 2008 | Thermador PSC364GDZS Gas Cooktop
Obsolete Thermador
I am looking for Thermador part # 414-564 and Bosch part # AP2831995. Anyone ???
Sep 09, 2007 | Thermador 37 in. SGSX365 Gas Cooktop
Thermador SGCS456R 36' gas cooktop
Take apart the cooktop and it is the potentior on the valve for the simmer burner that is usually the issue.
Aug 15, 2007 | Thermador 37 in. SGSX365 Gas Cooktop
Thermador SGS36GS Gas Cooktop Logo
81 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
