Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Thin twin tub inside is tilted as if a spring let go
  • 1 more comment
  • MIKE major May 28, 2008
    TUB IS TILTED LIKE SOMETHING LET GO?THANKS-MIKE
  • ladydidan Jan 10, 2009
    How do you get the front panel off?
  • Archie Ferrarini
    Archie Ferrarini May 11, 2010
    washer or dryer
  • 868 Answers
On this  problem one of 2  the Shocks have pulled a part (seperated),possibly even broke off.After removing the front panel ,you'll see that on each side towards the rear of machine you have a shock ( similar to a car) arm starting from the base and angling upward where it meets the tup.Look for the seperation there and then let me know and I'll be happy to guide you through this.
Posted on May 28, 2008
I need to know how to remove brass claps to top of whirlpool thin twin washer to get to switch pls
do not remove them just push a thin putty knife in and release the top from them then tilt the top back .to access the switch
Mar 09, 2015 | Whirlpool Washing Machines
Admiral model lnc6762b71 tub dosen't center itself
Check balance springs at the bottom of the tub/drum. To gain access and remove front panel insert a knife or thin blade approx. 4" in the from each side in between the front seam on the front panel, this will release the lid clips, lift and hinge back the lid panel, remove the two screws securing the front panel and remove, there are 6-8 springs at the bottom, check all are intact.
Also check drum is rotating at full speed, if not check and replace drive belt below the machine, tilt machine back to gain access, flip belt off the pulleys and replace same way.
Nov 30, 2013 | Admiral Washing Machines
Thin twin tub loose
you will need to remove the front panel of the washer,there are 3 spring suspension rods below the tub and either one or more of these springs are disconnected from the tub or broken
Dec 07, 2012 | Whirlpool LTE6234D Top Load Stacked...
Drum inside washing machine seems to come loose..making a really loud banging noise. Whats the best way to fix this.. Whirlpool Thin Twin
Might be a spring or the skate plate out of alignment.
Thin twin service manual is in this apartment series service manual:
http://docs.google.com/fileview?id=0B5If-wTgYWH5ZDgzODI5MjYtMWNmYS00MWZkLTk0ODEtNjM3MTIyYzVmZWVl&hl=en
Sep 18, 2011 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Outside seams to be level but tub tilts during
Front loader?..Could be broken drum spring up top..
Oct 03, 2009 | Washing Machines
I have the sameproblem
this is a snubber problem your tub in held straight by 3 springs they go from the washer frame to the bottom of the tub one spring is unhooked; bet it was held by the screw
Sep 07, 2009 | Whirlpool LTE6234D Top Load Stacked...
The barrell has come loose on my thin twin stackable washer/dryer
The struts, shocks, springs...they are called different things depending on who you speak to. Apparently on the heavy duty thin twin stackable units they are all bad and last for about 13 months just after the manufacturers warranty, this is common knowledge among Whirlpool technicians and even the replacement parts that are being installed are not performing for the lifetime they were designed. I have contacted a repair service and they are scheduled for the middle of next week and over the phone he ballparked the estimate at about $300.00.
May 15, 2009 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool twin thin
You need to check the suspension of the washer, it could be pads, suspension springs, or even the shocks.
Jul 12, 2008 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool Washer LSN3000PW4
tub is suspended from spring mounts
springs stretch over time tub sags
remove top cover
locate spring mounts and adjust tensioning bolts tighter on sagging side
Jul 11, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
122 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
