Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
Says low wont light - Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
    President:
  • Hayward Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Lo means low system flow. You usually need to clean you filter system and skimmer basket(s) to get the error to clear and the heater to operate. If it still wont run it means the pressure switch has failed and needs to be replaced.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Sep 05, 2010
2004 ford taurus low oil light. put oil in and car wont start
Well was it low on oil? Was this a low level light or a low oil pressure light, it has both.
May 10, 2017 | Ford Taurus Cars & Trucks
Both my low beam and high beam wont work. And my headlights wont go down even when lights are turned off and the button is unpressed on the inside.
check the headlight relays ,
Check for possible faulty light stalk switch also. Dash lights may fail with this possible cause.
Check fuses
Jan 25, 2016 | 1992 Mazda MX-5
Transmissiom wont shift low range light on
HI;
I pressed low range button and the light still on and gear change very fast o only to 3 gear wont go 4th gear how i can fix it please helpme
Nov 10, 2012 | Cars & Trucks
Message center wont stop saying low oil presure how do i reset it and it also say low coolant
REPLACE THE OIL LEVEL SENSOR WITH A GM REPLACEMENT I HAD THE SAME PROB
Mar 17, 2012 | 2001 Oldsmobile Aurora
Car wont start
sounded like the altinator, when you replaced it did you plug it in and check it.. Thanks wired good luck
Oct 03, 2009 | 1988 Chevrolet Camaro
Wont shift out of 4wd low
it sounds like the motor on transfer case is bad .
Apr 17, 2009 | Chevrolet Tahoe Cars & Trucks
My transmission wont shift out of low gear and my power steering light stays on
just remove whatever you did to cause the problem... it probably messed with the electrical system and is interfering with the other things
May 31, 2008 | 2007 Chevrolet Cobalt Coupe
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
