Question about Dryers
I have amana gas dryer. wife said it wasnt drying & not shutting off.. checked out unit. saw unit light but lazy flame. pulled apart & cleaned. was ok when i checked it but she said it wasnt working again. thought it was timer by unit not shutting off. replaced timer still same problom. do i have bad timer?
  • Dryers Master
  • 8,220 Answers
These coils get weak and die. More here
Posted on Sep 01, 2010
  • Dan Webster
    Dan Webster Sep 01, 2010
    Page 13 of the manual in the link I posted above gives ohms readings on the coils . Take these measurements when the coils are hot to confirm my suspicions or simply buy another set they are cheap enough.
  • Dan Webster
    On line today 279834 coils set
Amana propane dryer ignitor works, gas starts then flame shuts off in 5 secs
hay bob , get your vent cleaned out ,there's not enough oxygen for the flame to stay on.good luck APPLIANCES R EN
Mar 03, 2013 | Amana Dryers
Dryer is not heating enough to dry the clothes. It is 9 years old, is it better to just invest in a new dryer?
After 9 years you are going to need to replace some parts. If the ignitor works and the flame sensor is shutting down the gas but the flame stops after a while or not at all then them cols need to be replaced. themobilian_2331.jpgthemobilian_2332.jpgthemobilian_2333.jpg
Amana Dryer Service Manual Gas and electric models (printable)
May 09, 2011 | Amana ALG230RAW Gas Dryer
Amana NDG2335AW Gas Dryer runs but doesn't heat
Check the spark ignitor when firtst starting the dryer up. It should click within the first 15 seconds to light the pilot up
May 31, 2010 | Amana NDG2335AW Gas Dryer
The gas dryer is not getting hot enough to dry clothes have to run it double the time to get clothes dry-exhaust not blocked-igniter is working-there is a flame-checked dryer heat setting manual knob with...
You might want to replace the thermacouplar. Sometimes when they are going out , all will appear to be alright but as you stated it takes a long time for the flame to come back on. This sounds to me like the thermacouplar is going out.
Dec 08, 2009 | Amana ALG331RAW Gas Dryer
I have a estate whirlpool mod # TGDX640PQ0 and the dryer runs and there is no heat. i took it apart and i saw that there is no flame or what you would call it. but everything lese works just fine. what...
you have several things to look at, 1 - is the vent abstructed or pluged up with lint? 2- is there gas to the unit and is the valve turned to the on position? 3- is there spark when you turn the unit on and if the dryer isnt shutting off then you may have a problem with the timer or comp. board
Aug 23, 2009 | Whirlpool GGQ8831L Gas Dryer
Amana Dryer LG8409W2 - The dryer heats for a few seconds then runs cold. The dryer has been cleaned as well as the vent and still no heat.
karenl46 -- Flame sensor has to "see" proper flame in order for gas burner to stay on. Safety solenoid engages (shuts off gas) when flame light not detected. Check window on sensor (1:30 CW position) on burner tube. If you still have problem after cleaning it, then refer to URL below. -- SWT
http://forum.doityourself.com/kitchen-laundry-home-gas-appliances/350993-another-gas-dryer-no-heat-failure-rates.html
Aug 18, 2008 | Amana Dryers
Dryer heating problem
It sounds like an air flow issue. There is a flame sensor on the side of the flame housing. If the venting is not sucking the flame down the tube it will cycle very quickly and never reach the right temp.
Jul 04, 2008 | Amana ALG331RAW Gas Dryer
CUTS OFF BEFORE IT FINISHS DRYing cloths
Check your venting, this could be causing the thermostats to pop and shut down the flame. The complete venting line.
Sgt 48
Jun 05, 2008 | Amana ALG443RAW Gas Dryer
Gas Dryer won't stay hot
There is a thermoelectric eye that says it is OK to keep the gas burner on. If this sensor is defective or blocked from "seeing" the gas flame is properly lit, it will turn off the gas flow (safety) override solenoid. With the unit unplugged make sure that the optical path on the upper right (1:30 CW position) flame tube inside sensor window is clean. The rattle you hear is probably the safety gas shut-off solenoid engaging. If you need more help, please ask -- SWT
May 03, 2008 | Dryers
Amana DLG330RAW gas dryer.
try cleaning or replacing the flame sensor ( optical unit mounted on the side of the burner tube. voltage flows though that optical eye that proves flame.
Mar 29, 2008 | Amana DLG330RAW Gas Dryer
Dryers Logo
51 people viewed this question
Top Dryers Experts
