Question about Rockford Fosgate Power 350S Car Audio Amplifier
I have a rockford fosgate amp , Power 350s, model # 3040801100-01. the main fuse in the power wire to the amp blew, and now it doesn't work at all (with a new fuse of course) and i asked Geek Squad at Best Buy and they told me there is another fuse on the amp itself but i can't seem to find one any where on the amp. I have takin the amp caseing of and still have no idea were it could be. Your help will greatly appreciated
SOURCE: Rockford Fosgate Amp Repair Guild
I would love to get a copy of that repair guide you made. Could you please
Posted on Sep 02, 2007
etirbynnor
  • 655 Answers
SOURCE: Rockford fosgate 800 a2 amp power?
Hello desperate2le,
Watts delivered is a function of the voltage times the current. If the amp was 100 percent efficient, it would need 33 amps at 12V for 400 watts. At 14.4V, it would only need 28 amps. Of course, amplifiers are NOT 100 percent efficient, only about 50-60 percent in many cases, but somewhat higher for monoblocks, maybe 80-90 percent. So you're looking at a fuse in the 60-80A range. In the absense of a specific fuse size from the manufacturer, I'd start the primary fuse at a 60A and if the amp blows it on power up/immediately/frequently, move up to an 80A.
All of the Rockford-Fosgate 2-channel bridgeables I've ever seen show using the left positive (+) and the right negative (-) for bridging. But if it's not shown right on the amp, I'd call or email RF for the correct connection. The new amps do show it.
Hope this helps.
Posted on Apr 28, 2009
  • 182 Answers
SOURCE: Rockford Fosgate Punch 800 A2 shorting out.
replace the inputs on ur amp
Posted on Jun 29, 2009
  • 3 Answers
SOURCE: rockford fosgate 450.4. 1st protect mode, now blows fuses...
smell it !
Posted on Oct 13, 2009
Professor_V
  • 92 Answers
SOURCE: Rockford Fosgate Punch End CapsEnd Caps
I TAKE IT THAT YOU ARE REQUESTING A SOURCE FOR A PAIR OF ENDCAPS FOR YOUR PUNCH-200IX. IF THIS IS THE CASE, I SUGGEST THAT YOU CHECK EBAY ON A WEEKLY BASIS AS I AM SURE AFTER SOME TIME, YOU WILL SEE A PAIR LISTED. THERE IS ALSO A SELLER ON EBAY THAT HAS MANY OF THE LOGOS FOR THE MANY DIFFERENT MODELS THAT CAN BE PLACED ON ANY OTHER MODEL ENDCAPS FROM THE SAME SERIES (DSM, IX, X2, ETC. LET ME KNOW IF I MISUNDERSTOOD YOUR REQUEST......V
Posted on Jan 06, 2010
My rockford fosgate T1 amp blew a fuse and now protection is on
Chances are that more than a fuse went. I would follow (internally) the path of the wires from the speaker you mentioned - inside the amp. This should bring you out to the main amp. I think you will find that whatever powers that channel is faulty.
Apr 10, 2013 | Rockford Fosgate FAP T1 Amplifier
I was using bridge on a Rockford P300 and blew my cheap speakers but now my bridge doesnt work. Bought new speakers and want to run in bridge mode is there a fuse inside maybe or did I blow it up?
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Your amp is clipping.
No internal fuses. Your mosfets are toast. A thumbs up would be greatly appreciated if this answer is helpful to you. using-bridge-rockford-p300-blew-peeu4x5nsxvd53n2rwetiqa4-3-0.jpg
Apr 07, 2011 | Rockford Fosgate P3001 Car Audio Amplifier
I have a rockford fosgate punch P325.1 subwoofer mono amp that blows a fuse every time i start the car. I have a second pioneer amp but that works with no problems. How can i fix this?
Is it the correct size fuse ? Is it the power fuse or remote ? Either way check your connections going into the amp . Try this hook your other amp to the set of wires for the rockford if that amp has a problem its a wireing problem if not chances are its an interal problem on the rockford . Hope this helps !
Aug 19, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
Amp not working
It sounds like you either blew a fuse, or you cooked your amp. The fuse on the P200.2 amp is a 30A fuse, and it sits right next to the power, ground, and remote wire connections on the end. Pull the fuse out and see if it's blown. You should also check any other fuses that you have in the car before the amp.
Mar 03, 2010 | Rockford Fosgate Punch P2002 Car Audio...
I have a rockford fosgate p10002 amp when i give it power it blows a fuse like the power and ground are touching
make sure youre positive and negative wires aint touching maybe you have a tear i a gauge wire and its shortning out to save youre amp check all youre work if you installed it yourself...
Feb 22, 2010 | Rockford Fosgate P10002 Car Audio...
Amp fuses blowing and amp overheat
Does the amp heat up if you power it up with no speaker wires connected to the amplifier's speaker terminals?
Jul 17, 2009 | Rockford Fosgate Punch P5002 Car Audio...
Rockford Fosgate Punch 301X not runing
You should verify some other way (with a multimeter or another amp/device) that your 12V is working at the amp. Then to troubleshoot the Remote wire, take a short lead of scrap wire and run it from the 12V power input of the amp over to the Remote input like a jumper. If the amp still doesn't power up, then look for and check the fuse on the amp. If there's good power at the amp, the remote input has good power, and the amp doesn't turn on, and the fuse isn't blown, then the amp is probably toast. Good luck!
Jun 17, 2009 | Rockford Fosgate Punch 301X Car Audio...
Amp
There is no reset button. If you disconnect all of the speaker wires from the amplifier's speaker terminals and unplug the RCA cables, does the protect light still come on (I assume that you've already replaced the fuse)?
Jan 12, 2008 | Rockford Fosgate P6001BD Car Audio...
Rockford fosgate rfx-9200
If you're talking about the amplifier's power terminals, the positive terminal is designed to be wired directly to the battery (be sure to fuse the amp power wire near the battery terminal). The negative terminal should be bolted to vehicle chassis metal for a ground connection. The only amplifier connections that go to the back of the head unit are the remote turn-on wire and the RCA cables.
Aug 16, 2007 | Rockford Fosgate RFX-9200 CD Player
AMP WON'T WORK POWER SUPPLY?
that big coil of wires ytou described is the transformer for the switching power supply. Sounds like you over heated it and blew out the supply or the output section. From what you described you should take or send this unit into be serviced as there are no user serviceable parts in this unit except a fudse maybe and if thats blown theres more problems as thats there ( the fuse) just so the whole bloody thing dosent burn up your car! Good Luck
Jun 14, 2006 | Rockford Fosgate Punch 300S Car Audio...
Rockford Fosgate Power 350S Car Audio Amplifier Logo
29 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
