Question about PDAs
Authentication key requested for Panasonic RR-US 450 dictaphone
  • Anonymous Jul 21, 2008
    I DON'T HAVE KEY EITHER. PLEASE SEND ME: CD_CD@EMAIL.COM
  • yossimen Oct 08, 2008
    i dont have an authentication key
Dont have a solution
Posted on Oct 08, 2008
Dont know password
Account holders would usually have passwor accessibilty. Missing passwords are replaceble either reseting too capture new effects as authentic account holder. Also, the process is achieverble by account holdeer only requiring expert support in the situation that complexity arises. Uuslly with internet sites, a type key area allows to account holders to reset missing credentials. Howver, once support were required, contacting the tech from details provide make reset acheivable. Explore the network site to ascertin the program resources.
Feb 13, 2011 | Sharp Wizard OZ-800
Tip
Set up a GPRS data connection for email Please note: Please note that you need a...
Set up a GPRS data connection for email info.png boxAdd('subj0', cBoxClosed);
Please note: Please note that you need a POP3 email account in order to send and receive email messages on your phone. You cannot access web-based email accounts (e.g. Hotmail accounts). 1 Find "Access points"
  • Press the menu icon.
  • Press the fourth tab.
  • Press Phone settings.
  • Press Connectivity.
  • Press Access points.
2 Create new or edit existing data connection
  • To create a new data connection:
  • Press Add.
  • To edit an existing data connection:
  • Press the required data connection.
  • Press the icon to the bottom left.
  • Press Edit.
  • Press the Connection title input field.
  • Press C to clear the input field.
  • Key in EMAIL GPRS and press OK.
3 Select data bearer
  • Press the Bearer drop down list.
  • Press UMTS or GPRS.
  • Press OK.
4 Select authentication
  • Press the Authentication drop down list.
  • Press PAP or CHAP.
  • Press OK.
5 Enter username
  • Press the Username input field.
  • Key in user and press OK.
6 Enter password
  • Press the Password input field.
  • Key in one2one and press OK.
boxAdd('info6', cBoxClosed); The APN name general.t-mobile.uk must be in lower case letters. 7 Enter APN name
  • Press the APN input field.
  • Key in general.t-mobile.uk and press OK.
8 Save and exit
  • Press Save.
  • Press Disconnect to return to stand-by mode.
on Apr 30, 2008 | LG KU990 Viewty
LG KS360
Internet settings are usually found under the Phone Settings – Internet Settings.
- Connection mode Connection orientated / permanent / continuous connection
- GPRS APN live.vodafone.com
- Homepage URL http://live.vodafone.com
- GPRS ID username "none required"
- GPRS password "none required"
- Port (if required by device) 8080 (some older handsets may require you to enter 9201)
- PPP authentication type PAP (default)
- Proxy authentication name "none required"
- Proxy authentication password "none required"
- Proxy login type automatic (default)
- Security Off
- WAP gateway IP address 172.030.038.3 (your phone may require 172.030.038.003)
If you phone is a Vodafone NZ supported handset you may be able to have this sent automatically to your phone.
Mobile settings for sending and receiving PXTs (MMS messages)
The PXT settings can usually be found under Message Settings - MMS setting. You also need to send a message before you can receive one.
- APN live.vodafone.com
- MMS server address http://pxt.vodafone.net.nz/pxtsend
- GPRS ID username
- GPRS ID password
- MMS automatic download On (Automatically downloads full MMS)
- PPP automatic download PAP (default)
- Proxy authentication username
- Proxy login type Automatic (default)
- Security Off
Dec 22, 2009 | LG KS20 Smartphone
Nokia N82 bluetooth activation problem
My nokia n82 mobile bluetooth got problem. its not on what can i for do.
Oct 05, 2009 | Nokia N82 Handheld
LG suite & bluetooth connection to Viewty
You must first uninstall nokia pc suite:-)
Aug 09, 2008 | LG KU990 Viewty
Dont know what it is
Turn off smart password entry
You can turn off smart password entry to reduce the chance that someone might guess your BlackBerry® device password or smart card
password based on the smart password filter that your device applies to password fields.
1. In the device options, click Security Options.
214
2. Click General Settings.
3. Set the Smart Password Entry field to Disabled.
4. Press the Menu key.
5. Click Save.
For your information .........
If you use two-factor authentication and your BlackBerry® device password or smart card password is numeric, you might be able to use
smart password entry in some password fields. When smart password entry is turned on, your device is designed to remember the format
of a password that you type in a password field. When you type the password again, your device applies a smart password filter to the
password field. If the password is numeric, a 123 indicator appears beside the password field and you do not have to press the Alt key to
type numbers. If the password is alphanumeric, an ABC indicator appears beside the password field.
Smart password entry prerequisites
• Verify that the correct smart card driver and smart card reader driver are installed on your BlackBerry® device.
• Verify that two-factor authentication is turned on
Jun 04, 2008 | RIM BlackBerry Pearl 8100
Secure Password Authentication (SPA), and SMTP Authentication
Yes, the P300 supports Secure Password Authentication (SPA), and SMTP Authentication.
Sep 15, 2005 | NEC MobilePro P300 Pocket PC
PPP
The P300 supports PPP PAP Authentication, PPP CHAP Authentication, PPP MS-Chap Authentication, and PPP Password encryption - MD5, but it does not support PPP data stream encryption.
128 bit encription for WEP
Should just be: turn WiFi on, WiFi Manager -- tap Configure -- tap on name of your network, then on Authentication (or Authentication Key). Then set Shared/WEP, uncheck the box "Key is provided automatically", and enter your key. Remember, the iPaq wants the actual key in hexadecimal, not the passphrase. And you'll need to know which of the 4 standard WEP keys the one you're entering is. Good luck.
Sep 08, 2005 | HP iPAQ HX4700 Pocket PC
PDAs Logo
720 people viewed this question
Top PDAs Experts
Are you a PDA Expert? Answer questions, earn points and help others
