Question about NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC Card Adapter (USBP2D20) Serial Adapter
NEC USB 2.0 CARDBUS CARD
I've been trying to use the above device in my Dell Inspiron 8200's PCMCIA slot with an iPod Touch. I'm running XP Pro SP2. I can print from one of the ports but when I connect the Touch or a Garmin Nuvi, my computer locks up. Removing the Touch or Nuvi doesn't unlock the computer. To do that I have to pull out the card. Then everything is Ok. Dell phone support thinks there's a power problem. I refuse to give up. Is there anything I can do to resolve the matter. I just ran event viewer and found a number of warnings and a couple of errors. I need the advice of a master.
  • parorodai Jan 06, 2009
    I need the NEC USB 2.0 CardBus driver ,Where can download it ?
Your problem is a power overload on the USB 2.0 card. If you plug in a 5volt power supply to the USB 2.0 PCM/CIA card, it will solve your problem. You can also use any USB port on your computer to plug in an A-A USB cable to power the PCM/CIA card and it should resolve the lockup. Also, check and make sure you have enough RAM memory in your comptuer for Windows XP. Recommend 512, but runs much better on 1024 (1 gig) of RAM.
HTH
Posted on Oct 14, 2008
Thanks for your suggestions. I tried each of them along the way without success. Then a Best Buy Geek Squad member, after failing at everything else, tried connecting my iPod Touch to the native USB 1.1 ports at the back of my laptop and it worked even though Apple claims USB 2 is absolutely necessary. It worked. Perhaps MS's SP2 juices the native ports. I have no other explanation.
Posted on Aug 25, 2008
I'm no master, but...
Try supplying external power to the USB card (it should have a power-in connector), possibly from a non-PCMCIA usb slot or from a ps/2 keyboard connector. See elsewhere for how; i've never done it myself.
You may need to update the USB drivers, see http://support.microsoft.com/?kbid=873169
Posted on Aug 22, 2008
Usb pcmcia cardbus card will not lock in place
Are you sure? Push it. On some laptops there might be two slots for the card (one above the other). If your system has space for 2 cards, try the other slot.
May 04, 2012 | Computers & Internet
SIIG Hi-speed USB 4-port cardBus - iphone/flashdrive problems
Remove your device from the device manager and reboot unit.
Restart and reload device drivers.
Make sure the driver are for xp pro
Nov 14, 2009 | Electronics - Others
1616m card not recognized by Dell D600 PCMCIA slot
HI BRO PLEASE HELP ME OUT ..........
AM UNABLE TO FIND OUT AUDIO DRIVERS FOR MY SYSTEM IBM 8122KQA
Feb 02, 2009 | E-Mu 1616M Sound Card
Nec USB 2.0 CardBus on HP Compaq nw9440 with Vista Ultimate
Hi I have a Compaq Presario 919EA with xp operating system and others have a nec pcmcia usb 4-port and when the insert locks the operating system
Feb 01, 2009 | NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC...
External hard disk and pcmcia cardbus
Try reinstalling the drivers for the PCMCIA card and get drivers for the external hard drive..if that doesn't work then get this here. Don't buy dell they have bad quality products.
May 20, 2008 | Dell 4-Port USB2.0 PCMCIA CardBus Card...
Windows doesn't detect the adapter
may there is realy a defect on that card. just try use another card and see the result.
Aug 13, 2007 | NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC...
Techgear 3-port 1394 FireWire CardBus
Jim, Have you run the add hardware wizard? Are your pcmcia card slots enabled? If not in Control Panel then in the BIOS? Good Luck, Tim
Feb 06, 2007 | A D S GBR-101 (GBR101) Serial Adapter
Machine locks up
install the vendor specifig driver for the PCMCIA. because windows XP sp2 is also able to detect the device and when you push the device online it is detecting and there is some other device which has got same IRQ and that is conflict with this and stop. see any error that is generated in event viwer * run>type "eventvwr" and enter * see the application/system try to detect your error log and see what microsoft says about it. otherwise post the error report Thanks Arun
Jan 17, 2007 | NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC...
NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC Card Adapter (USBP2D20) Serial Adapter Logo
1,483 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
