Question about TurboChef TORNADO Electric Oven
MY UNIT HAS AN ERROR MESSAGE OF F3MAGCURR AND WAS WONDERING WHAT WOULD BE CAUSING THIS
    Scholar:
  • 75 Answers
There is a problem in the high voltage system. This is typically an expensive repair and generally requires someone with a working knowledge of electrical and testing skills.
Posted on Nov 01, 2010
Frigidaire error code f27 Ovens
Most error codes can be cleared just by unplugging the unit and re-plugging it back in. If this doesn't clear it then I would go to Frigidaire's web site and search for tech support. I did some checking with Frigidaire and they don't show a code f27 I was wondering if maybe it was showing two codes F2 and F7? so it might look like F2,7?
Nov 18, 2015 | Frigidaire FGB24S5A Gas Single Oven
My mbleoven had a E2-F2 code what is the oro
The F2 class of error messages means that the keypad and the control unit aren't communicating properly. First turn off the circuit breaker to the range for a minute. Check if the error recurs after you clear the PF message. If the error recurs, turn off the power again. You need to check the wiring between the keypad and the control unit. Make sure that all of the wire harness connections are fully seated and all the wires are undamaged. It's not uncommon for one wire to get broken so check the continuity.
If that doesn't help, you probably need a new keypad. If you add a comment with the model number of your oven, I may be able to point you to a supplier.
I hope this helps.
Nov 22, 2014 | Whirlpool Ovens
Dr error message
Hello Herb Reinhart - If the range previously displayed DR and now showing F11, it typically indicates that the unit has detected a shorted keypad. Since you have already try resetting the unit by unplugging it and issue persists, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
Apr 09, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
F1 code
Most F1 error codes refer to a communication error in the main control board/ clock on some there are reset overload switches that if tripped show as a push button that is pushed outward that you can reset. This also mainly depends on which type of oven that you do have and you would have to provide the make and the model number of the unit in order for me to give you an exact solution to your f1 error instead of a generalized one. Sometimes also you can turn off the power at your electrical breaker for 7 minutes which this causes the control to reset in some. Most of the time in most models though the F1 refers to having to replace the electronic control module (ECM. If you have any further questions or wish for me to look up the exact error for your unit message me back your make and model number and I will give further diagnosis on your unit. Thank you again
Rick
Nov 26, 2011 | Ovens
My Kenmore Elite oven door is locked and I am getting an F93 error message. I have had repairmen here 3 times already to fix the problem. Can you help?
The F93 - Maximum oven door lock time exceeded. First thing to try is holding the clear button down for 3-5 seconds sometimes this unlocks the door and then leaves the loc light still on in this case you would open the door and once again hold down the clear to make the loc light clear. If your unit doesnt have a clear button then you would hold the stop button for the same amount of time as described above. If this doesn't work try shutting off the power at your electrical breaker for 7 minutes this usually causes the control to reset in the unit. If you have any further questions or if this does not work to allow you to be able to open the door and clear the error code message me back for further diagnosis. Thanks
Rick
Sep 03, 2011 | Ovens
Error message "F7" What does
Hi
Error code F7 means that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | Kenmore Ovens
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
F3MAGCURR
Your magnetrons failed you must figure replace the 20 amp fuse and find out why they failed. Need more help email me at ndjm74@aol.com
Mar 20, 2010 | TurboChef TORNADO Electric Oven
My oven wont work
Get out your User Manual and follow the initial setup instruction
The machine is waiting to be told what to do
You will need to turn off the power to the cooker and when you switch it back on again you have a limited amount of time to put in the settings so write them down on a piece of paper before you start
Jun 02, 2009 | Whirlpool RBS305PD Electric Single Oven
TurboChef TORNADO Electric Oven Logo
73 people viewed this question
Top TurboChef Ovens Experts
Dennis Boxerman
Craig Butler
Craig Butler
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
