Question about Kenmore 24 in. 16532 - Multiple Color Built-in Dishwasher
Very long cycle as before
My dishwasher take forever to do is cycle. i can see 78min to go and afer 15min i still see 78min to go. and some time dish are no so clean and i fill up the rinse often.
Thanks
Robert
  • JensenReb Jul 27, 2008
    My washer has the same problem, but mine gets stuck on 42 minutes left to complete cycle.
  • seguin Oct 21, 2008
    my machine has a very long cycle also it is stuck on 83 for about 30 minutes
  • 734 Answers
If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Yourdishwasher may pre-heat the water. If so, and if the water entering thedishwasher is cool, the heater may take up to half an hour to heat thewater.
To avoid the wait, increase the incoming watertemperature before turning on the dishwasher. Do that by running thekitchen sink faucet until the water runs hot. Or increase thetemperature of the hot water to the entire house at the hot waterheater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Posted on Dec 12, 2008
Runs through cycle, but dishes and glasses do not dry, they are soaking wet.
10 Tips to Help the Dishwasher Run Better - Cleaning Tips ...
www.thekitchn.com/10-tips-to-make-yo...
Apartment Therapy's The KitchnFeb 24, 2014 - Well, we're here to help, with 10 tips for making your dishwasher run its best. ... loading up to help reduce particles stuck on dishes once the cycle is over. ...water to flash dry and not roll off your dishes, taking the ends of the dirty bits with it..... but can lead to damage, particularly of any glasses you put in the ...
[PDF]Dishwashers - Frequently Asked Questions ... - Bosch
www.bosch-home.com/Files/Bosch/In/in/Document/Bosch.pdf
this cycle the dishwasher dries the dishes. 3. ... dishes. During this time, you do notneed to be around the dishwasher as it ... Does it also dry the dishes after the wash?... You can put utensils that are made out of steel, ceramic, glass, plastic which is ...No, the dishwasher runs the whole washing programme automatically.
Why is My Dishwasher Not Drying the Dishes? ' Dr ...
Dec 03, 2015 | Dishwashers
We just bought a GE dishwasher today and it seems like the cycle never ends.We have silt in our water, can this affect the autosense?
Mine use to go forever because my water wasn't hot enough. The dishwasher would heat the water up to a higher temperature before it began to wash the dishes.
Feb 24, 2015 | GE Dishwashers
My bottom dish washer was draining the water on the top dishwasher and there is always water left over on the top.I remove the pipes and put CLR to clean up drain.Start both dishwasher on rinse cycle ( 12...
Hi
Thanks for using FixYa.
F1 error means that the flood switch has been activated. You'll need to reset it by powering off the breaker or by unplugging the unit from the power socket and mains for more than five minutes. Please check that there is no blockage in the drain hose and it is not raised higher otherwise the water will run back to the dishwasher. Also perform the following procedure---
    • Unplug power and remove bottom dish drawer
    • Use a Sponge and dry all the excess water underneath
    • Remove circuit board cover
    • Dry all around and underneath as much as possible
    • Apply hairdryer for 10-15min
Please rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Oct 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a bosch dishwasher shu6805uc/u06 to long to wash.
Well not going into the dry cycle could be a timing issue or a EOC (control panel) issue and will need to be addressed. But most dishwashers these days have a active run time during normal cycle of 110 to 120 mins, and thats not including the heated dry feature. I would let the unit run and see if it will finish on its own, and if I say it pushes two and half hours then something is wrong. A tech would most likely have to look at it, also a power reset could help but thats like a 30% chance.
DrakeTech
Dec 30, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
The dishwaser takes a very long time to run thruogh is cycles.
on many models, the timer will not move if the water is not up to temp. be sure that you run hot water in the sink until it gets hot before you start the dishwasher.
are your dishes coming out clean and hot? if not, your heating element may be faulty. this is used for drying, but also to maintain water temp. during the cycle. a bad heating element will certainly make the cycle take forever, if it ever gets done. good luck
Nov 02, 2009 | Asko D1716 Built-in Dishwasher
Won't stop cleaning to go to dry
I have not worked with this Kenmore model, but:
It would be good to check the heating element to make sure it has not failed. Some dishwashers will wait forever for the water to come up to temp before it goes to the next cycle.
If the heating element checks out:
-IF it has a knob/dial that you turn to start the dishwasher on any cycle, that timer/controller has most likely failed.
-If your dishwasher does NOT have a dial as described above, then the main controller card (PCB) has most likely failed.
May 05, 2009 | Kenmore 16072 - Multiple Color Built-in...
Model # dwu7702aae has heat delay light coming on during cycle. Why?
Heater is used to both heat water during clean cycle and dry dishes after wash cycle. Most washers have either a separate switch for Heat or Dry for optional use, or some have the water heat and dish dry options built into cycle set options.
You can save money by turning off the Dish Dry option since it is a very in-efficient way to dry dishes. Instead, open the wishwasher door after washing cycle completes, just enough so fresh air can get into, and humid air can escape, dishwasher.
Water Heat option is only needed for dried food on dishes, and is never needed if dishes are either rised off before putting them in the dishwasher, or rinsed off inside the dishwaser with a Rinse cycle, if they are to stand for a time waiting for a full dishwasher for wash.
Feb 22, 2009 | Maytag Dishwashers
Endless cycle with wet dishes
If it's a Bosch, check for Rinse Agent (e.g. JetDry). Rinse agent is not optional with a Bosch.
Apr 14, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Kenmore 24 in. 16532 - Multiple Color Built-in Dishwasher Logo
351 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
