Question about DeLonghi EAM3400 Espresso Machine
We understand that your problem is: My DeLonghi Magnifica EAM 3400 Super Automatic Espresso Machine frothing wand leaks water while making espresso, so no water gets to the espresso so no espresso is made. Is there a way to fix this. My machine is about 3 years old. .
  • 1 more comment
  • pamneuman Sep 01, 2010
    The product is not under warranty. Where do I get the valve and do I need to dismantle the machine to get access at the valve?
    Is there a specific name for this valve, so if I need to replace it I can locate it? Pma
  • pamneuman Sep 02, 2010
    Do you mean putting full strength Real Lemon juice (bottle) into the water tank and run the espresso machine like it was making a latte?
    President:
  • 2,047 Answers
Based on the information provided above the machine is a bit old as 3 years of regular use is quite a while. If the frothing wand is the only part of the machine which leaks water it can be presumed that a replacement of the part is in order.
It will be advicable if you can afford a new machine to get a new one otherwise get an expert to replace the frothing wand and run a general service of the entire machine.
Water leakages around electrical appliances are very dangerous and the consequences are always disastrous. So ensure that either the device is handled by an expert or replace the unit completely.
Hope this solution has been helpful?
Posted on Sep 03, 2010
  • 10,319 Answers
Run it one time with Real Lemon lemon juicer it out to operate That will make it run smoothly again
Posted on Sep 02, 2010
  • 944 Answers
This valve will differ based on the DeLonghi models
If the machine is still under warranty you may void the warranty any time you take it apart.
When water heats it expands which creates more pressure in the boiler. This pressure may allow some water to sneak by.This valve is located behind the shower screen and keeps the water from being forced out of the boiler as it heats and the water expands. When you want to make coffee and turn the pump on the valve will stay closed until enough pressure is built up to push it open allowing the water to flow. When you turn the pump off, the pressure reduces and the spring on the valve pushes it closed. When the steam button is pushed the boiler heats up to a higher temperature and the pressure in the boiler increases putting more strain on the valve.So this valve may be loose or some time may be defective one.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 01, 2010
  • Natarajan Ramasamy
    Natarajan Ramasamy Sep 02, 2010
    Boiler pressure valve.If you have proper tools you can take it else you will mess and don't break the boiler.It cost very less to change it in service centre.
    Thank you.
Why is Delonghi Perfecta not producing steam to froth milk.Nothing at all happens when cappacino button is pushed
At wits' end DeLonghi Magnifica steam function - Coffee Forum
www.coffeeforums.com/.../9427-wits-end-delonghi-magnifica-steam-fun...
Jun 1, 2012 - While I quite like the coffee it produces, the steam function seems to be ... it with the magic DeLonghi descaling solution, so I'm certain this is not ...
DeLonghi not producing steam Questions & Answers - Fixya
www.fixya.com > Forum > Tags > not producing steam
Ask your DeLonghi not producing steam questions. Get free help, advice ... Ad. Question about Esclusivo Magnifica ESAM3300 Espresso Machine. 3 Answers ...
Delonghi 3500s coffee machine not producing hot water or ...
Dec 06, 2015 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Espresso part is working, hot water/steam draining into drip tray.
I had the same problem on my Delonghi ESAM3300; you need to replace the "Tap" #7313216621 you can buy at eReplacementParts.com and search on how to install on Youtube. Its easy. No more leaking. Good luck
Oct 07, 2015 | DeLonghi ESAM3300 Magnifica...
Descale eam3400 delonghi magnifica machine
Hi, you need to select descale procedure from menu options and then add descale solution usually 100-125ml to 1l of water to your tank. Also you should find this how to do in instruction manual.
Jun 28, 2014 | DeLonghi EAM3500 Espresso Machine/Coffee...
Delonghi magnifica rapid cappuccino model EAM 3400.S KEEPS SAYING INSERT THE INFUSER, I HAVE PUT THE INFUSER IN AND IT HAS CLICKED BUT IS STILLS SAYS INSERT THE INFUSER
try cleaning any old bean dust ect with vacuum ... refit or replace infuser lot better . if still no good you need someone to check pcb assy ... bsc appliances 07779933829 we cover repair service anywere via post.
Nov 28, 2010 | DeLonghi EAM3400 Espresso Machine
Where can I get the parts for delonghi magnifica eam-3400.n
Howdy:) You can get parts and accessories for your Magnifica here: http://www.delonghiusa.com/index.php?texts&pid=15
Hope you are up and espressing asap:)
Aug 24, 2010 | DeLonghi EAM3400 Espresso Machine
Delonghi Magnifica 3500 not frothing
use cold low fat milk and keep the milk container in the frig.
Make certain that when washing water come out of both holes.
Jul 09, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
I have a model EAM 3400 expresso super-automatic. A couple of weeks ago after a regular schedule cleaning, the machine began dropping only about half the water through the infuser and into the cup. the...
Yes indeed... whozcraig,
65% of the problem reports on these
EAM 3400 are "LEAKS" ...
I would also check also AMAZON & eBay (prices)
((eBay = machines for parts, parts + lots of O-rings ))
but some of the BIG parts houses actually have
video assistance on-line...
Just NOT my favorite (appliancepartspros)
DeLonghi EAM3400 Magnifica Parts
Parts do abound... (a popular problem)...
Good luck
Carnac the Magnificent
Mar 11, 2017 | Refrigerators
Open Questions:
See all DeLonghi EAM3400 Espresso Machine Questions
DeLonghi EAM3400 Espresso Machine Logo
301 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
