Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
My simple tech external hard drive for 750 gb was working properly but today when i plugged it into my computer it says new hardware found and the driver does seem to be listed. i have no internet connection at my house. kindly help
  • 480 Answers
Hi, The usual issue with this type of error is the software that is being used by the HD is corrupted or missing. Try reinstall it again. Cheers!!
Posted on Sep 01, 2010
The computer does not recognize the Simpletech external hard drive. I plugged in a different external hard drive into the same USB port and the computer recognized it right away. What is wrong with the...
not all usb devices work on all machines
You need to find a driver or ask simple tech what the issue is i had the same issue with My WDC drive Western Digital gave me a driver after emailing them
Aug 13, 2009 | SimpleTech 750 GB USB Hard Drive
Device cannot work
Try cleaning your computer for spyware and viruses. Also try cleaning your registry out using a utility. Do your USB ports on the computer work with any other devices? Try using different USB ports and make sure theres no faults in you device list with the USB drivers. Let me know more info. What OS are you using. By unplugging it without safely removing is most dangerous to Flash memory but it's definitely possible to damage a hard drive by doing so. You might have corrupted your drive. Hope this helps.
Jul 25, 2009 | SimpleTech SimpleDrive 160 GB External USB...
I have a 60 GB simpletech external hard drive. I
Try to hook it up to another computer and see if it works there. This will tell you if the device is failing. If you have found that it failed please see about replacing the power adapter. If still no live the device has failed and needs replacement.
Thanks, Frank Z.
@Tech
http://www.attechcomputers.co.cc
3868607368
Jun 24, 2009 | SimpleTech Pininfarina 60GB External USB...
Transcend 250 GB Hard Drive not recognized by Windows XP SP2
u may got installation cd for storage device.if not download software from www.transcend.uk  ......... otherwise try for this..
goto control panel...
then goto add hardware...
overthere check out for connectivity
Jan 28, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Simpletech hard drive not working
I have that problem similiar to yours. My simple tech stopped working for like two years so i decided to open up my simple tech and removed my HD away from the old enclosure so I can try building my own external hard drive for the first time. I bought another new 3.5 enclosure, IDE/ATA for the old HD. I put it in the new enclosure and it worked!
It's the only solution you can have. No need to retrieve data or re-format your HD. You can leave it the way you like...if you wanna reformat it...up to you.
Jan 27, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Accidentally deleted partition
Simple, Connect your HD and boot computer using win XP CD and try to create a partition again using unpartioned space ! - xome
Aug 21, 2008 | Seagate ST307504FPA1E3-RK FreeAgent Pro...
Simple tech 500gb usb hard drive
Youve damadged the harddrive, is the harddrive spinning or making any noise?
Jun 16, 2008 | SimpleTech SimpleDrive Pininfarina 500GB...
Simple Tech external hard drive
if you are running windows, then check the following:
go to control panel -> administrative tools -> computer management -> storage -> disk management.
you probably have a drive (located on the bottom right) that is listed with no drive letter, just assign it a drive letter and see if it comes back, if not, the drive is probably not initializing and you might have to either format it or replace it.
Jun 13, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Problems
One thing to remember is the some of the Simple drives requires the USB mini to conect to the drive and the TWO USB connects to be plugin to the computer.
Jan 15, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Western Digital Elements Drive Problem
check the drive on any other system.
may be last time you were using the drive and system carsh or improper shutdown this can cause the drive damage.
Also may be a virus format the disk and try it.
Jan 06, 2008 | Western Digital 250GB ELEMENTS EXTERNAL...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
73 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
