Question about Miller Welding Tools
I have a miller 251 millermatic welder that has no response to the gas being tiggered when i press the gun trigger
    Sergeant:
    Champion:
  • 389 Answers
Check the wireing from the gun to the servo,it may have got damaged.then test the servo
Posted on Sep 02, 2010
My trigger to my millermatic 250 won't stop feeding the wire even when switch is not pressed
Does it feed with the trigger plug removed from the machine? If so, then it is a circuit board. If no, then wires shorted somewhere in the gun.
Apr 17, 2012 | Miller Welding Tools
Millermatic 211 temp light flashes when machine is turned on. fan is running and air flow is not blocked. if i unplug the little plug for the gun and plug it back in the wire will start feeding all by...
Hi:
By the description sounds like the trigger itself is the problem, have you try to bypass (bridge) the connection (disconnect the gun's plug from the machine and use a clip to bypass it at the machine's end) and see if the problem persists?
If the problem continues, then the problem would be the heat sensor.
Aug 25, 2011 | Miller Welding Tools
I have a millermatic 251 but the gat wont come out when i pull the triger
First, you need to check that you have the correct input voltage going to the machine. The main PC board on the welder disperses the input voltage to many different things,ie. the gas solenoid, the drive motors, contactors, transformer, stabilizer etc.
So if your machine is made to run on 230v and it is plugged into 208v, the first thing to stop working is the gas solenoid because it requires more voltage (34vdc on this model) to actuate.
If it turns out you are running the correct power to the machine, there is something wrong with an internal component on the machine and it needs to be brought to a certified miller service center where it will most likely be one of two things, the gas solenoid (about $30+ labor) or the main PC board ($500-600+labor) hope for the best on that one.
best of luck!
Aug 14, 2011 | Miller Welding Tools
I have a miller 255 nig .the welder will start to weld and stops gas flow is working the triger is working . You can relase the triger and start it again it willweld about 1 inch and stop emall ...
Sound like you have a machine programed on stitch mode, to override the program do the following:
1)Turn off the machine
2) With the machine turned off press the gun trigger.
3) Turn on your machine keep the trigger pressed, hold it for about 3-5 seconds. Depress the trigger and you should be good.
Jan 03, 2011 | Miller Welding Tools
Miller 350p welder gives a "help 3" code.
Code help-3 Indicates that the gun trigger was pulled and held during power up. Release gun trigger and clear fault condition. Also, this display can Indicate no open circuit voltage detected when gun trigger is pulled and no arc detected within 3 seconds, this means that the trigger was held without any metal contact. The machine will shut down in order to avoit the wire to continue to run freely.
To fix:
Turn on the machine without pressing the trigger on the gun. Then increase to the max the wire speed. Then turn off the machine. Press the trigger after the machine was turn off, then without releasing the trigger, turn on the machine and release the trigger after 2 seconds. That will take care of it.
Nov 17, 2010 | Miller Welding Tools
Have a miller Millermatic 130XP drive roll not working
Have a 130 xp welds the same with or with out the gas welds not smooth
Jun 29, 2010 | Miller Welding Tools
The millermatic 135 gun has stopped working. Could this be from the switch going out?
If the switch is dead, the gun will not work. Pulling the trigger tells the machine to initiate delivery of the wire, gas and current. If the switch is dead, none of that will happen.
Feb 09, 2010 | Miller Welding Tools
Miller syncrowave 250 tigrunner with gas flow
Your problem is in one of two areas. The controller board inside the unit or a bad trigger on your gun.
Nov 25, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
No constant gas flow...
a hole in your gas line or the solenoid is sticking
Jul 30, 2009 | Miller MATIC 140 MIG WELDING PKG w/cart...
Open circuit??
try blowing out the welder
Mar 19, 2009 | Miller Welding Tools
Welding Tools Logo
304 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
