Question about Sony Playstation 3 (PS3) Console
PS3 Video Format conflicting with Tv format
I have a problem. I currently have a regular SDTV in my apartment, but went to my parents house and played on 1080i HD. SO i switched the format of the ps3 to 1080 and now I can't see the video on my SDTV due to the settings change. Is there anyone that can tell me directions to blindly change my video settings or is there another way to fix it? Thank you for you time.
  • Jshaps May 10, 2008
    My Ps3 didn't come with a hardware disk. I have a 60gb one not sure if that changes anything.
Power on your PS3 and as your powering it continue to hold the power button for 5 seconds until you hear a second beep.
Posted on Jul 08, 2008
    Genius:
  • 1,224 Answers
Put in your ps3 hardware disk that came with your system in the box and switch back the parameters that way your system came with a setup disk that auto matically runs in lower mode so you can reset your system parameters
Posted on May 10, 2008
Screen says "format not supported"
You need to lower your PS3 video resolution, Google the web on how to change the PS3 video resolution.
See examples here:
http://www.youtube.com/watch?v=JHQnpyIE7sE
http://manuals.playstation.net/document/en/ps3/2_20/game/output.html
http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Right now it is too high for this small TV to display.
Nov 19, 2010 | Sylvania LC195SLX LCD TV
How can I play Canon's HD .MOV files on the PS3?
Hi van derb
You would need to convert MOV file into a format which PS3 understands.
This can easily be done with a simple conversion tool such as the 3herosoft PS3 Video Converter.
1) Download and install 3herosoft PS3 Video Converter. Once installation has completed, launch the program. Step
2 ) Click "File" and then "Add" from the top menu of the 3herosoft PS3 Video Converter program. Browse to the folder and location of your MOV file. Select the file that you want to convert to PS3 format and click "Open." Once selecting the file, it will be added to the conversion list. Step
3) Edit the file as desired. Modify fields under "General" in the upper left-hand corner of the program window. Changes can be made to video size, duration, frame rate, buffer size and more. Step
4) Click "Convert" button (red circle) to convert the MOV file into PS3 format. Locate the converted file and transfer it to your PS3 for playback.
You can download this software from following link. http://download.cnet.com/3herosoft-PS3-Video-Converter/3000-2194_4-10909133.html
Please rate, as this will help us know whether solution was helpful or we need to improve on it. If not resolved you may post a comment and let me know, so that I can research and provide you with a better solution. Thanks :)
Apr 28, 2010 | Sony Playstation 3 (PS3) Console
I am having a problem with a new tv I cant get a picture using a HDMI cable my TV says invalid Format. what do I need to do?
The format of signal your pushing with you ps3 is to high adjust it down to stadard def and work you way back up most tv's are 720p and your ps3 will try 1080p as a defualt with your tv does not understand, also check the cable as well there are diffrent versions of hdmi such as 1.0,1.2. etc etc make sure you using a lowest bandwith cable that way there are no conflicts.
thanks I sure hope this was Very Helpful!
Dec 13, 2009 | Sony Playstation 3 (PS3) Console
Invalid format??
change the display settings to 1080i or 720p- his tv likely does not support 1080p.
Mar 30, 2009 | Sony Playstation 3 (PS3) Console
PS3 Works on HD TV without Sound, no sound or display on a reg TV
when u connect ps3 to your tv turn on main switch now red led will come on press and hold touch button ps3 will come on keep your finger on the button and ps3 will turn off again factory settings are now reloaded this will work because i often change from standard v to hd tv
Jan 18, 2009 | Sony Playstation 3 (PS3) Console
No color
Sounds like you are having a issue with color format or a bad connection cable... In the US we use the NTSC color format, Japan uses NTSC-J, and Europe uses PAL. This matters quite a bit; if you have some Special Edition PS3 that they only sell in Japan and have it plugged into your Flatscreen TV in the UK no dice. Make sure you do not have conflicting regions for your hardware. Moreover, make sure the pixel resolution is not out of bounds for your TV's range. The PS3 has different connection cables for every kind of connection; RCA, HD, HDMI. I recommend using HDMI if your TV supports it.
Nov 28, 2008 | Sony Playstation 3 (PS3) Console
My PS3 will only play random .avi format video files using it as a media server
look in the programe menu on the ps3 and see if it set to only setin one file format amd change to all to play
Jul 11, 2008 | Sony Playstation 3 (PS3) Console
PS3 DVD'S playing
If there is no picture on the TV screen: Back to top
  • Check that the input mode of the TV is appropriate for the connector in use on the PLAYSTATION®3 computer entertainment system.
  • There may be a problem with the cable in use. Try using another cable that is compatible with the PLAYSTATION®3.
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
If the DVD or Blu-ray Disc™ (BD) cannot be played, or the picture is distorted: Back to top
  • When outputting DVD content or PLAYSTATION®3 system format software in SD resolution, only discs recorded in the NTSC standard can be played.
  • If the PLAYSTATION®3 is connected to a VCR or a combination TV/VCR unit, copy protection encoding on some DVDs and BDs may cause image distortion, or may cause the image to become lighter or darker. In such cases, connect the system to the TV directly.
  • If the DVD or BD does not match the region code set in the PLAYSTATION®3, it cannot be played.
  • Some DVDs are preset with parental control restrictions. Enter the password that was set in "Security Settings" to temporarily increase the viewer age restriction level.
  • Some BDs are preset with parental control restrictions. Enter the password that was set in "Security Settings" to change the parental control level.
  • The BD may be disc-locked. Enter the password that was set when the disc was created.
Apr 16, 2008 | Sony Playstation 3 (PS3) Console
PS3 Won't Play Blu-Ray
if non of that works you need to contact Sony at
1-800-345-7669 (SONY)
Mon - Sat 6:00AM - 8:00PM PST
Sun 7:00AM - 6:30PM PST
Good Luck,
-Rel
Sony Playstation 3 (PS3) Console Logo
1,124 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
