Question about Estate TAWS800JQ Top Load Washer
How much would a new timer be? - Estate TAWS800JQ Top Load Washer
    President:
  • 3,773 Answers
Go to
www.marcone.com
Have your model no. ready
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Sep 01, 2010
Timer wiring
there should be some schematic on the new timer , if you can send it can help to understand how to configure/ or at least the brand and model for the timer can help.
Sep 30, 2017 | Hardware & Accessories
Only part of the display is visible
Copy following link for sprinkler timer manuals for all current products including raindrip, with possible troubleshoot section each manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
If this timer is not new, then change battery before buying replacement timer.
If timer is new, then exchange for timer that works.
Gene
h
Aug 19, 2013 | Raindrip R673CT Digital Water Timer
Timer does not work
1) Copy following links for Intermatic timer troubleshoot.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timers.html
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timers.html#module
2) If this is box timer with yellow dial, then buy new clock motor.
If this is box timer with timer module, then buy new timer module
3) Add comment and say what you discover
Jan 07, 2013 | Hardware & Accessories
Flashing Christmas lights
Copy following link for general troubleshoot
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
1) Turn photoeye away from lights.
2) Buy new timer since photoeye is first thing to malfunction on cheap Christmas timers.
3) Buy new timer at Lowes, and return defect in new package
Dec 02, 2012 | Hardware & Accessories
When i unplug the timer then reset a new time schedule and plug timer back into wall my timer sets to 88:88. whats am i doing wrong? this timer worked brilliantly until i reset and plugged it back in.
Open following link to identify timer and read instructions:
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Timers go bad for many unprovoked reasons.
Check outlet with circuit analyzer.
This timer has 1 year limited warranty.
Extended warranty: If timer is defective, then buy new one from Target or Lowes, and return defective timer in new package.
To review:
Replace AA battery if this model has a battery carriage. Otherwise timer has internal rechargeable battery.
Press reset button with paper clip for a few seconds.
88:88-88 will flash on screen momentarily, and then 12:00 am will display. Timer is ready for programming.
If 88:88-88 does not roll over into the 12:00 am display, try resetting again.
If timer will not hold new programming, and keeps resetting, then see if reset button is stuck.
If timer does not reset and re-program correctly, then timer has gone bad.
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 23, 2011 | Woods Industries 59377 Indoor Digital...
Timer has been programmed but will not go on or off automaticvally. Has a new battery and the red light is on. I have to use the breaker to turn the pump on and off????
You posted under Intermatic PB300 series timer module.
http://waterheatertimer.org/pdf/Catelog-146-PB300.pdf
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#FM
Failure after battery replacement is common complaint about timers.
Chance to restore functionality is to reset timer.
Reset PB300 timer using round reset button on far right side.
If functionality is not restored, then timer has gone bad.
Order new timer module using information on back of timer, and take photo of wiring so new timer can be wired easily.
Jul 18, 2011 | Intermatic Panel Mount 24-hour Electronic...
Hi! Please help me. I am having trouble connecting the wires from my dead 220v T104 pool pump timer to a new 220v T104 timer. The old timer had posts marked G 1 2 3 4. The new one has posts marked L 1 X...
Open following link for T104 wiring diagram:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Your new timer is L 1 X 2, so that is not Intermatic T104.
You might have GE/Tork 15061 that fits into Intermatic box.
http://waterheatertimer.org/GE-timers-and-manuals.html#GE-replacement
First thing to check is if new timer is 240Volts to match old T104.
If new timer is 240V, then here is crossover:
"Old 1" goes to new L >> and notice that L and 1 are connected by brass bridge. If bridge is missing, add a jumper wire between L and 1 on new timer
"Old 2" goes to new 2
"Old 3" goes to new X
"Old 4" goes to new X
T104 Intermatic timer is SPDT single pull double throw, so it turns off both wires going to Load.
New L1X2 timer is SPST single pull single throw, so it turns off one wire going to Load, and that's why old 3 and old 4 both connect to terminal X.
If this is too complex, then add a comment or buy new trippers and a new WG1573 clock motor and repair T104 for $20.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
Apr 22, 2011 | Intermatic T104 24h 208-277v Mechanical...
Hello! I have a 59017 timer, and this is my problem: When I put the timer in Timer option, If I have all the pins in off, the timer run ok, but if I put one Pin in On mode, The timer run ok but when find...
You don't say if this is new timer installation.
Or if timer was working before and suddenly stopped working.
I also own Woods 59017 timer from Home Depot.
1) New timer installation:
Open following link to access manual and read wiring instructions.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59017
2) Old timer that stopped working:
If timer dial does not rotate, then the timer is broken, does not have power, or is wired wrong.
If timer stalls when it gets to a pin, then the clock motor has gotten weak, and is overheated and will stop working.
3) Buy new GE 15070 timer from Home Depot for $18
http://waterheatertimer.org/GE-timers-and-manuals.html#15070
4) Buy new Woods 59017 at Amazon for $11 plus shipping
http://www.amazon.com/Woods-59017-Mechanical-Repeats-Switch/dp/B002MO3LWQ
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 03, 2011 | Woods Mechanical Inwall Timer 59017
I have a General Electric timer on my water heater. For some reason it has stopped working. How do I override the timer. It is less than a month old?
1) GE timers don't have override switch, but if you raise all the timer segments, the circuit to water heater will be completed.
2) Open link below to identify timer and see wiring diagram, and wiring instructions.
http://waterheatertimer.org/How-to-wire-GE-15207-timer.html
3) Override timer using the wires:
Take a photo of wiring so you can re-wire correctly on new timer.
There is 1 black and 1 white Line wire coming from the breaker.
And 1 black and 1 white Load wire going to water heater.
Connect black Line and Load wires together on same terminal.
Connect white Line and Load wires together on same terminal.
This will complete circuit to water heater and by-pass the timer.
4) Buy new timer at Home Depot.
Reconnect wires on new timer.
Return defective timer in new box.
Keep new timer clean, and swap out whenever needed and give yourself extended warranty.
5) This is the first report of GE timer going bad that I've seen on Fixya.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 12, 2011 | General Electric GE 56941 24-Hour Outdoor...
Installed new T104 timer 3 mos. ago. Bldg. owner says the dial "hangs up" on pins--has to use manual on/off. Wiring is correct.
1) The clock motor might be bad if trippers hang up on pins
2) The timer might be exposed to dirt dust and moisture, in which case the T-104R raintight might be better
3) The tripper pins rotate around until they contact the tripper lever >> the pins push the lever >> new Intermatic timers have a bit of white grease on the lever where trippers contact
4) Test the manual override to see if it clicks back and forth crisp and clean >> the trippers click the manual override back and forth, so if override is sluggish, then timer might be bad >>> buy new timer and swap out insides without changing box
5) Sit and watch the timer and see if trippers hang up or they skip over the tripper lever> you might need new trippers. This seems odd with a new Intermatic timer.
6) The building electricity may have gone off and the timer is not set on current time and the bldg owner doesn't know how the timer works.
Timer accessories at Grainger
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Oct 22, 2010 | Intermatic T104-20 Indoor Hot Water Timer
Estate TAWS800JQ Top Load Washer Logo
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
