Question about Dell E153FP 15" LCD Monitor
How do i replace the bulb in my dell e153fp monitor?
  • 11,361 Answers
Are you sure it is CCFL problem not the shorted out transistors or blown fuse in the inverter circuits?
LCD will have to be disassembled to get the lamp assemblies out and you need to get the raw lamps from www.lcdparts.com
, remove the old wires an resolder the wires back on to the new lamps.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Posted on Sep 01, 2010
Is There Hidden Microphone on Dell E153FP 15?
No, this is juat a basic 15" LCD monitor.
You can see the inside of the monitor here:
http://s807.photobucket.com/albums/yy352/budm/DELL/Dell%20E153FPB/
Oct 18, 2011 | Dell E153FP 15" LCD Monitor
The Dell E153FPb monitor works, but has a very dark screen. the picture is not clear at all, but i can see a small portion of it as if a bulb may be out.
Hello Breon, hi, most likely that the LCD back light is going bad, or the inverter board is giving up, or could be loose screws, this needs to be checked and diagnose.
Sep 20, 2010 | Dell E153FP 15" LCD Monitor
Dell E153FP main menu keep popping up
Main menu button on OS buttons is stuck,
Contact Dell Techncial support for repalcement Monitor
Jan 05, 2010 | Dell E153FP 15" LCD Monitor
Dell E153FP monitor won't display any video from system (Dell GX260). My e173FP monitor works fine. E153FP powers up, runs Self Test Feature Test fine, menus all seem OK. Tried Factory Reset... still no...
You probably have tried this, but make sure monitor is set to correct display... i.e., Analog or Digital
Also, try starting in safe mode and verify Monitor is able to handle the display settings resolution
I’m happy to help further over the phone at https://www.6ya.com/expert/steve_52488d61fac93877
Apr 10, 2017 | Dell E153FP 15" LCD Monitor
I'm trying to hook up the e153fp to a dell latitude lap top. What are the settings that I should use for this configuration? the e153fp doesn't like the display settings.
By going to Dell.com I was able to pull up the user guide for the E153FP and read the specs to determine that the monitor has a screen resolution of 1024x768. The previous monitor had a higher resolution and this is why the E153FP would not display correctly.
Thanks for your response to my posting.
jem
Nov 02, 2009 | Dell E153FP 15" LCD Monitor
E153fp high pitched sound when on
Sounds like the LCD or the inverter are failing. Generally cheaper to replace than to fix
Jan 21, 2009 | Dell E153FP 15" LCD Monitor
DeLL LCD Monitor
bad capacitors are most likely to blame they need to be replaced on the inside of the monitor soldering will be needed
Aug 06, 2008 | Dell E153FP 15" LCD Monitor
Dell E153FP monitor
I have a Dell E173FP LCD, my monitor don't want to stop showing his Main menu , I had the problem since 3 months and didn't get a solution for it , some time it keeps showing the main Menu without stoping ,sometime not...crazy monitor.... But i have a friend that faced same prob and toldme to open the it and see inside it if there is a detached cable or anything...just don't know how to..please tell us a soultion.
Jul 06, 2008 | Dell E153FP 15" LCD Monitor
No interaction with the Monitor
Do you see anything at all after boot up or does it stay dead Check all the connectors. Check the driver situation. Check graphics card seating if this is a card aopposed of integrated graphics for this machine. Run the recovery disk Go to Dell Tech support.
May 15, 2007 | Dell E153FP 15" LCD Monitor
Dell E153FP 15" LCD Monitor Logo
448 people viewed this question
Alun Cox
