Question about Kenmore Ovens
Kenmore built in oven only Model # 911 40499890 It will not reset and keeps beeping do I need a new circuit board?
SOURCE: oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Posted on Nov 18, 2008
Sea Breeze
  • 4654 Answers
SOURCE: New replacement thermostat needs calibrating on my Kenmore oven
There is no real way to calibrate the thermostat. Most ovens have the same problem. By lowering the setting slightly will help get a closer temperature. Sometimes similar thermostats are substituted and may not be exactly the same as the original that came with your oven. Hope my trying to answer your question was helpful, Thanks, Sea breeze
Posted on Mar 27, 2009
  • 30 Answers
SOURCE: kenmore electric built-in oven control panel beeping
Try this first!
The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. If that does not work, repalce the defective parts yourself. You can do it for about 30% of what a repair company would charge. it's either got to be 1. Control panel 2. Relay panel. Good luck!!!
Posted on Nov 08, 2009
  • 30 Answers
There is a probelm with the control panel ribbon. You can fix it for about a penny. The panel has a printed ribbon cable that plugs into the relay board. The ribbon cable is actually two cables pressed together, which can be seperated by simply lifting them apart. The ribbon cable has a defect in that the plasic insulation is defective, causing the leads between the two ribbons to cross, or short circuit. Simply place a thin sheet of paper between them, and make sure you push the paper down all of the way to the plastic housing, fold over the edges around the cable, you are done.
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Oven model 790-30179400 code F11
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 26, 2010
I can't use my oven it keeps turning off and my oven is beeping and the problem light is flashing how can I fix this so I can use my oven
Kenmore electric oven keeps shutting off.... ' Sears PartsDirect
www.searspartsdirect.com > Ask an Expert
Oct 15, 2010 - Kenmore electric oven keeps shutting off. ... Can't locate your model number? Use ... hi, i purchased and replaced my etc (#316455420) for kenmore electric range model # 790.9011.2010. i was ... How to use the site (3:58) ...
Frigidaire oven Bake functions randomly beep and shut off ...
Dec 25, 2015 | Ovens
F7 and beeping
oven starts to beep and shuts off. I shut the circuit breaker off and it re sets itself and hopefully when I power it up it will start to work. We have replaced the front panel and all th PC boards and reset the reset button behind the panel. If there was a was that I could disconnect the shut off that's built in I would keep the oven.
When this oven work, it's great however at this time i am losing patience and maybe I should toss it out and get a new oven which I really don't want to do!
I am very capable of taking it out and opening up the panel an re setting all the boards once again if that would help? Thermador has had a recall on this unit as some people claim it will overheat and go on fire? The stove has little mileage on it and we would like to keep it but if you have a way of fixing it or if not we would love to hear from you! .
Mar 20, 2011 | Thermador C302U Electric Double Oven
An error f10 comes up and the oven keeps beeping
The F10 indicates that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Mar 09, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
The electric circuit breaker kicked off and when it was reset, we are unable to get anything with the oven to work. the time comes on at 12:00 and then it starts beeping and a f 1 light appears
with kenmore F1 is a power failure in side the clock control
your whole clock will need to be replaced
go to www.appliancepartspros.com
type in your model number and look in the control section
Oct 20, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore oven keeps beeping, shows F7 on display.
HI. this is a board fault. the control, or erc/eoc must be replaced in order to correct this issue you are experience.
The Function keys on the integrated touch pad are damaged.
Sep 16, 2009 | Kenmore Ovens
My Kennmore double oven is beeping with an F7 code
There is a probelm with the control panel. You can fix it for about a penny. The panel has a printed ribbon cable that plugs into the relay board. The ribbon cable is actually two cables pressed together, which can be seperated by simply lifting them apart. The ribbon cable has a defect in that the plasic insulation is defective, causing the leads between the two ribbons to cross, or short circuit. Simply place a thin sheet of paper between them, and make sure you push the paper down all of the way to the plastic housing, fold over the edges around the cable, you are done.
Jul 28, 2009 | Kenmore Ovens
F10 error and keeps beeping
Dec 02, 2008 | Kenmore 42161 / 42169 Electric Single Oven
Oven
Aug 07, 2008 | Ovens
Kenmore electric built-in oven control panel beeping
We had the same problem. F7 error code and beeping. We turned off at the breaker- left it off for hours turned it back on and still f7 and beeping. We call repairman to come out and he removed the cover on control panel (3 screws on bottom of controll panel and it pops off). He unplugged the ribbon keypad connection - Cleaned the ends with a pencil eraser and said it is fixed and we would not have a problem.
Well, that was a fast way to spend 60 bucks but it has been a week and the oven has been great. No more beeps or error codes. SAVE YOUR MONEY DO IT YOURSELF!
Oct 08, 2007 | Ovens
Kenmore, F1
I really need to know the make and model but most F1 are a bad control board.. F1 Analog to Digital Failure Disconnect from power for 30 seconds - if display reappears - replace control board
Aug 27, 2007 | Ovens
Ovens Logo
78 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
