My ac is running but its not cooling off the house.or its just not kicking in right away..what to do?
    Genius:
  • 1,970 Answers
Mcdevito75 Here, Try this, turn the a/c off completely and un-plug from the wall outlet for 5 minutes. Plug back in the wall and just put the a/c fan on for 5 minutes, then turn the control that says cool slowly to it's coolest positon and see if the compressor will kick in, if it doesn't you may need a charge of freon, if the compressor does kick in slowly back off the cool control to where the compressor just turns off. Contact any a/c repair shop in your area they come to the house.
Posted on Sep 01, 2010
A/C cooling fans, A/C only cools when car is in motion????
Cooling fans are most likely not coming on. I believe that vehicle has two fans..side by side, one closer to passenger side is ac fan..should come on when you cut ac on. I would check coolant level some sensors will not read temp correctly unless submerged in coolant...fans should kick on when car reaches somewhere around 185 to 205....should be a plastic fuse box under hood that houses fan relay...also should be identical relays that run headlights or something else..you can swap relaysaround to see if the relay has gone bad. If fans aren't coming on or one of the two is..turn the one not coming on by hand to see if fan motor has frozen up
Sep 18, 2015 | 2005 Lexus RX330
Maytag m6x06f2a like new but doest blow cold air
Make sure the Thermostat is set correctly! The problem with mine was the temp in the house was colder than my A/C lowest thermostat setting.I had my AC temp setting on 66 degrees.The temp in the house was a little lower so the AC didnt kick on just the fan blowing cool air and no compressor working. The next day it was warmer out and the house temp was 79. So when I powered up the AC set at 66 i heard the compressor kick in and the AC worked fine.
Aug 27, 2013 | Maytag M6X06F2A Air Conditioner
After furnace shuts off fan keeps running and blows cool air for while before shuting off
Check the AFC AUTOMATIC FAN CONTROL is not blocked with fluffon the back of it , you can remove this and check the back of it .
Mar 15, 2013 | Heating & Cooling
Honeywell Thermostat RTH6350 makes heat run in AC mode after AC runs
Well, if it wasn't doing that before then you more than likely know its in your wiring. Cools down then heats back up sounds like the auto change over is on, and the heat setting is higher than the cool setting?
Mar 02, 2017 | Heating & Cooling
My ac unit comes on and then kicks off right away.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 07, 2011 | Goodman Heating & Cooling
Cool air, but no fan, electrical smell inside house
most like it the motor windings are burn and you need to replace the blower motor
Sep 27, 2009 | Ruud UBHC Air Conditioner
AC not cooling during the day
Your AC cooling efficiency is low when he ambient temperature is high and naturally it cools well when the outside temperature drops.
Please remove the filter on the grill and try to clean it under the tap water and after removing all the dust fix it back to the unit. This would increase the cooling efficiency of the unit.
Your AC is also five years old. Please avoid frequent opening of doors or windows.
Ensure that the exhaust fan and the blower of your unit are functioning normal.
The technician might not have done a proper job in fixing the area where the refrigerant would have leaked out. Please check the refrigerant pressure to ensure that no further refrigerant leak has taken place. Or even servicing your unit he would have punchered the tubes resulting in very slow leak of refrigerant resulting in no cooling or less cooling. It takes around a month to feel the pinch of it and the refrigerant. One fine morning after sometime the unit will run and it would start throwing hot air instead of cool breeze!
Jul 13, 2009 | Heating & Cooling
Weather King AC
The motor of your air mover in the inside unit has failed.
It is responsible for circulating the air through the exchanger and your home.
This may be located in an attic space depending on the construction of your house.
Running the cooling with this not working could cause your outside unit to operate continuously or fail.
A more remote possibility is that the thermostat has failed and is only causing the outside unit to run.
Aug 19, 2008 | Weather King 10AJA6001AH Air Conditioner
Heating & Cooling Logo
103 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
