File sharing While transferring large files from one PC to another, the network speed seems to drop and the process seems to take much longer than it should.
  • Anonymous Sep 05, 2008
    i want the specification of usb cable used in lap link software and where its available can any body know it pls tell
    Problem Solver:
  • 35 Answers
Limit Windows VCACHE setting to 32 Meg regardless of the
amount of RAM on the system. I suggest you download and install Cacheman (www.outertech.com). This application lets you change the VCACHE settings easily. Set maximum and minimum disk cache to 32768 and CHUNKSIZE to 512.
Also, I got off the phone with the upper level tech of Microsoft and my problem with FA310 is that mine are C1 or C2 hardware versions which are NDIS (Network Driver Interface Specification) 3. WinME needs NDIS 4 and "prefers" NDIS 5. To see what NDIS your network card is go to regedit LOCAL MACHINE>System>Current Control Set>Services>Class>Net>0000>Ndi>Interfaces
You can see if your network card is on the Hardware Compatibility List that Microsoft certifies at: http://www.microsoft.com/hcl/default.asp
Posted on May 10, 2008
Just got new HP laptop and i'd like to transfer photo's and some files from my old HP desk top computer. What do I need to do this?
If the old computer still works, see the following. Otherwise look for the * for a solution further below. If the old desktop has Windows XP SP3 or newer, you can use the easy transfer wizard. It is included in Windows 7.
If the old desktop has a network connection, you can use an ethernet switch to create a network to share files. Once both computers recognize the switch, set up a network. If you have Windows 7 on one computer and do not have it on the other, do not use the Homegroup network. This may come up automatically; otherwise, use the Network Control Panel and add a network. Start the Easy Transfer Wizard and set this computer as the new computer. There may be an option to get the Transfer Wizard to copy and install to the old computer. Note the code for the Easy Transfer Wizard. Then install the Windows Easy Transfer Wizard on the old computer and launch it. Set this computer as the old computer. Use the code given in on the first computer to synch the transfer. Go through the settings to select the files to transfer and then start the transfer. Prepare to wait a while for the transfer.
If you can't use the Easy Transfer Wizard, set the hard drive on one computer to Share (click Computer (My Computer) and right click on the hard drive and select Properties. Then choose the Sharing tab. Enable Sharing by clicking the Share button.) On the other computer, map to a network drive and locate the Shared drive. Drag and drop the files to the new computer.
If you already have a network connection to a cable or DSL router, you will be asked about "New network found" and to define it. Make sure to make it the home network on both computers. (If you were directly connected to a cable or DSL modem, then you will again get this question. Note the switch will not let your computers talk to the outside network without a router though.)
(Alternatively, use a cross-over ethernet cable with the direct cable networking option.)
Other options: use the Microsoft Easy Transfer Wizard to put the photos and files on a DVD, external hard drive or flash drive with sufficient capacity. You may need to download and install this program to the old computer. For the optical drive option, you need a DVD-RW drive on the desktop and a DVD reader (minimum) on the laptop. (You can use an external optical drive, if you have one.) Another option is a USB file transfer device. Some of these come with the Easy Transfer Wizard on their install disc.
*If the old computer will not turn on, take the hard drive out of the computer and use a USB to IDE/SATA adapter. Follow the directions for the device and attach it to a USB port on the laptop. See if the drive mounts (is listed when you open the Computer File Explorer). Then drag and drop the files from one drive to another.
Note you may need to change the owner of the files on the new computer. (This doesn't apply with the Easy Transfer Wizard if the old user is made equivalent to the new user in the setup of the wizard.) To change the owner, right click on the file in the File Explorer and choose the Security tab. Select the Advanced settings.
I hope this helps.
Jun 30, 2012 | detto intellimover usb data migration kit...
Tip
Have you ever had any music, video, photo, or document files you wished you...
Have you ever had any music, video, photo, or document files you wished you could share easily between the various computers in your native Mac OS X network with ease? How about if you could share files just the same with a mixed network consisting of Macs and PCs? Or vise-versa?
Well now, there is a simple tool you can use, where you don't have to look so far or spend enormous amounts of time and energy, setting up complex file sharing infrastructure within your network. Well.. I mean you can if you want to...
But if you like, me, with a mixed network of Macs and PCs I could do that, but I don't really want to contribute that time unnecessarily.
That is how I found Dropbox.
Dropbox, is an online backup and file syncing service, that is quite easy to setup on any computer or laptop you have, Mac, PC, Linux, or even the iPhone. Once you have downloaded and installed it on your computers, literally in less than 5 minutes for each computer, you will be sharing files in no time.
So how do you get started in Dropbox?
It is an extremely simple 4-step process.
1.) Go to the website and you will immediately be greeted, with a landing page, that automatically shouts "Download Me Now!" to you.
Download Link: http://www.dropbox.com
Once you visit the home page, this is what you will see:
2.) Download Dropbox
3.) Install Dropbox
4.) Start dragging files, folders and applications into Dropbox
It is as simple as that!
Once Dropbox is installed on your Mac or PC, just look on the Apple menu bar (for Mac) or the System Tray (for Windows) and you will see a small distinctive little box which looks like this:
But that little box, leads to ways of being able to do big things for file sharing and even backing up some key files or folders from your Mac. Very easy to open and access...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This window, all you will need to access and use your Dropbox:
To get a Dropbox account, all you need is an email account to setup Dropbox on your computer or laptop.
You are even able to setup a free 2 Gig account and if you feel you will need more space, because you enjoy using dropbox more than you realized, you can upgrade to the monthly Pro 50 (50 Gigs of space) or Pro 100 (100 Gigs of space) Dropbox plans, for low prices ranging from $9.99 to $19.99 a month respectively.
For now however, just to get a feel of this great online backup and file syncing service, try the free 2 Gig plan and see for yourself, why I am recommending this service as a great solution to your file sharing woes between your computers within your network.
Since using this sharing application, I have not had any issues with sharing files, folders or applications of any kind with any of my computers with Dropbox installed.
Real case and point:
At anytime, if I want to drop a movie into my daughter's Dropbox on her Power Mac from my iMac, I simply drop the movie into my Dropbox folder and let her know. She then checks her Dropbox and in moments, she has her movie to now watch at her leisure.
NOW HOW SEAMLESS IS THAT?
Dropbox is simple to use and surprisingly fast in transferring files.
Of course the file transfer from Dropbox is contingent upon the power and RAM capacity of your Mac(s) or PC(s) as well as your network bandwidth and connection speeds, but once you experience Dropbox and its file sharing efficiency for yourself, you will get the full picture.
I hope this Mac OS X File Share tip from Fixya support will prove beneficial to you. However, if you don't try Dropbox, how will you know what it can do to enhance your general file sharing experiences positively?
Thanks for reviewing this Mac Fixya Tip!
Regards,
on Apr 07, 2010 | Computers & Internet
Tip
Sharing Cross Systems with Drop Box
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} But if you have a native Mac network or even a mixed network of Macs and PCs, why expend that extra time, especially when you can start sharing files in moments with the right utility?
3.) Install Dropbox
This, all you need to access and use your Dropbox.
To get a drop box account, all you need is an email account to setup the Dropbox on your computer or laptop.
You are even able to setup a free 2 Gig Dropbox account and if you feel you will need more, because you enjoy using Dropbox more than you realized, you can upgrade to the monthly Pro 50 (50 Gigs of space) or Pro 100 (100 Gigs of space) Dropbox plans, for low prices ranging from $9.99 to $19.99 a month respectively.
Since using Dropbox, I have not had any issues with being able to share files, folders or applications of any kind with any of my computers with Dropbox installed.
At anytime, if I want to drop a movie into my daughter's Dropbox on her Power Mac from my iMac, I simply drop the movie into my Dropbox folder and let her know. She then checks her dropbox and in moments, she has her movie to now watch at her leisure.
Dropbox is smooth and surprisingly fast.
Of course the file transfer from Dropbox is contingent upon the power and RAM capacity of your Mac(s) or PC(s) as well as your network bandwidth and connection speeds, but once you experience Dropbox and its files sharing efficiency for yourself, you will get the full picture.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I hope this Mac OS X File Share tip will prove beneficial to you. Keep in mind: if you don't try Dropbox, how will you know what this cool web-based application can do, to enhance your general file sharing experiences with your networked computers?
Regards,
on Mar 17, 2010 | Computers & Internet
Getting large files off mac for use on pc
Here are three ways:
1. If on the same network, create a smb share on the macintosh, map the share on the windows system.
2. Format a usb drive on the macintosh using disk utility as a FAT partition. Copy the files to it. Dismount the drive. Mount the drive on the windows machine.
3. If both have access to the Internet, crete a free 2GB DropBox account. Drop the files in the dropbox and it will be copied to the dropbox on the windows pc.
May 24, 2011 | Apple Macintosh Server G4
Purchased a gigaware cat5e crossover network cable to transfer files from one older computer to a new one. Cant get it to tranfer info.
So that you will be able to transfer your file from one PC to the other you have to share your folder first.
1. Share your folder in your old computer. Right click the folder then click Properties and Choose Sharing Tab. Check Share this folder (For windows 7 or vista you have to click Advance sharing button first) 2. Open your explorer from the other computer and Choose Network. Now, you should see the shared folder where your files are. Then start copying the files to your new computer.
*Note: you can also delete the files from the other computer by setting permission of the folder properties.
regards
Apr 02, 2011 | Computers & Internet
Tip
Speed up viewing shared files across networks
Speed up viewing shared files across a network
Windows 2000 & XP machines delay as long as 30 seconds when you try to view shared files across a network because Windows is using the extra time to search the remote computer for any Scheduled Tasks. Here's how to prevent this remote search for Scheduled Tasks:
Open up the Registry and go to :
HKEY_LOCAL_MACHINE/Software/Microsoft/Windows/CurrentVersion/Explorer/RemoteComputer/NameSpace
Under that branch, select the key :
{D6277990-4C6A-11CF-8D87-00AA0060F5BF}
and delete it.
If you like you may want to export the exact branch so that you can restore the key if necessary. This fix is so effective that it doesn't require a reboot and you can almost immediately determine yourself how much it speeds up your browsing processes.
on Dec 01, 2009 | Computers & Internet
How to transfer FROM Vista TO XP?
Are both PC connected to a network and running? Enable file and folder sharing and drag and drop.
Do this on both:
CLick Start, Settings, Network Commections and Double click your NIC. Then choose properties and click box next to File and Folder sharing.
Now goto my computer, Rt click the drives you want to share, click sharing and fill in the blanks.
Now go to either machine, open a browser and type:
\\IP address of other machine\c$ and hit enter
Like this: \\123.45.6.78\c$
Give Login and PW if it asks
Drag and Drop or Copy all you want.
Done!
Mar 26, 2009 | Western Digital My Book Essential Edition...
I can't seem to get my 2 pc to share files
Hey Capb, sounds like this "modem" is set up differently from the old one in that it is separating the wired and wireless network traffic. If you are a little technical, you might check the IP addresses of both devices and see if they are on the same networks segment.. like 192.168.1.100 and 192.168.1.101 or some such.
Apr 21, 2017 | 2wire 2700HG-B Router (2700HGB)
My pictures transfer to the computer too slowly.
If you are transferring Tiff files or video clips, you can expect the transfer to take much longer than it does for JPEG files, due to large file sizes. If your system has less than 32MB RAM, the transfer speed may be slower.
Sep 12, 2005 | Epson PhotoPC 3100Z Digital Camera
If you are transferring Tiff files or video clips, you can expect the transfer to take much longer than it does for JPEG files, due to large file sizes. The transfer speed is especially slow when you are using a serial connection. If your system has less than 32MB RAM, the transfer speed may be slow. Try using virtual memory. See your computer documentation or system help for more information. Check the port setting in your Windows Control Panel. You may need to set your port to a faster speed. See your Windows documentation or help system for more information. If you're transferring pictures to an application through EPSON Photo!3 and you use the PhotoEnhance(tm) feature, the transfer will take longer. Try transferring without PhotoEnhance.
Sep 12, 2005 | Epson PhotoPC 3000Z Digital Camera
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
