Question about Amana Heating & Cooling
The air does not come on at all but the fan will work.
  • Patrick Worley
    Patrick Worley Sep 01, 2010
    For verification when you say the fan comes on but the air does not.. This mean that the fan comes on and circulates air just fine but the air would never get cool ? Is this a window unit ?
    Genius:
  • 1,970 Answers
Mcdevito75 Here, You may need a charge of freon, turn the a/c unit off completely and remove plug from wall for about 5 minutes, then plug back into wall, now just put the fan on for 5 minutes, now the cool control, tiur that slowly to it"s coolest point and ss if compressor comes on, if so back off the cool control slowly just until the compressor goes off, if compressor doesn"t come on, contact a local a/c repair shop in your area. They come to the house.
Posted on Sep 01, 2010
Lasko fan wont blow air
Sounds like the fan motor is the problem
Aug 31, 2016 | Lasko 48" Xtra Air Tower Fan with Air...
Radiator cooling fan, air con & central locking not working
Search Results
    newrremedies - Range Rovers
    www.rangerovers.net/newrremedies.html
    Feb 1, 2012 - Shop Manual: To diagnose and cure problems on the 4.0/4.6 it is almost... When the air conditioning failed during a summer off-pavement expedition in the..... the security/central locking portion of the service manual describes a process .... I asked the dealer to check the radiator and the viscous fan clutch.
    Air Conditioner Fan Not Working - Repair Parts ...
    www.repairclinic.com/RepairHelp/...Air-Conditioner/...---/Air-conditione...
    Heating & Cooling ..... Most Frequent Causes for Air conditioner fan not working ... On one side, the fan blade draws in outside air over the condensing coil to ..
Jan 13, 2016 | Cars & Trucks
First time starting a/c this season, display is lit but no air is blowing. Fan outside is on. Batteries changed, still no air. System is only @ 2 years old. Stat model - TH3110D1008. Thanks.
Set the thermostat FAN setting to FAN ON to verify the fan working.
If it works in the FAN ON position the fan motor is OK and you have a bad fan relay.
If it does not work you should check the fan motor capacitor.
At 2 years old the unit is still under warranty for parts.
Apr 26, 2011 | Honeywell Heating & Cooling
I have a Jenn Air refrigerator JFC2087HRS. The freezer compartment is working, but the fride is not working.
check the inside fan if no air blowing in to fridge fan may be frozen/blocked on need repair/replacement if fan working damper in fan duct may be closed or blocked
Oct 14, 2009 | Jenn-Air Refrigerators
Fan is keeps jamming on out side unit machine runs but no cold air comes out
If the outside fan doesn't work , the compressor will shut off on overload and you won't get any cold air , so try to replace the fan capacitor and if still doesn't work , you have to change the fan motor.
Oct 11, 2009 | Carrier BCA101R Air Conditioner
Air handler turbine fan does not come on
A bad fan relay is not sending high voltage to the fan. A defective thermostat not sending low voltage to the fan relay.
How did you check the fan to say that it works?
Sep 25, 2009 | Ruud UBHC Air Conditioner
Air cinditioning blowing from cold to hot air
need to check ac fan or fans ,are they working? if not check fuses and fan relays,,,,,and fans (hot wire the fan to see if it/they work
Jul 05, 2009 | 2000 Acura TL
Air handler fan not working
Check the fan relay switch in the air handler.
Check the fan motor capacitor.
Check the fan blower wheel for binding.
May 25, 2009 | Heating & Cooling
Fan doesn't work
(BACK TRACK FROM THE FAN VOLTAGES BACK........)
May 25, 2008 | Goodman PHKJ048-1 Air Conditioner
"high" vs "low" dual control
could be problem with either switch of fan. try continuity across both legs of the switch then try continuity across the fan windings.
May 25, 2007 | Fedders X Chassis A3X05F2B Air Conditioner
Heating & Cooling Logo
67 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
