My 64 inch phillps tv colors are bad so i took the back of the tv off to fix the the colors and now its worse i cannt get it to look right,should i call some one to fix it??
  • 3 more comments
  • shavaisaw Sep 01, 2010
    the model number is 64p8342
    i can still watch the tv but it looks like fog a little to,can i adjust the colors from in side the tv my self,or does that makes it worse?
    and how much will it cost if it is the convergence output chips?
    hey are u still there?
    the color on my tv wasnt looking right so i took the back of it off to fix the color inside but made it worse,its a little fog looking now,then it took a while to turn on,but i can still watch it but the picture doesnt look right still.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The issue is with the failed convergence (STK) ICs which needs tobe replaced. It’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs(STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime. Please check this picture:
There are repair kits available which includes repair instructions with the parts, if you want to do it yourself, you can buy and repair it yourself. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 01, 2010
  • 10,594 Answers
What is model number of your Philips tv? I assume it is rear projection tv that has 3 picture tubes inside to project picture on front screen and colors gone bad due to convergence output chips failure that needs to be replaced by qualified tv repairman, local tv repair shop will help you to get tv fixed.
Thanks.
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Sep 01, 2010
    Yes, I'm here,
    If tv picture is just out of focus then clean its lenses, projection mirror that will improve picture quality.
    and if tv shows 3D type picture then it is convergence output chips failure problem and repair will cost you $250 or so
    Can you post tv screen image here to understand picture problem?
    Support via email takes little time so patience is required to exchange emails.
    Thanks.
Tv picture shift leaving one inch of white vertical stripe on left side. Any suggestions as to repairing?
there is not really a "fix" for that besides buying and installing a new lcd panel. you have bad pixels. unless someone took the tv apart before this happend. then its probably a plug not inserted in all the way for the lcd
Feb 18, 2016 | Samsung PN64F8500 64" Plasma 1080p 3D HDTV...
JVC HD 56FN97 No RED color
Does menu have any red? Yes = digital video bad; No is light engine bad.
Mar 31, 2014 | JVC Hd56fn97 56-inch 1080p Hdila Rear...
We have a 60 inch philips tv that started to have problem with overexposed color (blue) i thought that i could fix this, i moved the lenses a bit rendomly,that did help a little, but then i touched the...
Thats the screen controls. To adjust it turn the color level down to zero, Then adjust the 3 knobs by balancing them to where the best black and white picture is acheived. Then turn the color level up and that should do it. Just be careful not to turn the settings too low or the CRTs will refuse to light after the set gets turned off. If that happens you will need to turn each adjustment up a little and the CRTs will relight then you will need to adjust it more. If you cannt get a good black and white picture you will need to replace the Coolant in the CRts.
Nov 24, 2009 | Philips 60PP9202 60" Rear Projection...
My 51 inch Magnavox rear projection has red and green overlapping
the coolant is bad inside the blue and green pix tubes-to verrify this you can remove the front edge of the screen(it pulls off-one edge at a time-take out screws to remove screen-after screen is off look down at blue/green tubes pix is bad or not there
Sep 07, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Phillips Magnavox 60 inch Projection Tv
That model is famous for having bacterial contamination in the CRT coolant causeing halos, and dim pictures with bad overall color issues. You can look into the lens of the CRTs when the set is laying and if the coolant looks cloudy or has any growth there you will notice it right away, and changing the coolant will restore color, clarity and brightness.
Jun 15, 2008 | Philips Magnavox 9P6034C 60" Rear...
Fix the color on my tv
sir/maam kindly adjust its screen focus of your tv,,,,thankss and hopetohelp you,,,gud luck!!
Feb 27, 2008 | Philips 20PT6441 20" TV
Red colored halo at bottom corners of screen
Movement of any TV can result in a problem caused by bad
solder connections.In your case, the red convergence IC......
Found on a circuit board,mounted on large heatsinks........
Part # STK392-040.....Change both for prevent maintenance.
Do not use generics - I use OEM or better = Sam,Pan,Hitachi.
After repair,recheck alignment................T.
Nov 20, 2007 | Samsung PCJ533R 53" Rear Projection...
Right 2 inches on edge of screen are darker than the rest of the screen
What is the model of the TV? Samsung DLP TV's start with HLS,HLP,HLW.....
Feb 06, 2007 | Samsung TX-R3080WH 30" TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
