Question about Broderbund ClickArt® 750,000 Full Version for PC
Good afternoon, I have upgraded my system to Vista. Do I have to buy a new version of clickart 750,000 so it will work on my computer?
  • 51 Answers
Yes, Software compatible with Windows Xp are 75% incompatible with Vista/ Window 7.
Posted on Sep 01, 2010
Clickart 400,000 compliancy
Right-click on the program shortcut =>
Run as Administrator =>
Input your Admin credentials if you have set any!
Done!
Feb 04, 2018 | Broderbund ClickArt 400,000 (385489) for...
Tip
Windows Installation Disc VS Windows Upgrade Disc -NOT THE SAME-
Having Trouble Booting To Your Windows Upgrade Disc?
...Upgrade discs aren't bootable discs. To repair a windows installation, you must use either a system repair disc or, better yet, a windows installation disc (genuine Retail/OEM discs are pretty much your only option to completely reinstall your windows operating system, unless you own a previous full installation disc of a previously released Windows version (such as XP or Vista), in which case you could install that windows operating system and then upgrade to a newer windows OS like windows 7. however if you ever need to reinstall windows 7, you would either need to reinstall the older windows OS, then upgrade to the newer one.
If that isn't clear, I'll sum it up....
Let's say you bought a computer, that computer had windows xp home edition. Maybe you wanted to upgrade from Windows XP/Windows Vista or Windows 7?
Well in order to switch from Windows XP/Vista to Windows 7, (or even from Windows 7 home premium- to windows7 Pro or Ultimate), then you must either:
A) Buy an upgrade disc and upgrade to the newer desired version.
B) Or, Buy a Retail Copy of the version you want to install. (keep in mind that a retail Windows 7 disc can be used to perform an upgrade rather than to competely wipe the hard disc and perform a clean install (delete partitions, reformat, and perform a new windows installation), if you so choose.
The bottom line is, you cannot Install a fresh clean copy of windows using an upgrade disc. OEM (Original Equipment Manufacturer) and Retail Windows Operation System Installation Setup Discs are "Bootable Discs". Windows Upgrade Discs are NOT bootable. (unless one where to "modify that particular disc, which is not legal).
on Jul 06, 2010 | Computers & Internet
I have HP 7700 system,with Vista Operating System. It had issue which resulted to me formating it. Now I cant activate it even online. I keep reinstalling the Vista OS every 30 days. Pls how can I freeze...
Vista sucks anyway, and anything that can run Vista should be able to run Windows 7. This is a blessing in disguise. Buy Windows 7 Home Premium Upgrade and install it.You legally qualify for the upgrade version if your computer came with Vista. You can use instructions here to make the upgrade version work on a clean disk:http://windowssecrets.com/top-story/clean-install-windows-7-from-the-upgrade-disc/
Jan 27, 2012 | HP Computers & Internet
Dosn't work with windows 7
Broderbund's ClickArt 200,000 Image Pak should install quite easily on a 32-bit version of Windows 7.
64-bit version of Windows 7:
It is not possible to install ClickArt 200,000 Image Pak on a 64-bit version of Windows 7 - because the Setup.exe file is not compatible with any 64-bit Operating System. That is due to the fact that the Setup. exe file contains 16-programming code. 64-bit Operating Systems cannot handle any 16-bit programming code.
Hope this answers your query. Cheers!
May 03, 2011 | Broderbund Clickart 200,000 Image Pack for...
Upgrade to windows 7
i dont think so but with some new computers you'll get windows vista + upgrade to windows 7. so only when you are buying a new computer.
Not when you'll buy vista and then get windows 7
srry for my bad english
Aug 26, 2009 | Microsoft Windows Vista Home Premium...
Contact Broderbund for support This problem was caused by a compatibility issue between this version of Windows and this version of PrintShop Deluxe. This program was created by Broderbund. Recommendation...
I used a 14 disk ClickArt 200,000 edition with my older computer. Now I have a new Windows 7 Computer. Is not this 2000,000 edition compatible with my new Computer.?
Feb 19, 2009 | Broderbund The Print Shop 20 Deluxe for PC
Upgrading the OS Windows XP not possible
Upgrading from OS Windows XP:
you can upgrade from Windows XP to Windows Vista(ultimate, premium, home, business.......),
you have to buy a Windows Vista CD and install a fresh copy or format.
Some Minimum Requirements:
i) Min 2GB RAM or atleast 1GB RAM(if you have>1GB RAM installation of Windows Vista will not continue)
II) External Graphic Card. for some versions of Windows Vista(to run Aero Interface, special feature only   in some versions of Windows Vista)
NOTE:
"Windows Vista Upgrade Advisor" is a software from Microsoft which you can download from internet, this  can help you determine which features and edition of Windows Vista will run on your computer.
 i.e., when u load this software on windows xp it will suggest which upgrade version of windows vista          will suit your system(based on you system configuration. or hardware components.) and then            you can install the upgraded version of windows xp(mostly windows vista home,.........)
Thanking You
M. Sridhar
Dec 26, 2008 | Computers & Internet
Sftware
Hi, Unfortunately any of Bernina's software that is older than Version 5 , will not work with Vista. There are some software patches available on the berninausa.com web site, but there is nothing out there that will help you if you have any Version 4 software or older. Microsoft really through out a curve ball to everyone with VISTA as there is a lot of software out there that will not work in that operating system.
Actually the lowest cost solution would be to get a nice used computer that runs Windows XP. You do not need a super fast, state of the art computer to run embroidery programs.
I bought a nice used computer at a yard sale for $10.00 and it even came with the XP install disk. I replaced the hard drive just because they do wear out after a few years, installed XP in it and that computer is now in my wife's sewing room and it is only used for her embroidery work.
You might have a computer repair shop in your area where you can buy an older XP computer that has been reconditioned. The few dollars you would spend to get an older computer would cost you far less than buying new Bernina Version 5 software. It is EXPENSIVE! Good luck...bushvideo
Sep 11, 2008 | Bernina Artista 180
Windows vista ultimate problems
It needs Microsoft office Key,
If your Office is not geniune you can get the key at:
http://www.seriall.com
If it was a demo disk, then why did you install it on your full version of windows???
Please rate if satisfied!
Dec 17, 2007 | Microsoft Windows Vista Ultimate Edition
Broderbund ClickArt® 750,000 Full Version for PC  Logo
70 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
