Question about Health & Beauty
We have a Pride jet 2 power chair. Been in storage for three years installed new batteries. Now when you try to operate the chair the control box just clicks and then all lights flash four times. With a pause in between. Can you help? Thanks.
  • 692 Answers
Yes you are getting a flash code error indicating a right motor fault. Unfortunately the only fix is to replace the motor. Wish I could give you an easy fix. Hope this helps you
Posted on Sep 02, 2010
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
New batteries new battery harness still 3 red bars and two yellow bars flashing what else could it be
[PDF]Pride Jet 2 Hd Owner's Manual - Scootaround
www.scootaround.com/.../manuals/pridemobility/Pride%20Jet%202%20...
The symbols below are used throughout this owner's manual and on the power chair to identify ... Jet 2 HD www.pridemobility.com. 3. TABLE OF CONTENTS.
Sep 28, 2015 | Jet 2 HD for 350 lbs, Power Chair,...
How to reset manual brake control and where is it.lights go on( 2 red & 2 green) but jet joy stick is so touchy lights blink and I have to restart it.
If the joystick turns completely off when you try to drive it means the batteries instantly are dropping voltage below the operating capabilities. I have also seen bad connections in the battery wiring harness cause the same thing.
Sep 15, 2014 | Pride Mobility Products New Pride Mobility...
What is the fix for Pride power chair code 3101 bridge voltage fault?
The fix for this fault is to replace the chip in the VSI controller. This happens when you consistently drive the power chair with weak or low voltage batteries.
Sep 02, 2014 | Pride Mobility Products New Pride Mobility...
Shoprider power chair won't move and 8 Battery LED Lights are flashing
Code 8: Controller problem. Also, check to see if your gearbox levers are engaged - if you can roll the chair by hand the gearbox is not engaging the motors.
Mar 20, 2013 | Pride Mobility Products New Pride Mobility...
Lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
Mar 27, 2009 | Pride Mobility Products New Pride Mobility...
Batteries run low fast on jazzy jet 3, heard brakes might be failing or motor needs replaced after replacing batteries?
one battery was low,,,,not sure if anyting else is bad, used chair...by having only one battery low, it ran down the chair...
Health & Beauty Logo
131 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
