Question about Oster 12-Bottle Wine Cellar - Black
I have an 8-bottle wine cellar, model OW0809H6H, bought about 3 years ago. It quit cooling properly about 8 months after purchase and couldn't find the sales receipt, so didn't do anything about the problem. The adjustments on the door work fine, but immediately revert to a temp of about 64 degrees. I have done everything that's suggested in the user's manual to correct it, to no avail. What can I do?
SOURCE: K-Mart Homemaker brand, 40 bottle wine cooler fridge
Are you sure you want frozen champagne? Or do you mean 7 degree C (not minus 7).
Posted on Jul 04, 2008
  • 19 Answers
SOURCE: Avanti WC492D wine cooler temperature control does not work
the wine cooler has to be at least 3" away from the wall, do not block the air flow to the condenser. or check power plug to outlet is it secure.
Posted on Feb 21, 2009
  • 10865 Answers
SOURCE: Wine Cooler Does NOT get cool.
Here is the web site to locate your closest oster service center. They should be able to tell you what their charge will be up front so that you can compare that charge to the cost of a new one.
Now days, sadly, many of these items are too costly to repair so they go to the landfill..
http://www.oster.com/CustService.aspx?content=center
Posted on May 21, 2009
  • 905 Answers
SOURCE: Wine Enthusiast 16-bottle thermoelectric wine refrigerator DEAD
usually bad power supply, if the cooling fan isn't running either. These are horribly inefficient coolers that use a lot of power to accomplish little cooling. The power supplies are quite notorious to burn up.
If your supply is 12vdc output, you might be able to replace it with a supply from radio shack. dont use a battery charger though.
Posted on Nov 02, 2009
SOURCE: Haier wine cellar HVTS18DABB top zone won't cool.
Maybe not the answer for everyone, but I proved it was the fan by removing the back panel, removing the fan and finger guard, then placing a small desktop fan that was the same size as the top-rear fan on the wine fridge. Pumping air directly over the heat sink allowed the unit to attain the temperature set on the front panel. The old fan would either not turn at all, or too slowly to be effective. These fans are junk. Especially after finding articles such as this out in different forums for the same issue. I have the HVTS18DABB model unit and the replacement fan is a simple 120mm square, 25mm deep 12V DC fan. Similar or the same as you see in computer chassis. Found some inexpensive, high CFM, low noise fans from the following site:
http://www.sidewindercomputers.com
Specific fan for my application was the model SY1225SL12SH. Although I did order a second fan that is similar in case the .5amps was too high and I popped a fuse. These fans are inexpensive folks, as long as you aren't afraid to get your hands dirty. Good luck.
http://www.sidewindercomputers.com/sc12slsy110c.html
Here are the details on my order:
Name Code Qty Each Options
Yate Loon 120x25mm D12SH-12 1 5.99
D12SH-12 High Speed -
Black (88 CFM, 40 dBA)
Scythe 120x25mm SY1225SL12SH 1 7.95 Add Black Sleeving = No
SlipStream SY1225SL12SH -
110 CFM
Subtotal 13.94
Shipping 7.02
Tax 0.00
Posted on Aug 16, 2010
Beeping will not stop on wine cooler - red wine side
Beeping usually indicates that something has gone wrong. Probably not cooling properly. The water coming out would indicate that the unit has defrosted. Turn the unit back on again and see if the red side is cooling properly. Some wine fridges have independent evaporators which allows different cooling temps in different parts of the cabinet.
Jun 26, 2014 | Danby DWC2727BLS Silhouette 54-Bottle...
Not colling
Check the back to see if the compressor is running or just really hot. If it is not running it could be a thermostat issue, but if it is hot and not running, that means your compressor has problems and will need to be replaced.
Apr 07, 2014 | Whirlpool 22" Dual Zone 38 Bottle Wine...
I need the Haier 18 bottle wine cooler instruction manual.
Hi There,
I was able to find two 18 bottle wine coolers on the Haier site.
The first is model number HVTM18DABB
http://www.haieramerica.com/wine-beer-beverage/wine-cellars/hvtm18dabb
The second is model number HVTSM18DABB
http://www.haieramerica.com/wine-beer-beverage/wine-cellars/hvtsm18dabb
On either product page the manual can be downloaded from the "product support & downloads" tab
Have a great day!
Jul 18, 2012 | Refrigerators
My wine cellar (Model: ow0912H6H) still runs but it does not cool. What can I do? I don't believe that there is a compresser in ot. I don't know what cools it.
I had the same problem and noticed that the lint screen behind the cooler was full of lint where it was almost completely clogged. I vacummed it and it seems to have done the trick.
Feb 19, 2010 | Oster 12-Bottle Wine Cellar - Black
May 21, 2009 | Oster 12-Bottle Wine Cellar - Black
Oster 12 bottle wine frig, how to set temp instructions please
I suggest you return that puppy as fast as you can.
The company that makes them took bankruptcy and warranties are no good.
To top it off the fans usually **** out in 6 mos or so.
May 15, 2009 | Oster 12-Bottle Wine Cellar - Black
Kitchenaid Wine Cellar-model # KUWS2246EBLO Power on switch does not turn on cooling compressor. Lite will come on.
Try tapping on the thermostat it is probably sticking.
If it comes on then you will need to replace the thermostat.
Check the start relay on the compressor.
Check the fan motor on the compressor is it running?
Clean lint from underneath on the condensing coil.
Mar 26, 2009 | KitchenAid 48-bottle Wine Cellar
Broken door...
Buy a dented unit on eBay and take off the hinges
May 12, 2008 | Oster 12-Bottle Wine Cellar - Black
Oster 12-Bottle Wine Cellar - Black Logo
348 people viewed this question
Top Oster Furniture Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
jasbo
jasbo
james laughton
james laughton
Are you an Oster Furniture Expert? Answer questions, earn points and help others
