Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
42" 15 hp craftsmen mower dies when let clutch peddle out
  • 252 Answers
Have you tried fitting a bypass wire to seat switch and retest then try disconnecting it completely and retest
if that does not work check that the blade engage switch is not stuck down.
check that catcher switch is not open if this nodel uses a catcher ?
have a look ?
cheers
Posted on Sep 03, 2010
What causes my 13.5 hp craftsman model #917270412 engine to die when i release the clutch
My question would be what caused the belt to break. Have you checked under the mower deck to make sure the blades turn freely? Could be that something is jamming them and causing the motor to die. Or even a blade that hit something hard might be bent against the top of mower deck.
May 07, 2014 | Garden
I have a craftsmen. Went out to mow and the battery was dead. Recharged it and then when i went to let off brake/ clutch it started to die. This also happened when trying to engage the blade. I check...
Just to help you with your troubleshooting:
You can get off the seat with the engine running if the blades are not engaged and the brake is on.
I also think that you can start the mower without being in the seat, but I'm not sure about that.
First, see if you can jump the seat switch.
Second, I think the discharged battery is a different issue.
Gary
Sep 13, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
On the clutch and brake peddle the clutch engadges at the very end of the peddle. The brake is working fine but as you let the peddle out on the last 1/16 of an inch the drive engades. this makes it where...
If you replaced the belt then you know there is a tensioner/guide pulley and another pulley which goes in and out with the clutch pedal movement to take slack out of the belt. I would closely examine both of those as well as the linkage and return spring on the clutch pedal.
Aug 05, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Blades don't engage
Check the drive belt for the blades
Jul 22, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Motor dies when engaging the cutting blades
I need help with this exact same problem. Someone please answer this question.
May 22, 2009 | Craftsman Garden
Need diagram for drive belt on a craftsmen ys
Get your model # from under the seat (should start with 917) and go to this site.. http://www.searspartsdirect.com/partsdirect/index.action Then, enter your model #, click on search, scroll down to Subcomponent list to Mower Deck and there ya are. You'll probably have to click on 'zoom in' in the top left corner. Hope that's what you were looking for
May 17, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Need to replace a clutch cable
i need a picture or explanation, how does the clutch spring attach
Apr 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Engine dies when clutch is released or PTO is engaged
flop the seat forward, locate the seat switch in the middle of the seat, push the connector onto the seat switch firmly, start it up and drive away
Mar 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
125 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
