Question about Bissell 1770 Quicksteamer II Upright Vacuum
Bissell 1970 quicksteamer water runs out of clean water tank
  • 276 Answers
Try re-installing the handle. Remove the screw on the back of the machine and pull up on the handle. Once the handle is removed pull the trigger to make sure the plugger on the end of the handle moves up and down when the trigger is pulled. If the plunger is moving reinstall handle and test. If the plunger is not moving you may need a new handle.
Posted on Sep 15, 2010
    New Friend:
    Problem Solver:
  • 7 Answers
I had clean solution dripping onto the floor from the wheels of the unit. I had to disassemble it to find the problem which turned out to be a leaky seam on the edge of the black plastic valve assembly. This is the part that the solution tank plugs into. It appears the glue holding the valve together let go. I sealed it with 'Seal-All' sealant and that resolved the problem.
Posted on May 30, 2013
  • Roger May 30, 2013
    Here is a photo of the valve with the seam that leaked pointed to by the pen.
  • Rose Kemper
    Rose Kemper Nov 09, 2015
    This may be my problem too. Thank you I will be checking that.
Water leaking from somewhere on my bissel quicksteamer model #1970
This is not an easy one for us to offer advice on because we cannot see it. There are a lot of places that can leak water and there are a lot of parts that can wear out. You need to check the hoses and connections on all the tanks and spray bars. At least you can get parts for it now: http://www.vacsite.com/en/bissell-parts-1/bissell-parts/1970-quicksteamer.html
Apr 22, 2016 | Vacuums
How can I clean or open the bissell quicksteamer dirty tank
Hi Deni! The collection tank can not be opened for cleaning. You may want to fill the tank with some hot tap water and let it sit for about 30 miutes.
Here's a link to our website if you decide to order a new tank.
http://www.bissell.com/parts/?id=9143&sc=part&partid=4482&cid=ccsocial
Jan 16, 2013 | Bissell 1770 Quicksteamer II Upright...
What's your problem? how to replace nozzel for bissell quicksteamer
The User Guide for your Bissell 1770 QuickSteamer can be found here:
http://canada.bissell.com/images/UserGuides/1970-2080_English.pdf
Available replacement parts may be ordered online here:
http://canada.bissell.com/Products/p/1770+quicksteamer/ak/replacementparts/Product.aspx
Was not sure if you meant you were having difficulty with actually removing and replacing the nozzle? Please reply if you need further asistance
Oct 27, 2011 | Bissell 1770 Quicksteamer II Upright...
I have a Bissell Quicksteamer plus model # 1950 and when I plug it in it begins to heat the water then trips the circuit. Can this issue be corrected?
Have you cleaned the tanks recently? If not do it.
Remove water from the solution tank and collection tank.
Keep the tanks open and allow to dry in sunlight.
If you can, remove the solution tank and see whether there are any leakage signs where the tube connects to the solution tank. If there are, use an adhesive that can withstand heat and stops the leak.
You can also contact Bissell consumer service on 1-800-237-7691.
Aug 07, 2011 | Bissell 1960-3 QuickSteamer Plus Upright...
Need instruction book for bissell model 1770
Information on your Bissell QuickSteamer 1770 can be found here:
http://canada.bissell.com/Products/p/1770+quicksteamer/Product.aspx
The User Guide for the 1770 /1970 Series is here:
Apr 13, 2011 | Vacuums
Where can i order a quicksteamer plus 1950 clean water tank?
I had a look at the Australian variant of this model and located parts number 407-0931 Clean Water Tank.
My best suggestion is that take this part number and contact your local Bissell Service Center, go to the Bissell International website to locate information for your country.
May 26, 2010 | Bissell 1950-3 Quicksteamer Plus Vacuum
Bissell manual
Sorry this is as close as I could come...but *** covers the Quicksteamer 1970 model...and surely it is the exact same process for yours...as this manual covers several models.....I found it at www.bissell.com.....I hope this helps...good luck and thanks For rating my effort....The Fang
http://www.bissell.com/images/UserGuides/1770_0206.pdf
May 20, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissel 1770 Quicksteamer II Upright vacuum
Here is a picture breakdown, maybe that will help. Sometimes tho you can run a mixture of vinegar and hot water thru it, it may clean it out ok.
Mar 25, 2008 | Bissell 1770 Quicksteamer II Upright...
Bissell 1770 Quicksteamer II Upright Vacuum Logo
652 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
