Slidere I am interest to find out where to get information on parts that are used to made the slider on a copier such as canon pc 425. Can I modified the Canon PC 425 copier, so that the system will not reverse the direction until it receive an external contact signal? I also want to be able to disable all other interlocks that are not used for moving the stage? The PC 425 copier has a "metal" strip. What is its function? Pleasse send answer to ozozoz99@hotmail.com. Thank you.
  • 1,326 Answers
What is it that you are trying to do withe the copier????? The funcations of the copier are all set to different clock pulese. And if it dose not get the right one at the right time it will code out.... Self defeating I would say...
Posted on May 11, 2008
There are no active mixer drivers available information msg comes when i clicked volume cntroller
Go to Start - Programs - Accessories - Multimedia or Entertainment and then select Volume Control. Note: If you have more than one playback device installed in your computer, make sure that the proper device has been selected before modifying the mixer control settings. To do so, select Properties from the Options menu, and make sure that the proper device has been selected.
Make sure that the Mute All check box below the Volume Control slider and the Mute check box below the Wave slider are not checked, and that the Balance sliders for Volume Control and Wave are in the center of the scale.
Move the Volume Control and Wave sliders at least halfway to the top of the scale. If the Play Control and Wave sliders do not appear, select Properties from the Options menu, and then make sure the Play Control and Wave check boxes are checked. You may need to adjust the current Play Control or Wave slider settings to play wave files at the volume level you want.
If you hear popping or crackling noise from USB speakers, turn off the SpeedStep (if you have a Intel Mobile Pentium III processor) functionality during the sound session. To do so, set the power scheme to an non-adaptive mode: Click Start, click Control Panel, and then click Performance and Maintenance, and click Power Options. On the Power Schemes tab, click Always On in the Power schemes box, and then click OK.
Jan 01, 2011 | Creative Labs SBS 250 Computer Speakers
Stuck brake slider pin- how to loosen grease & reuse?
I usually remove the caliper, use penetrating fluid (PB Blaster) and loosen the slider pin. You buy new ones if it's too corroded where a burnishing can't clean it up.
Make sure you use a springs brush to clean out the caliper where the slider pin goes. I always use some good hi-temp grease and some anti-sieze where the slider is exposed to the air outside of the caliper. Make sure the rubber boot is not torn. these can be replaced too.
New boots and slider pins are not part of the standard pad kit.
Nov 30, 2010 | 2005 Chrysler Town & Country
What is massige " cheek your document"?in canon copier model ir2016i sanks
do you mean CHECK DOCUMENT SIZE?
If yes, check the paper size slider in cassette, check under printer properties custom paper size, it should state the paper wich is in cassete.
Aug 11, 2010 | Canon iR 2016i Black and White Copier
How to mount 06 zx10r framesliders? Do i need to take fairings off or cut? Thought it would be just sliders themselves instead got sliders, brackets and a lot of screws....??? They are PSR (Powerstands)...
they should have included instructions. i am not familiar with that model but most frame sliders have brackets that bolt to the engine/frame mount on each side. then the slider mounts to the newly installed bracket. you Will have to modify (cut) holes in the body for the sliders to protrude. they would not serve any purpose bolted to just the body in the event of a crash.
Use a torque wrench for this as those bolts also will be holding your engine. you may get lucky and the not have to modify the body if they designed the slider to protrude through existing body holes.
Oct 03, 2009 | 2006 kawasaki ZX-10R
I'm suddenly getting uniform black lines on copies when using my canon pc 425 monochrome personal copier
remove toner cartridge, and look at the drum (on the bottom of cartridge). If there are toner streaks on it, it is failing and needs to be replaced.
*please rate me :)
Mar 26, 2009 | Canon PC-425 Color Copier
Zoom
My zoom problem was a combination of the software and hardware when it came to the neutral position for the zoom slider. When the camera is first turned on, if the physical zoom slider (hardware) is in the neutral position (you are not touching it) the camera software does nothing, but if you are pushing the physical zoom slider when you turn on the camera, the software resets the "zero zoom" position into memory. The solution to my problem was to push and hold the physical zoom slider towards the wide position and the software realize reset the "zero zoom" neutral position. This may take a few tries to get it right (if you over compensate, do the opposite and push the slider towards "T" when you turn it on), but I hope this will solve your problem and save you a few bucks.
Ryan
Jul 04, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Envelope printing
there is a slider for paper on the paper tray the envelope runs long ways usually on the right hand side of the paper tray
if the slider isnt there it probably broke off this helps keeps alignment of envelope and different size papers in line
May 21, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Slider switch problem
Switching probel- may be repairable - check out Canon for estimate- but don' hold your breath
Sep 04, 2007 | Canon Powershot SD450 / IXUS 55 Digital...
44 people viewed this question
k24674
jasbo
jasbo
