Question about Karcher 2500 PSI Pressure Washer
I have an older model pw model number 2SFX3OG I can not figure out where and what to attach a container for soap.
How do I use the soap attachment on a wolfblaster max
Only add half of soap that you think you will use to do the job at a time and flash soap container after use so that sop doesn't control.
Apr 18, 2014 | Garden
Silly question - where do you add the detergent?
Often you will find the detergent dispenser very close to the dispenser for the softener. Mine is a separate container within the same "pullout" drawer that holds fabric softener. If you still are not sure, then find the model number of your washer and google it with the term, "user manual". Most are available online as a PDF
Nov 22, 2013 | Maytag Neptune MLE2000A Front Load Stacked...
Hose broke off fitiing
If fitting on hose broke off, replace hose. If the fitting on pump body broke off it may be a special fitting with a siphon fitting for soap induction which means it may be a model specific part. Start with a model breakdown of parts for your model PW. Honda made motors for a few different PW models and the water pump casing will change with manufactures.
Apr 08, 2011 | Honda Garden
How do you add soap to the bissell model 1630
If this is the model that attaches to the sink faucet it should have a solution container that connects to it.
Model 1630 and 1631 are the same and the manual can be found by clicking the link below.
LINK
Hope I was of help.
Mar 28, 2011 | Bissell Vacuums
I was using the upholstery attachment on my Hoover F7220900 and the water and soap container had emptied out all over my floor.
Sometimes it's to put the lid on the water and soap container so that's it's not completely sealed. This can happen due to the gasket in the cover becoming dislodged or it's also possible to screw the cap on in an uneven manner. I would check the seal inside the cap/cover and make sure that it is screwed on properly. If it isn't the container leaking, it could be a broken hose, etc. I would check the container first. Good luck!
Mar 14, 2010 | Hoover F7220900 SteamVac V2 Upright Vacuum
Dishs have soap flim
If your dishwasher has been in use for a period of time, you may need to clean the interior of the washer.
The next time you are at the grocery store, pick up (2) containers of "Tang" orange drink. With no dishes in the dish washer, fill the soap container with Tang, close the lid and poor the remaining Tang in the bottom of the dishwasher.
Close the door and run through your regular wash cycle. You may have to repeat this with the second container if it is an older model washer.
The citric acid in the Tang will clean the soap scum off the inside as well as the pump chamber inside the washer.
Good luck, it worked for me, cleaned it nice and shinny and smells good too.
Regards,
Aug 13, 2009 | Dishwashers
Unlock my nokia 6300
Hai,
You can visit the site mobileunlocker.In that site contains the unlocking instructions and unlock code for the nokia 6300.its contains the unlocking instructions for all mobiles.
Jan 26, 2009 | Nokia 6300 Cellular Phone
Nokia 6500 slide
You Have given 2 IMEI nos, here are the codes for both,
Model: Nokia (6500 )
IMEI: 358675019083382
Network: 23433000
#pw+989 072 613 752 071+1#
#pw+717 410 141 566 513+2#
#pw+738 200 666 634 506+3#
#pw+984 442 616 236 546+4#
#pw+138 274 761 644 670+5#
#pw+888 101 213 603 004+6#
#pw+423 307 550 145 705+7#
Second one
IMEI: 354837021915217
Network: 23433000
#pw+993 542 324 107 442+1#
#pw+742 140 275 073 641+2#
#pw+883 861 210 150 360+3#
#pw+423 127 455 133 027+4#
#pw+108 924 036 611 127+5#
#pw+829 171 550 723 574+6#
#pw+882 431 612 036 733+7#
Try these unlock codes one by one till any of them works for you.
Hope this helps,
CynosureboY
Sep 12, 2008 | Nokia 6600
Blocked security code
Model: Nokia (DCT2 )
IMEI: 358658010699489
Network: 51502000
#pw+797 784 455 0+1#
Security Code: 85897
-------------or--------------------------
Model: Nokia (DCT3 )
Network: 51502000
#pw+506 226 598 2+1#
Model: Nokia (DCT4 )
Network: 51502000
#pw+899 371 327 725 574+1#
#pw+982 212 712 014 517+2#
#pw+799 470 626 756 073+3#
#pw+914 032 240 222 030+4#
#pw+942 172 375 053 077+5#
#pw+145 454 375 356 052+6#
#pw+096 833 725 440 630+7#
send me your phone model alongwith the previous details.
Sep 01, 2008 | Nokia 1600 Cellular Phone
Karcher 2500 PSI Pressure Washer Logo
41 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
