Question about Kenmore Elite 45986 Front Load Washer
Washing machine water shutoff valve can't close
I bought another washing machine so I need to remove the old one. Before removing the hose from hot and cold valve i need to close the valve, but I couldnt. Its very difficult to turn it clockwise. I tried to turn on the washer so the water gets the machine releasing some pressure...but i still could not turn it. what should i do?
I tried to turn off the main shutoff valve outside the house...but same problem. Please help.
thanks,
Dan
  • 975 Answers
What you need is a pressure pliers tool , that will do the job, thanks AJ
Posted on May 10, 2008
LG front loader WD14071SD6 won't fill and run on cold wash. Works fine on hot. Thanks
The main causes your washing machine is not filling with water MAY BE:
1. One of the water valves (hot or cold) supplying the washer with water has been turned off or closed.
2. Your washer has a shutoff valve on the back that may be in the closed position
3. There may be a water filter on your washer that is clogged and tells the washer computer (control board) to not allow water to enter.
4. A hose or water connector on the back or inside the washer is defective or clogged.
Dec 29, 2016 | LG Washing Machines
Tip
How to fix a Washing Machine if it is leaking
Leaking water from a washing machine usually comes from hoses or connections. Be sure that water appearing to be a leak isn’t drain water from a backed-up standpipe. To prevent potential flood damage, which can occur if washing machine supply hoses burst, be sure to install “no-burst” stainless-steel mesh hoses and lever-type shutoff valves, as shown below. With these, you can easily turn off the levers for both hot and cold water between wash days. 1) Check the fittings where the hoses connect to the faucets and to the back of the washing machine. Also look for worn or leaky hoses. Tighten couplings or hose clamps if needed, or replace the hoses altogether. Be sure to turn the water off before removing the hoses, and drain them into a bucket after disconnecting them.
2) Determine whether the machine is oversudsing, which can cause it to overflow. Reduce suds by pouring in 1/2 cup white vinegar in 1 quart water. Then switch to either less detergent or a low-sudsing variety.
3) The machine may have a faulty basket gasket or tub seal and bearing that must be replaced; in this case, call an appliance repairperson.
on Sep 03, 2010 | Washing Machines
How to remove washing machine from jayco sterling 2013
I PRESUME YOU WAN'T TO REMOVE A OLD WASHING MACHINE,
1. PULL OUT ELECTRICAL SUPPLY PLUG.
2.PULL MACHINE OUT A BIT TO GAIN ACCESS TO BEHIND MACHINE, SOME MACHINES HAVE COLD WATER SUPPLY PIPE ONLY BUT MOST HAVE HOT AND COLD SUPPLY PIPES.
THERE SHOULD BE A SHUT OFF SUPPLY VALVE AT THE SUPPLY SIDE OF THE TWO HOSES, CLOSE THEM BOTH THEN DISCONNECT HOSES, DRAIN HOSE SHOULD JUST LIFT OUT OF PIPE BEHIND MACHINE , NOTE ALL HOSES WILL LEAK SOME WATER ONTO FLOOR IF LAYED DOWN
A SACK TRUCK IS THE BEST WAY TO MOVE MACHINE
Nov 12, 2016 | Washing Machines
GE washing maching not filling
Several factors can cause a GE washing machine not to allow water to enter the drum, including closed valves, kinked hoses, a faulty electrical breaker or sediment in the water lines. Sediment occurs most often when the water to the home is off due to electrical outages or when installing items in the plumbing. Cleaning the screens will remove a sediment blockage, allowing water into a washing machine.
    • 1 Check each water valve for the hot and cold water lines to make sure they are open completely. Open valves are turned completely to the left. Check the fuse at the electrical box to make sure it is not faulty, and check to make sure the washer is plugged securely into the outlet. Observe the water supply hoses to make sure there are no kinks from the supply valves to the back of the appliance.
      Observe the water supply valve handles to see if they are cracked. If so, they need replacing.
    • 2 Turn off both the hot and cold water supply valves. Turn each knob completely counterclockwise to turn them to the off position. Pull the washer forward to reach the water supply valves, hoses and the back of the washing machine. Place one hand on each side of the washing machine and slightly lift the front while pulling straight out from the wall.
    • 3 Place a bucket at the rear of the appliance. Use adjustable pliers to unscrew the hot and cold water hoses on the back of the washing machine. Turn each hose counterclockwise to unscrew and remove from the washing machine while pointing them into the bucket to catch any water in the hoses.
    • 4 Turn on the hot water supply valve and hold the hose pointing into the bucket. Observe to see if water is coming out of the hose or trickling out of the hose. Repeat this procedure for the cold water supply hose. Limited water or no water flow indicates that the lack of flow is at the valve end of the water supply hoses.
    • 5 Pull the filters out of the washer valves with needle-nose pliers. Rinse under warm water to clean out any sediment and replace them in the hot and cold water washer valves on the appliance.
    • 6 Unscrew the hot water supply hose from the valve using adjustable pliers. Turn the hose connector clockwise to unscrew and remove. Repeat this procedure with the cold water supply hose. Pull out the screen from each hose with needle-nose pliers and rinse under warm water to clean. Replace the screens.
    • 7 Replace both water supply hoses on the washer valves and the washing machine and tighten them with adjustable pliers. Slide the washing machine back into place and level the legs by slightly lifting the front of the washing machine and setting it back down.
Oct 03, 2011 | Washing Machines
How to remove hot water valve to replace?
look at the new valve and you will see that the champhered tab has a bump near the end. This needs to be lifted on the old valve. do it with a screwdriver and slide the valve along. It is a close fit but once you get it you'll see how it works...Good luck....Nomess
Apr 21, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
NEC NW-452 Washing Machine will not run a Hot Wash
by memory it is located at the lop of unit, where u attach the inlet hoses 2 the machine. u need to remove inlet hoses first with water turned off, then undo 2 screws at back of washer holding plastic panel that covers water valves and electics. it unclips off, i always have trouble myself. once u have that panel off remove wires to hot valve ( that is the 1 that had the hot water hose attached to it) put your tester on the terminals. if u get a different continuity reading compared to your cold it is faulty. if it is the same your computer at the front of unit is faulty.see how u go but remember turn off the power b4 u work on it! dont want any acciedents. please reply back for more help. good luck!
Mar 10, 2010 | Washing Machines
1 year old Frigidaire front loading washing machine will only
Check the water inlet valve. Unplug the machine, turn off the water, and remove the supply hoses. Check the small metal screens inside the openings on the water inlet valve. Make sure they are clear of rust or debris. Pay particular attention to the hot water side. Check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid and the valve assy will need replaced. I'll attach a photo for reference. Hope this helped and best wishes.
Oct 07, 2009 | Washing Machines
Hot water fill is weak
you can look at the back where the hot water supply is connected.
first, close the hot water valve, remove the hose and at the fitting of the washing machine, there is a stariner at the middle, it could be clogged.
if not then with the hose still attached to the hot water valve, put the hose inside the drum and open the water valve, observe the pressure of water if it is good.
if it is not, then the water source's pressure is the problem.
tnx 4 using fixya,
drcool
Sep 19, 2008 | Washing Machines
Washing Machine fills slowly how to change inlet valve
switch off power remove top switch off water and remove hose. remove inside pipe from valve - usually held by just a spring clip remove electrical terminals valve is just held with a couple of screws usually - remove these and valve will come away. put back in same order
Jun 22, 2007 | Creda W100FW Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
62 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
