Question about Simplicity Performer S110 Mechanical Sewing Machine
Simplicity Model S110. I opened the Bobbin area and found a small spring. I am not sure where it goes. My grandson was playing with it before I could stop him. Can you help?
3 Suggested Answers
  • 4 Answers
SOURCE: I have a Simplicity Fashion Plus
Be careful what TYPE of bobbin you use. Some are flat and some are curved. Sometimes the plastic ones are even different sizes! See if you can determine what type CAME with the machine and only use that type. JLP
Posted on Nov 12, 2011
  • 166 Answers
SOURCE: spring come of in bobbin area bernette 60
Without knowing which springs are involved, I cant really help - there are a number of springs in the machine associated with the hook drive and the feed regulator, so if its not obvious where the springs are attached, your best bet is to try and get a manual for the machine.
Posted on Nov 14, 2011
Needle is stuck in down position and manually the wheel won't move
Try removing the bobbin case. Usually the thread is holding the needle in place, therefore the hand wheel will not operate. Once you get the thread released, it should all come free.
Sep 15, 2016 | Simplicity Sewing Machines
Hello I'm having a problem with the top thread connecting with the bottom after I thread both and turn the wheel for them to connect nothing is happening
Try changing the needle
Try rethreading the machine top and bobbin
Make sure the bobbin is turned the correct way In the bobbin case
It's possible that the machine needs to be checked for a timing problem
Aug 18, 2013 | Simplicity Performer S110 Mechanical...
Simplicity heavy duty performer s110 manual
try these sites--you may have to email some of these sites about the manual
sewingpartsonline.com
sew4less.com
sewusa.com
sewvacdoctor.com
a1sewingmachines.com
May 01, 2012 | Sewing Machines
Simplicity americana Model SE3 needs service
I agree, the machine needs to be serviced at a sewing machine shop
Apr 16, 2012 | Simplicity Sewing Machines
How do you thread the machine, top and bottom, please.
From the Simplicity Sew Precious Model SWSP2 manual:
Inserting a new bobbin:
  1. Place wound bobbin into the bobbin case.
  2. Pull about 6 inches of thread out from the bobbin.
NOTE: Be sure that the bobbin rotates COUNTER-CLOCKWISE when thread is pulled.
  1. Pass the thread from the bobbin, under the bobbin case spring, and toward the back of the machine.
  2. Slide bobbin cover back into position.
Upper threading:
  1. Turn the handwheel toward you to raise the take-up lever to its highest position.
  2. Lower the presser foot.
  3. Place a spool of thread and spool cap on the spool pin.
  4. Place the thread into the first thread guide at the top of the machine.
  5. Bring the thread down the right slot of the threading path, then around the tension dial. Push the thread tension release lever and pull the thread up so the thread is secure in the thread tension dial.
  6. Bring the thread up the left slot of the threading path and through the take-up lever from right to left.
  7. Bring the thread back down the left slot of the threading path and into the needle eye from front to back. (Clip the thread end with sharp scissors fro easier needle threading.)
Raising the bobbin thread
  1. Make sure the presser foot lever is raised.
  2. Hold the end of the needle thread with your left hand. Turn the hand wheel toward you with your right hand until the needle goes down once and comes back up, stopping when the needle is at its highest position.
  3. Gently pull up on the needle thread. The bobbin thread, looped around the needle thread, will be drawn up through the needle hole.
  4. Push the thread tension release lever and pull about six inches of both the upper and lower threads toward the back of the machine, placing them under the presser foot.
You can obtain a copy in pdf format for free at:
http://www.simplicityhomecare.com/ftp/whitepapers/SWSP2-english.pdf
Dec 10, 2007 | Simplicity Sew Precious SWSP2 Mechanical...
How to properly thread the bobbin
  2. Pull about 6 inches of thread out from the bobbin. NOTE: Be sure that the bobbin rotates COUNTER-CLOCKWISE when thread is pulled.
  3. Pass the thread from the bobbin, under the bobbin case spring, and toward the back of the machine.
  4. Slide bobbin cover back into position.
Sep 21, 2007 | Simplicity Sew Precious SWSP2 Mechanical...
Simplicity Performer S110 Mechanical Sewing Machine Logo
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Greg Cann
Greg Cann
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
