Question about Toshiba 32HL83 32 in. LCD HDTV
Tv goes on and then picture and sound go off at same time....no consistent time interval.....sometimes the screen is not fully illuminated...sometimes when the picture and sound go off, the power light blinks
  • 11,361 Answers
There are two common possibilities that are causing this problem, dying power supply due to bad DC filter caps, or shorting out backlight inverter board, you will have to do in-depth troubleshooting to narrow down the problem. Please read my guide see the pictures so you can decide if you will want to DIY repair or not.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Sep 01, 2010
Picture goes black with gray fuzzy lines ~ 1/2" apart horizontal.
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sanyo DP50749 50 in. Plasma TV
Screen zoomed in zoom out
this is likely a virus, trojan issue... have you done a thorough virus scan with current software???
superantispyyware.com... free
Aug 17, 2013 | Sony Computers & Internet
I have had my tv since 2003. The picture is still great but it goes pink around the edges, the screen scramble or goes thru all the possibilities including split screen and picture in picture versions...
Sounds like the light engine is going...costs as much as a whole new set. May have to get a service man to have a quick look at it to be sure. Scrap the set if it is the light engine and buy an LCD or Plasma. They won't last as long as this set did...
Mar 23, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Lcd tv loses picture, power lght flashes grn; picture return
It sounds lamp is weak in TV and requires replacement.
I would be in better position to help you out if you post model and brand of your TV.
Dec 31, 2009 | Televison & Video
Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Apr 30, 2009 | Sharp Aquos LC-C3234U 32 in. LCD TV
Sony kv35s66: No picture, just sound and red blinking
This should be a quick fix. Try resoldering the vertical IC. This is a small flat IC attached to a heat sink with about 11 pins. It should be marked LA7837 or something similar. That should resolve the problem.
Keep us posted.
Dan
Sep 08, 2008 | Televison & Video
Sound but no picture
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
The most common problem (I have fixed lots) is the Vertical amplifier has developed a loose connection. It probably just needs resoldering. As things expand it makes and looses connection you picture goes in and out. The vertical chip is a large black chip that gets hot, over time it degrades the solder until a connection is damaged. Most newer sets have a protection circuit that senses the lack of height, and shuts down the picture tube to save it. When the picture dropped to a line on older TVs and left that way too long it would burn a line into the face of the picture tube. You then had to have the picture tube replaced along with the vertical amp. it's kinda like a screensaver for your TV.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Flashing in and out picture
This is crt base failure due to corrosion. That is why to wont get clear picture initially when you switched on in long interval period. Change crt base problem solved.
Sep 09, 2007 | Toshiba 27AF41 27" TV
Toshiba 32HL83 32 in. LCD HDTV Logo
103 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
