Question about Delfield Freezers
Screen showing eror-7 - Delfield Freezers
  • Delfield Master
  • 1,150 Answers
Http://www.delfield.com/?xhtml=xhtml/del/us/en/general/partsandservice/archivemanuals.html&xsl=minisite.xsl
since you did not supply any info, lik model or serial numbers, check out this site for a manual on your unit and see if you can find what you need.
Posted on Sep 05, 2010
My upright freezer shows hi temp on screen it making a noise now it is not saying anything
then you need to contact a repairman possibly needs freon added to the system .
May 09, 2016 | Freezers
Frigidaire GLFH17F8HW upright freezer has stopped working. electronic screen is messed up with power loss lights on.
This is the part that is most likely bad: http://www.repairclinic.com/PartDetail/User-Control-And-Display-Board/297366306/1864642?ss=-x676c6668313766386877&mr=1
Aug 24, 2015 | Frigidaire GLFH17F8HW Gallery 16.6 Cu. Ft....
F1471 vi Miele freezer showing fault code 01 21 _F
From a previous post for a different Miele freezer: "I emailed Miele and this is what they reply: Thank you for your interest in Miele products. That message is a ice fault. If the ice has stopped production, please turn the toggle switch off under the electronic touch panel. To find this please reference the owners manual on pages 7 and 9. I have included the owners manual in case yours is missing. If your machine still produces ice fine just shake the cubes around making sure none are built up along the back wall of the ice drawer. If this continues please contact our service department. Please reference incident number 2698767 should you need to call in. For more detailed information, please visit our web site at www.miele.com or to speak with one of our representative call 800-999-1360." Haven't tried yet, but will post again if it didn't work, otherwise should be the answer"
Nov 17, 2013 | Miele Freezers
Frigidaire upright freezer: freezer stopped working (no power).
Hi Kevin - it sounds like your freezer may possibly be stuck in diagnostic mode. Press and hold the Up (+) and Down (-) keys simultaneously for 3 seconds or more. The buzzer will beep at the end of the 3 seconds. Hopefully that will resolve the issue.If you continue experiencing this problem, please provide a model number to your freezer and any additional symptoms it may have experienced prior to shut off. - Best of luck!
Aug 25, 2012 | Freezers
I have this majic chef freezer about 7 cubic ft. 3 years old turned it off to defrost and when turning it back on it won't get cold?? Compresser is hot so I believe it is working and lights on in front...
I'd let it dry out totally then try it again, some of the electronics may have gotten wet when you defrosted it. Give it a week somewhere warm and dry like a garage. If you didn't attack built up ice in the freezer with a knife while defrosting it it should work after it dries out. Most people end up killing freezers by accidently poking holes in the evap coil while trying to remove built up ice.
Aug 14, 2011 | Magic Chef Chest Freezer MCCF5WBX
Where is the thermostate(sensor) located that controls the compressor - or is it the same as the sensor located by the door which show the temp on the outside indicator Thanks
The thermostat sensor is located in the top rear of the interior of the unit, if you locate the dial to change temps on the inside of the unit, the sensor is attached to it, you may have to pull your fridge apart to get to it, but it can be done.
Regards Russ
Mar 07, 2011 | Nor-Lake Freezer Norlake Refrigeration 6'...
Lcd not working just flashing with no temp showing food starting to defrost
Hi, You should replace you lcd soon to see the correct setting of appliance. It is hard to control your freezer with out its screen working normal. Regards,
Nov 28, 2010 | Miele Freezers
The alarm light is flashing, the freezer seem to be working,
Most all cooling systems need to be in an ambient temp of about 60-65 degrees. If not, it needs a low ambient control. This helps keep the high side pressure high enough so you have the proper pressure drop accross the expansion device. This applies to coolers, freezers, a/c units, and so on. I also think, if it keeps things frozen like you want, where's the problem? You make have a control just acting stupid.
Feb 07, 2009 | Freezers
Need correct setting for 30 yr old upright Kenmore freezer
depend on the type of control you have on your box ,,,, best is if it shows 1-7 set it on 3-4 ,, if it has letters set it on C ,,, eather way set the control on mid-point and it will work fine.
Larry
Nov 22, 2008 | Freezers
Used freezer won't freeze food
If the compressor is running and it still doesn't cool, it is probably leaking freon. If this is a frostless model there are other minor things that can go wrong. This usually shows up on a freezer that has recently been moved or hasn't been used for a time. This is almost never worth fixing as even if you fix it you can't ever completely trust it again. The food inside is usually worth far more than the freezer and most homeowners insurance doesn't cover it anyway.
Jun 30, 2008 | Freezers
Freezers Logo
110 people viewed this question
Top Delfield Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Delfield Freezer Expert? Answer questions, earn points and help others
