Question about Dryers
Our dryer model wed6200sw1 will not power up. my brother inlaw installed a 3 wire power cord when helping us move. there is a white wire that hangs loose in the housing that I believe is a nuetral ground, but he hooked it up to the right side live wire. dryer made a awful noise when started and will only run for a few seconds before shutting off with all power lights still on. after a few minutes you can here something reset and you are able to start again with the same results. I tried to move the white wire to the center pole but now the dryer will not power up at all unless you move the white wire back were he had it. i have tried to replace the machine control electronics assy. and the user interface assy. but this did not work. i have checked the power at the block from center to right it reads 240 volts from left to right reads 240 volts but from center to left it reads 10 volts with wires connected. do you have any suggestions .thank you.
  • 347 Answers
This is tough to say without being their.. But lets try...You need to hook up the power cord correctly before doing any other diagnostics...On the dryers terminal block you should have a black on one side, white in the center, and red on the other side THE POWER CORD WIRES HAVE TO BE HOOKED UP THIS WAY. when checking voltage at the back of unit make sure its 120 volts from center to right side , and 120 volts from center to left side after this is correct we can diagnosis from their if its not working right.......
Posted on Sep 01, 2010
  • 10 more comments
  • chrys0903 Sep 02, 2010
    when hooked up voltage to the right from center is 240v, left to center is 10v. But if you check the cord with the cord disconnected from dryer it is 120 per side which seems very odd to me why it would be different while connected. thanks
    when hooked up voltage to the right from center is 240v, left to center is 10v. But if you check the cord with the cord disconnected from dryer it is 120 per side which seems very odd to me why it would be different while connected. the cord is a 3 prong all grey I have it connected left to left center to center and right to right, and floating white wire to center. thanks
Just moved, the dryer has a 4 prong plug and house has 3. Should it replace plug to dryer to 3 prong or house plug?
Buy a 3 wire cord and install it on the dryer. Hang onto the 4 wire one in case you move again.
Aug 28, 2011 | Whirlpool LER4634J Electric Dryer
I have a four prong clothes dryer plug that needs to go in a three prong outlet - 220v. Any ideas?
It's either you convert the 3-prong outlet to 4-prong or the 4-prong cord to 3-prong. But the latter is easier and more feasible. Unplug the dryer then disconnect the 4-prong cord from the dryer. Note that it has red, black, white, and green/yellow wires but sometimes the red and black wires are both replaced by same color wire, usually gray. The red and black wires are lines L1 and L2 reversibly, meaning they can switch places, while the white and green/yellow wires are the neutral line and ground, respectively.
Get yourself a 3-prong cord and note that it has red , black, and white wires but sometimes, like the 4-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect these 3 wires in the same manner they are connected as 4-prong cord to the terminal block. The wire strapped to the dryer cabinet and connected to the green/yellow wire of the 4-prong cord wire is now left hanging. The last step is to connect this hanging strap wire to the same terminal on the terminal block (center) where the white wire (neutral) is connected and it's done.
It can be observed that converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3. On the other hand, converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 20, 2011 | Maytag Dryers
Just moved into an older home with a 3 prong dryer receptacle. My whirlpool duet dryer model: GEW9250PL1 currently has a 4 prong cord. I have purchased the 3 prong cord and am ready to install. Very...
Hi, White, green green/white striped they are all the same....only thing you really have to worry about is that you have the red and black in the proper places...
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Jul 13, 2011 | Dryers
We just moved into an older home, the 220 dryer outlet is set up for prongs. I went to a hardware store and bought a Magnum 4-wire cord that matches the outlet. My dryer has a 3 wire cord. I removed the...
The red and black are the "hot" wires... white is the neutral and the green gets hooked to the frame of the dryer...
Here is a tip that gives more detail...
heatman101
Aug 28, 2010 | Faber Pro Magnum 605989 Kitchen Hood
MY DRYER IS NOT HEATING UP. 220 VOLT CONNECTION ON BACK OF DRYER- NEED WIRING DIAGRAM OR WHERE DOES BLACK WIRE GET ATTATCHED IN BACK OF DRYER. THERE IS A BLACK WIRE HANGING THAT IS CONNECTED TO A BLACK BOX...
The following link explains how to correctly install a power cord to the terminal block of a dryer:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Take note of the difference between a 4-wire and 3-wire configuration. The color codes for both installations are as follows:
RED - HOT (120 VAC)
BLACK - HOT (120 VAC)
WHITE - NEUTRAL (0 VAC)
GREEN - Ground
The main difference between the two configurations is how the Neutral wire and Ground wire is installed.
In a 3-wire configuration ground and neutral are connected together at the terminal block.
In a 4-wire configuration ground and neutral are INDEPENDENT of each other. Neutral is terminated at the terminal block, while ground is terminated on a ground lug on the equipment cabinet.
If you have any questions, please let me know. I hope you find this information helpful.
Aug 21, 2009 | Dryers
Putting new power cord on dryer i have a 3 cord set up a red wire a black wire and a white wire and dont know which wire to connect to which.
on the back of your dryer.
1.connect the white wire to the center of the junction box.
2.than take the red wire and connect it to the left side of your junction box.
3.than take the black wire and connect it to the right side of the junction box.
If you have a green wire on the cord as well. PLEASE make sure it is connected to the dryers back panel. do not leave it to hang.
Please do not forget to rate and comment about your experience today.
Aug 16, 2008 | Whirlpool Dryers
Power cord connection on back of maytag dryer model LDE8416ACE is not color identified in order to install a 4 cord power line.
center is always neutral ..white on cord or center wire on 3 wire cord other 2 are hot but doesn't matter red or black on cord will work
Jun 30, 2008 | Maytag Dryers
Dryers Logo
94 people viewed this question
Top Dryers Experts
