Question about Dell Inspiron 1300 Notebook
Dell 1300 LCD issue!!
I have an Inspiron 1300 that the LCD has nothing but lines on it and nothing else..
I replaced the Inverter and the LCD Cable with New Dell parts and still the samething..
What else do I need to do here?
Thank you
  • 1,027 Answers
Before buying any more parts, attach an external monitor and if the display is OK then the problem is your LCD, if the problem is displayed on the external monitor the problem is the Video card. I believe the 1300 has an integrated Intel video adapter
Posted on May 10, 2008
Where is the lid sensor on a Dell Inspiron M5030?
3) Location;
Hibernation sensor problem,
Dell Support > Inspiron M5030 Notebook PC > Service Manual,
What condition is the Video Cable in? (Dell = Display Cable)
Continuity check with a multimeter prove it to be OK?
[LED backlighting, no screen Inverter used; for those who may think it is a screen Inverter problem ]
Oct 09, 2012 | Dell Inspiron M5030 Laptop
Screen is too dark
If you can see the icons but the screen is mostly black ( you have to look real close to see the desktop or windows logo) most likely you need a new lcd inverter. I repaired a 1300 series laptop, that had a dark screen, not black, just darker, and the fix was a new motherboard. That would be the second option if replacing the lcd inverter doesnt work. Lcd inverter is about $10 Motherboard is around $50-65 for that model on ebay.
Oct 08, 2011 | Dell Inspiron 1300 Notebook
Hi i recently started having problems with my dell inspiron 1545 screen. At first it started to freeze and fade to bright white, eventually after a few days it became stuck white even after booting the...
Hi lewis haywar,
Try to replace the LCD inverter in your laptop. Most common issues on LCD are due to failing LCD inverter. It fails more often than LCD cable or LCD backlight does.
Please let me know if this solution helped to resolve your issue.
May 11, 2011 | Dell Inspiron 1545 Notebook
Dell Inspiron 1300 blank monitoe
the problem might be from the screen or from the screen inverter.
Connect your laptop to an external monitor and try again.
If there is a display, then its obvious that the problem is from screen or screen inverter of your laptop.
Good luck.
May 01, 2010 | Dell Inspiron 1300 Notebook
I purchased a replacement inverter for my husband's Dell Inspiron 1300 Laptop (14.1" screen) on Ebay. I noticed when I got it that the little screw hole on the left was on the bottom left while the hole on...
The inverter simply converts DC power from the adapter into high voltage AC power for the backlight in the LCD....if you are having distortion problems or anything else other than the brightness of the LCD, you are either looking at a cable issue or a bad LCD panel.
Mar 26, 2010 | Dell Inspiron 1300 Notebook
My Dell Inspiron 1300 wont start
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out for parts, repair service and DIY info.
May 09, 2009 | Dell Inspiron 1300 Notebook
Dark Screen Inspiron 9100
If you replaced the inverter board and its still dark you need and new backlight itself
Dec 10, 2008 | Dell Inspiron 9100 Notebook
Inspiron 6000 lcd failure
It sounds like from my experience that the issues is with the cable. Either somehow the cable is loose or it is broken. I do not think it is the LCD or the inverter. Try unplugging the cable or moving it around see if that will make any change. They are kind of fragile. They are not expensive to replace but it is not easy job to replace them.
Jan 31, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 1300 Notebook Logo
170 people viewed this question
Alun Cox
