Question about Jensen Televison & Video
I have 15" model #JE1507DC that was given to me out of a boat. i would like to convert it so that it will work in a college dorm. Is this possible and what do i need? Also need some for of wall bracket.Thank you
  • rsoif Sep 01, 2010
    i need to know if there is a way to change the power cord. All there is a plastic clip with a red and black wires attached. Is this tv only set up for 12 volt or can it be set up for 110 volt.
  • Jensen Master
  • 19,396 Answers
Hi.
To set the TV to 120VAC you need to replace the power board. That will be expensive and must be done by a technician.
The best and easiest way to proceed is buying an inverter, which will convert the 120AC into 12VDC. You will be able to plug TV directly into the inverter. It will look more or less like a power adapter. This TV does not need an expensive inverter (draw is small). A cheap one will do the job.
Here one:
Wagan 2003-6 400-Watt DC to AC Continuous Power Inverter.
Please do not forget to accept the solution.
Regards.
Ginko.
Posted on Sep 08, 2010
  • Jensen Master
  • 17,129 Answers
You will need to buy the power supply for the Tv which I think is a 12 volt/5 amp type .Just check this on the back panel .
You can get to buy many types of powerr supplies but a SMPS unit will be ideal because it will be less bulkier than the transformer type.
You can get to buy the SMPS unit from any electronic spares shop or industrial electronics spares outlets. This unit must be housed into a proper cabin and the main connected to a mains power plug and the output DC to the DC jack with the correct polarity. Make sure that the POLAIRTY IS CORRECT OR YOU WILL END UP DAMAGING BOTH THE SMPS ND THE TV.
Use a safety fuse at the Dc end.
Just in case your Tv is 24 volt type , you need to get the 24volt/5 amp SMPS unit.
Posted on Sep 02, 2010
  • Donald DCruz
    Donald DCruz Sep 02, 2010
    Sorry about the wall fittings you can have L-Type brackets to be made to order or can be done by you according to the size of the TV to be fitted to the wall to hold on.
    There are many standard types but making will be cost saving , especially for your dorm.
    Please dont forget to rate me.
  • 736 Answers
Peerless mounts should be able to take care of the mounting problem you have. Wherever you buy the mount you will need to know the VESA standard. It is:
VESA MIS-F 75mm mounting pattern
The cable company serving the dorm will have to provide you with a set top box with either composite outputs (the RCA yellow, red, and white) or component outputs (the Green/Y, Blue/Pb, and Red/Pr) in order to view tv channels.
Posted on Sep 01, 2010
  • Loretta Northcutt
    Loretta Northcutt Sep 03, 2010
    I'm sorry. I did not understand the question. You can buy a converter.
    http://www.amazon.com/s/?ie=UTF8&key...
  • Loretta Northcutt
    Almost forgot then you will need an additional converter to plug the 12V to 110V converter into
    http://www.amazon.com/Adapter-Converter-...
I just moved in to my college dorm yesterday and you have to use an ethernet cord for internet in my room. So I bought one, and when I plug it into the wall and into my computer, the ethernet port has a...
The lights means the port is active and working. Does the lan connection show as connected on the computer, what IP are you getting if any? Does the college use a proxy?
Aug 30, 2011 | Toshiba Ethernet Cable (cmcable)
I just moved into my college dorm room and got the tv all hooked up to my cable outlet, but n=my channels dont show up. is there programing i need to do to make it happen?
Yes,Used ur tv remote.Push the button said Menu.Go into ur tv MENU go to SETUP go down to Ch.setup or something like that on down to all the option of the SETUP menu.Look for 2 words like AIR or CABLE.Pick CABLE if ur college dorm offer pay tv services.Press the Enter button to scan for pay cable channels after it done scanning for channels tv should have picture and working.
Aug 17, 2011 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
I just bought a RoadPro 2500 and i want to buy like a dorm fridge how many watts or volts size would work??
If you are referring to the RoadPro RPPI-250
  • 2000 Watts Continuous Power
  • 2500 Watts Power Output @ 10 Minutes
  • 5000 Watts Peak Power Output.
  • A small fridge will use about 500 -700 watts, with startup wattage at around 2000watts.
  • So, a dorm fridge will work fine.
  • the RoadPro converts DC to AC voltage, so a regular 120 volt dorm fridge will work.
  • Jul 05, 2009 | RoadPro RPPI-2500W Inverter
    I want to find out an address of a person through his phone no.How can i?
    When I worked for Domino's decades ago we had a sort of reverse phone book called a city directory. We got it from the phone company to avoid prank orders from the college dorms. I think these are available online now, but of course that won't help if it is a cell phone.
    Feb 24, 2009 | Lands Phones
    Daughter can not get laptop connected to the web from her dorm.
    Its possible that the firewall on her computer stops it. The firewall may be thinking that the scan is an attack. Try disabling it.
    Aug 18, 2008 | Dell Inspiron 1501 Notebook
    Installing tv in boat
    You can But I would not connect it directly unless I had a regulator or isolation device between the set and the boats power. if your boat has 110 volt capability just be safe and use the adaptor.
    Sep 15, 2006 | Sharp Aquos LC-15S1U-S 15 in. EDTV-Ready...
    Televison & Video Logo
    Top Jensen Televison & Video Experts
    Computer Repairing
    Computer Repairing
    Jaime Hernandez
    Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
