Mitsubishi vs-55601 screen will go blank but the sound still remains.if the tv is switched on then off the picture comes back,sometimes for a couple of minutes sometimes for a couple of weeks this seems to be an intermitent problem,
  • powwow07 May 12, 2008
    the solution would helpful if it was more in depth.I am handy but I don't know much about electronics,if i were told how to access the vertical output I may be able to fix it.
    Thank You
  • powwow07 May 14, 2008
    thanks that was the fix I was looking for
  • 8,617 Answers
Try resoldering the vertical output IC that should solve your problem
Posted on May 10, 2008
  • Sonny Berry
    Sonny Berry May 12, 2008
    The vertical output is located on a aluminum heat sink usually on the deflection circuit where the HV generator is located and will usually be marked with Vertical on the circuit board right next to it and it will have at least 5 to 7 pins
  • Sonny Berry
I GOT A 55 INCH TV MITSUBISHI MODEL # VS-55601 I GOT SOUND NO PICTURE
shine i light on the screen to see if you can see the picture .if so the back-lights are bad .
Apr 18, 2017 | Mitsubishi Televison & Video
Mitsubishi vs 55601 picture has gone out. It was
I have found several of the vertical deflection caps to be off value as well as the vertical chip to be defective.First after pulling the chassis (mark plugs and sockets that have no id numbers with a mark a lot) look with magnifier around vertical and hi section for circuit board cracks that need resoldered.Hope this helps.
Technition
Nov 17, 2009 | Mitsubishi VS-55601 55" Rear Projection...
I have a convergence problem on my Mitsubishi VS-55601
ICS with some resisters,tries these websites Tv rpair Word.com or Tv repair kits.
Nov 02, 2009 | Mitsubishi VS-55601 55" Rear Projection...
I need the front screen for a mitsubishi vs 55601 tv. Where can I get one?
mitsubishi in california is only company you can buy this item from,,unless you can find someone that is junking a set,,I have purchased these before,and most likley they won't sell to you as they support dealers only, so give yourself a trade name if you happen to call them, and tell them you pay tax, this should work
From Wendell
Aug 04, 2009 | Mitsubishi Televison & Video
Mitsu vs-5042 Works then picture goes out. Thumping works sometim
If you occasionally have a picture then you stand a good chance of repairing this tv. There are bad grounds on the deflection board. Start with the board that has the flyback. I do not know the year of your tv. Sometimes the same model may have an option improvement than one couple of months earlier. The first suspected problem would be the vertical IC. In some cases this ic is located on the convergence board and in others the flyback board. It has seven pins and is the TDA version. Located on a large heatsink. Resolder this and any other grounds on both board. Some will tell you the P I P board is bad. This is a free standing board that can be removed and replaced. But please do the earlier option first.
Jun 28, 2009 | Mitsubishi VS-45607 45" Rear Projection...
I have a mitsubishi projection tv model vs-55601. The tv comes on but there is a blank screen. The audio is there but no picture.
Does the menu come up if you press the menu button? If not then there is a few things that can cause this problem. most likely is a fluid leak, to check for fluids i would take the front off the bottom of the set and look in with a flashlight and see if you see any liquid on the boards or corrosion of any type. let me know what you find.
TIm Nolan
Sep 13, 2008 | Televison & Video
Tv repair
There is no chip for the green, Unless he is refering to the convergence Ics as there are two of them and one controls red convergence and half green, and the other controls blue convergence and the remaining green. Those ICs are 20.00 each and take about 30 minutes to replace both. Is your set experiencing a 3D type of picture?
May 24, 2008 | Mitsubishi VS-55601 55" Rear Projection...
Sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Mar 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Electro Med Services...
