Question about BSA .22 Special Riflescope w/Rings & Matte Black
Which one to choose for my bsa supersport- five .22 rimfire with 13mm rails - bsa scope master 606 or 607 / any other rings to fit 32mm dia. scope
5 Suggested Answers
  • 152 Answers
SOURCE: how do change the battery in a BSA HD42SB
It should be seated inside the windage knob, if not look for a slotted type indentation in one of the knobs, and turn that cap counter clockwise with a coin that fits snugly in the slot while holding the sides of the knob.
It will be a pancake style battery.
Aduz
Posted on Mar 30, 2009
  • 4 Answers
SOURCE: my scope is broken
Return the scope to where you purchased it and ask for it to be replaced. Or check out BSA's warranty page at: http://www.bsaoptics.com/returns.aspx . At any rate, DO NOT DISASSEMBLE YOUR SCOPE! This will void any chance of returning it and make it into a poor baton.
Posted on Jul 07, 2009
Adrian762
  • 425 Answers
SOURCE: 3-9x50 BSA Deerhunter Rifle Scope.
What that means is they are not mounted correctly. The scope mounts should be square with your rifle when fitted, when the scope is placed into the mounts, it should be turned to be square with the rifle.
Firstly, make sure you do not "cant" when you shoot. That is hold the rifle at an angle instead of vertical. Once you are sure that is OK, then put it into a vice using blanket or some other soft material to protect the stock. Get the rifle perfectly square using a spirit level. There should be a flat spot on the top of the action that you can use. Once this is achieved, you loosen off the scope mounts and square the scope up to your satisfaction. Once done, tighten the mounts up and then remove from the vice.
Posted on Feb 10, 2010
  • 243 Answers
SOURCE: cross hairs sideways?!
If you are seeing an X you need to loosen the scope rings, re-level your scope and re-tighten the scope rings. 10-20 in/lbs on the ring screws, 15-30 in/lbs on the mounting screws. Typical configuration of the turrets is one on the top, one on the right side.
Posted on May 31, 2010
Why did i get a sudden loss of power in my mk 1 bsa airsporter 1.77
It could be a broken spring or the piston seal has dried out if it is a leather one if it is a rubber oring it may have broken down depending on how old it is
When was it last stripped and serviced
Apr 26, 2016 | BSA Supersport Air Rifle 0.177
Ballistics for 22 mag
The ballistic performance of the .22 WMR based off 30, 40, 50 grain is 2,200 ft/s (30 gr), 1,910 ft/s (40 gr), 1,650 ft/s (50 gr). - See more at: http://gundata.org/cartridge/173/.22-winchester-magnum-rimfire-%28wmr%29/#sthash.qVd5FziR.dpuf 22 Winchester Magnum Rimfire WMR Ballistics GunData org
Feb 18, 2015 | Henry Repeating Arms Henry Frontier Lever...
My name is james and I recently had bought a new bushnell rimfire scope for my ruger ten twenty two. I had used the scope and began to sight it in. I was adjusting the sights then looking through the scope...
You backed it off too far and the alignment screw came out of the internal guide. They are usually pretty close to accurate when they are released from the factory. Make sure your mounts are in proper alignment and tight before trying to sight it in. 1 click is normally 1 inch at 100 yards.
May 14, 2011 | Bushnell 22 Rimfire 3 9 x 32 Silver...
Even though the scope was marked 22mag could it still be used with out damage on a regular 30-06 rifle, thanks for your time
Everything I could find on your scope says that it can be done, provided that you can get the correct mounts.
It looks like the optics will be able to handle the stronger kick of your '06, but because they are much smaller than a full-sized rifle scope at 32mm, you will be limiting yourself because the scope cannot drink in as much light for the longer ranges that the '06 is capable of.
One thing that you have to be careful of is that since a .30-06 kicks ALLOT more than a .22, that you set the scope far enough back so that it does not hit your eye when you fire. You do NOT want your eye right up against it, because after you fire your rifle you will get a bloody black eye!
You should seriously consider a scope with a larger aperture. If cost is a problem, Look around at Sportsman's guide.... I got a real nice 6X29 40mm BSA scope from them for about 80 bucks!
Mar 10, 2011 | Simmons 511072 3-9x32 A/O 22 MAG...
How to set up a redhead red dot pursuit deluxe
You must have the correct rings for your base. If the scope has rimfire dovetail rings already attached, it should be easy. Remove the 4 setscrews on the top of the receiver, install the dovetail mount (use blue locktite and DO NOT TIGHTEN THE SCREWS MORE THAN 10 IN/LBS! Otherwise you may strip the threads in the receiver!).Loosen the clamps, place the scope on the dovetail mount and tighten snugly.
If it has weaver mounts, you will need to install a weaver rail to your receiver. Remove the 4 setscrews on the top of the receiver, install the weaver mount (use blue locktite and DO NOT TIGHTEN THE SCREWS MORE THAN 10 IN/LBS! Otherwise you may strip the threads in the receiver!). Install the rings in the weaver slots, tighten snugly.
Go Here:
http://www.outdoorpros.com/How-To-Guides/How-To-Zero-A-Rifle-Scope/5
for info on how to zero your red-dot after you have it mounted.
Apr 17, 2010 | Cabela's Optics
How do change the battery in a BSA HD42SB
remove the screw on battery cover counter clockwise.  Replace the small button battery and carefully replace the battery cover and don't forget the o ring.
Mar 29, 2009 | BSA Air Rifle 3-90X40 Ir Red Dot Scope
Need instructions for my BSA Red Dot RD 30/22 Scope
I contacted BSA and they e-mailed me the instructions!
Mar 19, 2009 | BSA Air Gun Scopes
BSA .22 Special Riflescope w/Rings & Matte Black Logo
111 people viewed this question
Top BSA Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a BSA Optic Expert? Answer questions, earn points and help others
