Sumsung reprojection stop working as we were watching it to coulor change and a small line came up on the srceen then it just turned it self off.It is 4 years old and has 3 colour round tubes behind the screen model numer is SP-54T5HP/MODEL CODE VERSION 1/TYPE NO-CM54T6 sO DO I NEED TO BUY NEW COLOUE TUBES FOR IT OR IS IT SOMETHING ELSE.
  • 121 Answers
What kind of line came up did it come up in the middle of the screen or was it a solid colored screen with arched lines through it....need more info on what its doing
Posted on May 10, 2008
I tried this it is hasnt worked? the tv dose come on for a sec ( video4) appears in the top left corner of tv goses of as it turns of its a green srceen with some lines
i'd need the model number to investigate; every model is different due to the technical circuits that have changes from model to model.
Dec 11, 2014 | Televison & Video
How can get sound on my iroman 8 lap watch after changing battery. I wander if there should be a tape in the back cover and if yes to what extent it should cover. when I set my alam I see the fainting of...
mcdevito75 here, It"s possible the NEW battery in your watch is weak from an extended shelf life, I'd return to the place the battery was installed and ask. Also you can go over your watches functions again as the watch has to be re-set once the battery is changed.
Jul 15, 2010 | Timex Watches
The watch is self widing. ait just stopped working
Yes I do. Don't try to fix your watch.
My watch maker friends have told me that generally speaking, the reason most self wind mechanical watches stop is: (1) they need cleaning or (2) the screw that holds counter weight in the watch (that actually does the winding) comes unscrewed. He said most of the watches that have been worked on by the customer have lost the screw.
My advice remains have your watch looked at professionally.
Any other concerns my friend?
Jan 14, 2010 | Watches
ICEMAKER STOPPED WORKING, HAD IT OFF FOR QUITE A WHILE, AND TURNED IT ON THE DAY WE HAD THE WATER OFF TO RUN A NEW LATERAL TO THE HOUSE.
Sounds like there is either something in the line blocking the water, the water valve is bad or the micro-switch inside the maker is bad. First try this. Turn the ice maker on and off 3 or 4 times. If nothing, take the ice level lever and flip it back and forth a couple of times. (This will re-set some models) Watch the ice maker and see if it starts moving. If not, take the front cap off of the maker. If it has the big gear and little gear you can advance it like this. Take a small flat blade screw driver and put it in the middle of the little gear, Try turning it clock wise. It will not turn fast, just hold clock wise pressure on it. After it turns about 1/2 turn, the ice maker will start running by it's self. It should advance all the way and take water. If not, like i said, it's either a bad water valve, something blocking the line or a bad micro-switch inside the ice maker it's self.
Note. You said that it worked until you had the water off for something. If you had broken into the water line tom the house, there could have been trash get into the water lines. It does not take much to stop a water valve from working. It just may be something in the line. I hope this helps. Good luck!
Nov 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Indicators work intermitently
try the flasher can for your indicators, you should be able to locate this by turning on the indicators then stick your head under drivers side or passenger side dash. should be a small round metal tube case or a coulored box about as half as big as a matchbox. you should be able hear/feel a clicking sound everytime the indicators flash. good luck.
Jul 27, 2009 | 1995 Toyota Previa
Lcd srceen
This sounds like screen burn, or image persistence.
Jan 05, 2009 | Sharp Televison & Video
Vintage Caravelle runs fast
A quick look at ebay shows plenty of Bulova watches and only a few looking for a worthwhile price.
I think if you have it repaired for sale it probably won't be worth the effort or expense. If the watch has sentimental or nostalgia value to you I think that is what would make it worth getting a good watchmaker to look at it.
Sep 19, 2017 | Caravell Bulova Caravelle watch
My reprojection tv turned it self of but before it happen the colour change and a line came on the screen it a samsung 4 years old
Whats the model number of your samsung? I need that to help you, and also how did the color change before it shut off?
May 10, 2008 | Televison & Video
CASIO PAG-40 Keeps good time but buttons stopped working
open the backside.
probably the light switch contact at the six side of the watch (attached to the steel mainframe) may have contact with the electronic cirquit
Jan 13, 2008 | Casio PRG-40T-7 Pathfinder
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Electro Med Services...
