Question about Whirlpool Refrigerators
I got a whirlpool refrigerator and the ice maker is not working. I put a new water filter on it and reset it. There is no water getting to the ice maker,but its getting to the water valve. So I poured water into the ice tray and it froze, but would not cycle the cube out of the tray.Does the water valve and the ice maker comocate with each other.
  • alllawalin Sep 01, 2010
    This is a side by side, model#ED5SHAXML11, all lines are tight.The ice maker dont have an auger, it has an arm with white fingers to clean the ice out of the tray. It will dispense ice out the front door.
    My whirlpool is a side by side Model ED5SHAXML11 . The lines are all tight and the ice maker dont have an auger to remove the ice,it has a white rake that has fingers on it to remove the ice when its frozen. It does work when dispening ice and water out the door. we put bag ice in it to use.
  • Whirlpool Master
  • 1,711 Answers
The water valve get the istruction to open from the electronic control which receive signal from the sensor in the ice maker.
So the test must be perform to the three parts.
First Soneloid valve if the coild is ok if not must be replaced.
Ice maker sensor if it gives the signal to PCB if not this must be replaced.
and finally the electronic board PCB if resposse to the sensor signal if not must be replace.
The PCB is the most expesive part more tha $200.
Posted on Sep 08, 2010
  • Whirlpool Master
  • 8,220 Answers
Yeah. The water valve is activated by the ice maker. The ice mold thermostat gets all cozy and decides ice is in the mold. It brings the motor and heater to life. The heater stays on till the ice begins to move and you hear a click. Then the motor rotates on around and dumps the ice and real near the end of the cycle a probe sticking out of the head rubs a copper plate that is mounted behind the main drive wheel. The amount of water can be tweaked by moving a screw mounted on the 3 o'clock position of the ice maker head. This page give out better details and provides a simple video which shows how to see if the water valve is working. If you are careful you can remove that main gear and clean that copper plate. MANUAL AND MORE HERE
Posted on Sep 02, 2010
  • 2,272 Answers
Properly check the water hose at the back of the fridge if its not connected tightly then the water will run down the back of the fridge and not into the icemaker. Check the hose and if its loose then properly tight the hose and check. If the ice maker is making ice but not dispensing the the flapper door needs to be checked. The auger which pushes the ice out of tray to dispense has to be checked.If the auger is cracked then it will not work .The auger works with the help of motor.The auger and the motor needs to be checked.But if auger and the motor are functioning properly and motor is running properly then the water valve needs to be checked and replaced.The ice maker unit has to be removed and checked to confirm the fault.All ice-maker is controlled by main control board.If all checks out ok then the main control board needs to be checked. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 01, 2010
When I changed my filter in my Whirlpool refrigerator, my refrigerator stopped making ice and dispensing water. How do I get it to start back making ice and dispensing water.
If you still have the old filter replace the new with the previous. If all works OK check new filter for blockage or manufacturing defect. Usually most units will work with no filter installed.
It is likely that you have not fully assembled the new filter in the location.
The filter can be removed and there should be no leak and the ice maker and water dispenser should work just like before except the water is not filtered. This feature is available for customers who have whole house filters.
Hope this helps?
Nov 22, 2016 | Whirlpool Refrigerators
Whirlpool Gold side by sideGC3PHEXNS00 not making ice but the water works. Already replaced the filter.
put your finger in the ice mold and see if there is ICE in the mold. if no ice then use a turkey baster and put approx 1/4 cup of water into the ice mold, slowly. in about 2 hrs you should hear ice drop and then refill with water. if there is ice in the mold, you most likely need a new ice maker.
Jan 02, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker not working
Get me the model number. Put tap water in ice maker tray and make sure arm is down. Let it freeze. Wait and see if the ice will drop, this should allow water to come into the ice maker for another run. Let me know, Thanks, Sea Breeze
Apr 27, 2009 | Whirlpool GS6NBEXR Side by Side...
Freezer does not make ice
You need to check and see if ice maker has any water init. if not check the fill tube that goes thru the back wall for stoppage while you have it out rin the maker thru a harvest mode and listen for the sounds of the solonoid opening. If tube is full you'll need to replace the slow leaking valve a common problem. for parts call 704-819-6557
Mar 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE PROFILE PSS26msrd Ice maker not working water dispensor ok new water valve new filter fill tube seems clear Does anybody have any sugestions before i replace the ice maker unit?
water does become ice inside the pipe in side the freezer it happens to my frige at list once a year, put a hard wire or pencil up to make sure that is not the problem, before you spend any more money
Dec 06, 2008 | GE Profile PSW26P Stainless Steel Side by...
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
Whirlpool gold ice maker problem
  • The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
  • Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees.
  • In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering.
  • note: The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jul 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool ice maker stoped working
1. sometimes the water filter
2. the motor to pump the water to the ice maker
3.the ice maker out of order
Jun 18, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
