Question about Adcom GFA-7500 5-Channel Amplifier
GFA-7500 A751 FB 03670. THe problem is that one of the rear surround outputs is dead. I have a great 4 channel amp!! I am in MN. Ultimate Electronics will not be bothered with my problem. So "expects" please give options, hopely a few on the best way to repair this fine old AMP. I hope you will share your wisdom and advice ASAP!!!! Thanks in advance. Mike in MN. Mlaughlin54@;hotmail.com
3 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: Adcom GFA-7400 power amp; 1 dead channel (thermal protect LED on)
Hi...
I've contacted ADCOM before and they sent a pdf of the electricals
http://www.adcom.com/default.aspx
also try:
www.stereomanuals.com
Posted on Apr 17, 2010
  • 119 Answers
SOURCE: is a Adcom GFA-7500 5
no this AMP is not bridgable to get more power out of this amp you need 4 ohm speakers.
Power rating
1 - 150 watts into 8 ohm speakers
1 - 225 watts into 4 ohm speakers
Posted on Feb 23, 2011
Adcom gfa 7000 amp makes a cyclic humming noise in unit not in speaker
Are your grounds to BARE metal sounds like a ground loop issue.
Feb 25, 2013 | Adcom GFA-7500 5-Channel Amplifier
Adcom GFA 7500 problems
My right channel went out on my GFA 7500 and the problem was TWO blown internal fuses. Each amplifier inside the GFA 7500 has two fuses. In order to get to the fuses you must first take the top of the amplifier off by removing the screws using an allen wrench. Then put the top back on.Turn the amplifier over and remove most of the screws from the bottom to access the fuses in the bottom of the amplifier. There are two different size allen wrenches on the bottom. Be careful to not drop a screw inside the amp and make sure you line up the screw holes that hold the amps using a small screw driver to push the amps into position. I replaced all the fuses on the top and the bottom. AdCom sells the fuses on their site.
Jun 11, 2012 | Adcom GFA-7500 5-Channel Amplifier
I am looking for the fuses on an Adcom GFA 7807. The amp has no output on some of the channels.
Fuses aren't channel-specific; it's all on or all dead fuse-wise. Maybe you have dead / improperly connected speakers, source connection issues. Track it back or swap source channels and speakers to isolate.
Jul 24, 2011 | Audio Players & Recorders
Is a Adcom GFA-7500 5 channel power amplifier bridgable?
Power rating
Feb 23, 2011 | Adcom GFA-7500 5-Channel Amplifier
Hi...
also try:
Mar 30, 2010 | Adcom GFA-7400 5-Channel Amplifier
I have a vintage Kenwood amplifier (two channel rear speakers, 4 channel front / satellite) with Dolby Surround. It is circa '98 or so. I just moved it and now the right channel of the rear speakers seems...
I can't provide specifics without the model number, but ingeneral, the amp section for the rear speaker could be defective or the output relay could be the problem. Without knowing the deisng, I can not say for sure. Typically, the units of that vintage, use ICs for the surround amps. Some use a single IC for both channels, some uise 1 per channel. If you can update this with the model number, I can get you more specifics and perhaps a repair cost estimate.
Thanks,
Dan
Nov 24, 2009 | Kenwood Audio Players & Recorders
I turn on the ADCOM GFA-5802 amplifier... ...The power light comes on, but does not heat up nor output sound
Have it serviced. Do you know what GFA stands for. People at Adcom do have a great sense of humor. Take it only to a high end audio servicer. Contact Adcom. This is good stuff you wouldn't want a hack working on it.
Nov 23, 2009 | Adcom GFA-5802 2-Channel Amplifier
Adcom 7500, Adcom 5400(bi-amp), Marantz AV-9000, Dakiom HA103
Try just the power amp on ..nothing connected
no Dakiom thingy either. It's a matter of elimination. Start at the output device and work back. Keep the Dakiom out of the loop.
If there's hum with just the Adcom..then it's the ADCOM
Mar 25, 2009 | Adcom GFA-7500 5-Channel Amplifier
ADCOM GFA7500 problem
I don't have experience with the 7500 but I had a 7000 with multiple bad channels (red light lit). The problem was bad filter capacitors on the amplifier boards. The large black filter caps (two per channel) were leaking on every amp board. Its a relatively easy repair if you can solder.
FYI you'll probably need a set of small hex head drivers to open the unit.
Feb 21, 2009 | Adcom GFA-7500 5-Channel Amplifier
ADCOM GFA 5802 POWER AMP NO SOUND, BUT POWERS UP.
Remove the output transistors and measure each of the sets of 3 pads and report the voltage readings here. I suspect that you have either a blown driver circuit or output transistors. The voltage readings will give me an idea on where to start looking for specifics.
Thanks,
Dan
Nov 11, 2008 | Adcom GFA-5802 2-Channel Amplifier
Adcom GFA-7500 5-Channel Amplifier Logo
85 people viewed this question
Top Adcom Audio Players & Recorders Experts
 Grubhead
Grubhead
Computer Links
David Burbee
David Burbee
Are you an Adcom Audio Player and Recorder Expert? Answer questions, earn points and help others
