Question about Pentax Optio V10 Digital Camera
When I turn on my pentax v10, it will turn itself off automatically. the battery icon shows it's fully charged, it's about 3 years old. It worked perfectly before. I've taken the batt. out to "reboot" but it still turns itself off after powering up a few seconds. thanks
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 02, 2010
Camera only works when charger is plugged into it, the battery is showing 3.4 volts of charge, is the camera at fault and can it be fixed cheaply?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 24, 2012 | Pentax Optio Cameras
Battery has been charging to 100%. Suddenly would only charge to 76 percent. Now, after two weeks, will max at 62 percent. Computer is 1 year old. Can battery meter be recalibrated?
Pulled from Gateway's website:
Do not interrupt the battery recalibration process. If recalibration is interrupted, you must start the process over again.
  1. Close all open files and programs.
  2. Connect your notebook to AC power and allow the battery to completely charge.
  3. Disconnect the AC power and restart your notebook.Note: If the power cord plug.gif or battery baticon.gif icon does not appear on the taskbar, click the show hidden icons showhidden.gif button. If the icon still does not appear, verify thatAlways show icon on the taskbar is checked on the Power Options Properties Advanced tab.
  4. Completely discharge the battery by doing the following:
    1. From the desktop, right-click on the power icon, then select Adjust Power Properties.
    2. Click the Power Schemes tab.
    3. Click the arrow button to open the Power Schemes list, then click Always On.
    4. Click the Alarms tab.
    5. Click to remove the check mark from the Low battery alarm and Critical battery alarm checkboxes. Let the battery drain until your notebook automatically turns off.
  5. After the battery is completely drained, reconnect your notebook to AC power.
  6. Charge the battery completely until the yellow battery status indicator goes out.
  7. When you are ready to use your notebook again, do the following:
    5. Click to select the Low battery alarm and Critical battery alarm check boxes.
Mar 11, 2011 | Gateway Netbook N450
The indicator shows low battery after 2-3 shots. (batteries 3800 MAh are fully charged)
This seems to be a problem with the ist line. My istD does the same thing. Turning it on and off a few times helps with mine. Pentax has no solution.
Sep 24, 2010 | Pentax *ist DL Digital Camera
After charging battery ( and testing with multimeter 3.8v) when loaded into camera it shows low charge batteries are 3 yrs old any ideas thanks rob
your very luckily do be using rechargeable 's for 3 years after a year they start going down the drain, your battery tester may be showing that there is power in the batteries but its not enough for your cam,
my advice is to get new ones and you will see.
good luck.
Aug 01, 2010 | Pentax Optio M30 Digital Camera
The chair and its battery pack is 3 yrsold,not used,but when char
mcdevito75 here, If the battery--ies show charged they should be OK, still battery--ies that are 2--3 years old should be replaced. If your battery--ies show full charge, double check the connection for dirt, at the battery itself and at the motor.
Jun 22, 2010 | Everest & Jennings 20" Wheelchair With...
Camera doing its own thing.
Depending on the age and use of the batteries it could well be time to replace them. The best test would be to buy a new set of high power alkalkine batteries which you know to be fresh and try them. If everything works then invest in a new set of rechargeables. A respected brand with a high milliamp rating is best. It is possible one of your rechargables has lost the will to live and just died don't add just one battery. Change the complete set.
I've repaired a number of Pentax cameras where everything was OK except for the batteries.
Apr 07, 2010 | Pentax Optio V10 Digital Camera
Pentax Optio S10 cannot take photos in flash mode
HI there check the battery first. Red light blinking in working mode when the battery not having enough power for flashing. So i suggest you charged the battery fully or if its old then replaced it. Thnaks.
Apr 04, 2010 | Pentax Optio S10 Digital Camera
It won't turn on even with a fully charged battery. What do I do? I've owned it for at least 5 years and have three batteries and a pentax charger that turns green when a battery is charged. I put the...
yeah if you have had it for that long the batteries might be dead even if the appear to be charged i would get new batteries or get a new camera get one cheap on eBay ! have a good day :)
Apr 01, 2010 | Pentax Optio 430RS Digital Camera
Pentax w30 will not turn on. I think the battery may be shorted the light on the charger now blinks instead of staying lit while charging and turning off when fully charged?
The flashing light indicates either a charger problem or batteries that are beyond charging. If you have a voltmeter you can check the output of the charger and the voltage of the batteries, but chances are that you just need to replace the batteries -- especially if they're more than a year old.
Dec 12, 2009 | Pentax Optio W30 Digital Camera
E10 and s45 same problem
the batteries needed for the cameras are quite high powered
though the batteries show that they are fuly charged most times they have lost their actual capacity of power storage in them so not being able to supply enough to start the camera best way to test this is to start the camera on preview mode if this works then you will need to buy a new set of rechargable batteries, i would suggest to take batteries in the range of 2000MAh to 2500MAh and
the normal batteries will not be able to sustain long even for normal lens open and retract functions, instead of normal batteries try LR6 varieties (eg: Duracell, Energizer, etc)
Jul 25, 2009 | Pentax Optio S45 Digital Camera
Pentax Optio V10 Digital Camera Logo
101 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
