Question about Crosley Dryers
My Crosley Dryer, model # CDE7500AZW doesn't heat up. Possible soloutions?
  • Crosley Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 04, 2010
Where is heating element in crosley clothes dryer
What is the model number of the unit?
Nov 05, 2012 | Crosley Dryers
Crosley dryer model # cde22b6v. Timer switch works but dryer will not turn or heat. I checked connections. Belt is good. Motor turns free. What do you think I need to check?
door switch, bypass by taping the wires together. here are some other things to check:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Mar 30, 2011 | Crosley CDE6000 Electric Dryer
Crosley Clothers Dryer Model Number CDE/CDG22B8 will not heat up
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 16, 2010 | Crosley CDE6000 Electric Dryer
I have a Crosley CDE 7000 dryer that stopped heating
There can be a few reasons why an electric dryer does not heat...
Check out this tip that I wrote... it will help you find the thing that is causing your problem..
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 06, 2010 | Crosley Dryers
I have a Crosley Electric Dryer Model BYCD3722WI. You can hear the timer, but it will not get hot. What could be the problem?
the heating element inside your dryer could have malfunctioned, it may need to be replaced.
Dec 13, 2009 | Crosley Dryers
Crosley dryer fuses where r they
The thermal limit is located on the right hand side of the heater chamber. The dryer will not run if it is open. SOME REPAIR PHOTOS
Sep 06, 2009 | Crosley CDE6000 Electric Dryer
Crosley Dryer Model CEDX463RQ1 no heat
take elements to a dealer and have them checked, unless you have a digital multimeter and can DIY.Otherwise get a replacement element
Aug 01, 2009 | Dryers
Heating element in Crosley Clothes dryer
Before you replace the heating element, check the thermal fuse. All heaters have safety thermal fuse. This opens in case the thermostat fails. This is normally attached on or near the heating element, looks like diode. (When replacing, do not solder ! this will damage the fuse)
May 30, 2007 | Crosley CDE6000 Electric Dryer
Dryers Logo
78 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
