Question about Streamlight 74914 Replacement Bulb Only Strion
How do I replace the bulb on a GE 17000 lantern? Also, how do I open the lantern?
How to test a flashlight bulb
To test a flashlight bulb you use an Ohm meter which will detect a broken filament or an open circuit within the bulb. If the bulb is bad it will read "OL" if it's good it will read "00.0"
Jun 14, 2014 | Energizer Eveready Utility Lantern Uses 6V...
Rayovac 360 sportsman lantern wont work
Since batteries and bulbs are new/ok, check for a bad connection. In older version using 4 lantern batteries, open the battery compartment by unscrewing the knob on top of lantern. The lantern bottom comes off once unscrewed (of course you did this to change batteries). There is a "C" clip on the lantern center shaft; remove this by prying with screwdriver or with pliers. Carefully raise the battery contact plate and check slip-on wire connections. Clean as needed (Scotch-Brite works well) and reconnect. Squirt some contact cleaner in exposed switches, work switches back and forth. Inspect circuit board for obvious corrosion or damaged parts (this damage may "total" the lantern). Re-install plate aligning grooves with ribs. Install batteries and test.
Nov 01, 2012 | Camping, Backpacking & Hiking
How do I change the bulb on the 17300 Jasco lantern
Unscrew the bottom, there are two on each side of the battery housing. push both tabs in and slide it out which will give you acess to the bulb.
Jul 01, 2012 | GE Camping, Backpacking & Hiking
I want to know where i kent find this replacement bulb for GE steelbeam fluorecent latern ETU11W-SX
Hi did you find the bulb? I believe I have the same lantern (GE jasco 17300). I have been to every camping supply and home improvement store with no look. Also, I have been unable to find anything online. Please let me know! sumiraphatak@gmail.com
Jul 07, 2011 | Sport & Outdoor - Others
How do you relamp the GE model 17000 lantern
Visit the Coleman site to locate your particular lantern.
http://tinyurl.com/2a9j2xx
Jul 02, 2010 | Coleman Retro Rechargeable Battery Powered...
Doesn't GE make lanterns? I seem to own one.
GE do make emergency lantern. the one you own is a rechargeable lantern made for outdoor or indoor activities.
Jun 02, 2010 | GE SteelBEAM FluorescentLED Hybrid Lantern...
I have a GE Hurricane lantern model # 17000, how do I get it apart to put new batteries in it? There is an arrow on the bottom of it pointing to oppen one way and close the other, but nothing is budging.
I have the same latern. Apply a bit more force to rotate the bottom lid in a counter-clockwise direction. There are threads on the inside of the botton lid. To replace the battery or bulb you go through the botton of the lattern.
Jun 30, 2009 | Camping, Backpacking & Hiking
Streamlight 74914 Replacement Bulb Only Strion Logo
753 people viewed this question
Top Streamlight Camping, Backpacking & Hiking Experts
Stan Ford
Tom Chichester
Are you a Streamlight Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
