Question about Crosley 0187SST Turntable
Crosley cr249 Worked on setting up my new Crosley cr249 tonight and can't seem to decipher why most of what I record is distorted on playback.  All the levels look right going in while recording, and it sounds fine then...... but about 75% of what's recorded is distorted when I play it back.   Any ideas?
  • Monkey Mark Jun 19, 2008
    I've tried listing on another device with no results.  Wondering if I need to reinstall the software, or if the cartridge or needle is bad, or....... the turntable has been sitting on my desk for a month or more, and I haven't been able to use it.  Help?
    The recording head? In the computer? ? Everything else I use the computer for, including i-Tunes works fine...... the turntable plays LPs fine..... the problem is that after I record what sounds fine on the turntable, its distorted on playback on the computer, usually after the first 1 or 2 cuts on the LP recorded...... everything else is distorted. I don't think its the turntable or the needle, I don't think its the computer..... seems like the software? Still looking for help on this.
  • 1,512 Answers
Hi
Sounds alot like a buildup of dust under the stylus. This would make it distorted after running for a couple of tracks.
A couple of questions...
Are you giving your LP's a wipe with an antistatic cloth before playing them.
Are you monitoring the audio whilst you are recording.
regards
robotek
Posted on Jun 19, 2008
  • 1,879 Answers
What program/application do you use for recording ?
    Guru:
  • 1,342 Answers
This may explain things for you. It's a bit lengthy but worth the read.
  • Georgia B
    Georgia B Jun 19, 2008
    It's got to be something in the conversion process. You could try a different recording software program such as the FREE one listed in my previous post.
    Here's a link
    Make sure the needle on the turntable is straight and not twisted to one side or the other.
    Guru:
  • 1,894 Answers
Then the recording head is facing the problems sir.
amy be small loose connection in the circuit.
if u r expert in electronics u can fix it easily
    Sergeant:
  • 243 Answers
Are you using a standard microphone jack? like a 1/8" if so this is most likely the problem. also what program are you using. i recommend audacity.
  • 3 more comments
  • Nathan Ayers
    Nathan Ayers Jun 19, 2008
    make sure the needle is clean. its most likely something to do with the sound interface it self. I do 2 shows a week on turntables. and recently had to move to a new computer where i had to use 1/8"/3.5mm plug into the soundcard. I then upgraded to a audigy xifi with front drive bay for the rca inputs. is there a reciever inbetween the turntable and the computer?
  • Nathan Ayers
    can the turntable play at all? can you get it to work with a regular receiver and through speakers? cause if your hooking it straight in to the computer it may not have the preamp needed to receive the signal. As a computer has a line in. which is why you need a mixer or receiver with preamp ability. Usually listed as phono on your receiver.
  • Nathan Ayers
    cause the signal from a turntable is phono and has a very weak signal. which is why a preamp powers the line in a receiver to the speakers or a line out.
  • Nathan Ayers
    hows it going do you still need assistand. as i am here to help you.
    let me know how it goes.
    -Nate
  • Nathan Ayers
    Nathan Ayers Jun 20, 2008
    here i want you to try this free program called audacity. Also what kind of sound card is it can you redownload your sound card drivers for me and install them. Just to get that out of the way.
    click here to download audacity audio recording software.
I replaced my needle on my Crosley CR249. Now, there is a lot of static. Any idea what to check next!
The diamond tip on the needle is most probably been damaged. Check the tip for any significant visual issues with a magnifying glass.
Nov 11, 2016 | Crosley Audio Players & Recorders
Crosley CR249 warped table
Sounds like you need a new platter. Has the platter worked OK before or has it always been like this?
I suspect you might have to contact Crosley to see who supplies parts.
Jan 10, 2013 | Crosley CR249TA Turntable
CROSLEY CR249 KEEPSAKE AUX TURNTABLE STOPPED SPINNING
if it's belt driven, then your belt has fell off.
Jul 07, 2012 | Crosley 0187SST Turntable
Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Nov 09, 2011 | Crosley 0187SST Turntable
Sony pvw2800p-when done with the recording & then playback at different machine,there seem some picture distorted(at the top frame)like recording in a low head quality,but already changed a new...
distortions are present on the same machine?
Need to check the squareness of recorded frequency mod packages, using a test tape CR2-1B. Distortion at the top of the frame it misses the heads on track while entering. Adjust S-reel achieve squareness packages.
Feb 23, 2011 | Sony PVW-2800 VCR
Marantz CDR-510: Playback is good , recording is distorted
If this brand of media is new to you and the symptom is unique to it, I'd try a different brand.
Monitoring during record would never reveal media problems as there is no immediate playback after record as on old-school 3-head tape recorders.
I've had similar intermittent problems and I never could find a pattern to it except that it always seemed to be on low-end media. My best advice would be to try to find a pattern in your instance and make a change that avoids it. Then publish what you learned for us.
Good luck.
Mar 14, 2010 | Marantz CDR510 2-Disc CD Recorder
New crosley CR249-GR "wow and flutter"
I see your message isn't new anymore but Crosley does have a website with warranty and support info:
Crosley Radio
Jul 14, 2009 | Crosley CR248 Turntable
Crosley 0187SST Turntable Logo
553 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
