Question about Philips 42PFL5603D 42 in. LCD HDTV
I have a PHillips HDTV (32PFL6704D). When we watch shows, the picture is too big for the screen. For example we can't see football specs on top info line or all of program information on bottom, etc. I've gone to options and picture format and selected automatic, and when that didn't work, I tried unscaled, but we're still having the problem. I've also adjusted vertical and horizontal shift and can sometimes bring in top info, but then totally lose bottom band of ongoing scores for other games, & sometimes even at max shift, we're still missing stuff. I've gone a round-about way to be able to see entire scrren by going to TV mode (instead of HD mode). Once there, I have to adjust volume way up, but can then chose a picture format option (usually one of the movie expand options) and see the entire screen. However, once we turn off the TV and later go to turn it back on, we've got very loud volume and we get an error message on the screen telling us we need to go back to the HD mode. Do you have any idea what's happening and how to fix it?
  • renaesal Sep 02, 2010
    Thank-you SO MUCH for your answer! I didn't even know my Cox Cable remote had an HD zoom option, but it did, and somehow must have gotten pushed because as soon as I got that pushed back to normal, everything on screen fits and can be seen. Thank-you SO much for the assistance, was really going nuts trying to work around problem and figure out how to fix it! Our football season is going to be much more watchable/enjoyable thanks to you!
  • Philips Master
  • 736 Answers
Try going back to the hd mode and adjusting the picture size with the other remote control that came from the cable or satellite company. There should be an hd zoom (#) button, format button, or aspect button on the cable company's/satellite company's remote. If there is not an obvious button to do so there is a menu selection (picture format usually). Also if the set top box's resolution is wrong for the television you have you will also experience this problem.
Posted on Sep 01, 2010
Tv picture too big
You can probably change the picture in picture setting with your tv and that should help
Jan 01, 2012 | Samsung CLS55 Televison & Video
Green light flashing and no picture on our tv
2004-Model H 347 - 10839 Phillips big screen HDTV. The picture went 3-D.
Dec 25, 2009 | Akai PT46DL10 46" HDTV-Ready Television
The vertical screen cannot be adjusted. Watching football games the score cannot be seen at the top of the screen. changing vertical center and vertical size has no effect
You question shows its Sony KDL-46S2000 lcd tv so adjust screen format like zoom etc to adjust picture size best fits in screen.
Screen format option is available in Menu.
Dec 06, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Picture aspect ratio? Picture is too big for
Try VIEW MODE button on the remote or ZOOM button on the remote from cable box.
Oct 25, 2009 | Sharp AQUOS 52" Flat-Panel LCD HDTV
The ticker tape during football or nascar is not visible
If your watching a standard resolution(4:3) picture in wide screen format (16:9). than the picture will be stretched and the tops and bottoms cropped. look in your video or set up menu to change the resolution settings to standard 4:3
Sep 27, 2009 | Mitsubishi WD-65731 65" HDTV
Picture doesn't fit on my Samsung HDTV
after searching around on both remotes for me...im with verizon. Using my verizon remote under... settings-video settings-sd override...then into stretch mode fixes problem! Hope this helps anyone else with same problem!
Sep 21, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
Watching football and can't see the yards, downs, etc on top/bottom of screen
Maybe you should check your screen settings, (widescreen, full, cinema, etc.) if the picture is too big for your screen, you won't be able to see the top or bottom of the picture.
Sep 08, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Screen size is too big all of a sudden
im guessing it convergance amp ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
or
you can send them the board have it fixed
www.ptscorp.com
Dec 14, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Picture size too large
Did you try chaging the aspect ratio in the setup menus yet?
Feb 19, 2007 | Philips 46PP9302 46" Rear Projection...
Philips 42PFL5603D 42 in. LCD HDTV Logo
188 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
