Question about LG 37LC7D 37 in. LCD HDTV
I have no picture and the LED at the bottom just flashes away(red), what does this mean??
  • 11,361 Answers
It is in the safety shutdown mode, it may be detecting short circuits in the power supply ot in the backlight inverter board, you need to do in-depth troubleshooting to narrow down the problem, please read my guide and look at the pictures so you can decide if you will want ot DIY repair or not.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Sep 01, 2010
Samsung TV (model UN40H6203AF) 40" LED. No picture, have sound. Flashlight test can see faint menu screen. Have replaced power supply & main boards to this point. Ideas as to what to do next?
Hi Terry,
If you can see the faint picture in flash light means the power supply and the main board is working. The real culprit is the backlight. Even one bad LED in the backlight will switch off the whole array. To repair this fault the panel has to be opened and the defective LED or LEDs are to be replaced.
This is a complicated, delicate and risky job and must be attempted by an expert only. You may end up damaging the screen permanently if you have not done it before and try to DIY.
Oct 13, 2017 | Samsung Televison & Video
I have a Philips 42pf5321d/37 that won't turn on.
send me a email sonny@tvcircuitboards.com and I can assist you with troubleshooting it to determine whats happening with the set.
Aug 07, 2012 | Televison & Video
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
Sound, no picture, Red LED 4 flashes
Hello Thanshar, Hi, you TV has sound, but no picture. this could be several things, and let us add the red led flash. In my analysis, no picture means no high voltage is reaching the picture tube. this could be due to a bad Horizontal output transistor, and/or a bad flyback transformer. This bad transistor is causing an overload to the power supply section, causing the 4 led flash to blink. Now i want to know if you want to do this service or get professional help. if you decide to do this by yourself, this needs to be performed: the Horizontal output transistor must be checked for short, the horizontal flyback transformer needs to be tested, the deflection yoke also needs to be checked, especially to horizontal coil.
Oct 09, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
No Picture
4 flashed on that model mean a vertical deflection trouble.
Look for solder on it. IC 541 TDA 8172.
Apr 22, 2010 | Sony KV-27S66 27" TV
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
I have a Philips 42PF9630A/32 Plasma TV, red led blinks 7 times
No,body can cofirm u have to troubleshoot change the boards to know the problem.
Oct 22, 2009 | Philips 42PF7220A 42 in. Plasma Television
My philips 50p8341 beeps then flashes the red led 4 times
4 Blinks means that an incorrect voltage had been detected on the +5V circuit coming from PSU to digital control board.
The PSU must be tested and eventually repaired or replaced.
Aug 08, 2009 | Philips Televison & Video
LG 37LC7D 37 in. LCD HDTV Logo
77 people viewed this question
Computer Repairing
Computer Repairing
