Question about KitchenAid Ice Cream Makers
KitchenAid side by side refridgerator: Making ice, but won't dispense ice, water nor the light comes on. Is there a fuse for the front panel?
  • KitchenAid Master
  • 1,711 Answers
No the problem is from the main control assecmbly which is located on the top of the fridge.
The posibilities are first the solenoid and then board assembly.
Posted on Sep 01, 2010
Compressor hpco code comes up on panel of Taylor soft serve ice cream machine? Does that mean lack of water to machine?
There is a very good chance. Often the water has been shut off, or a wheel is pinching the hose.
HPCO stands for High Pressure Cut Out. The high side pressure is regulated by the water valve on water cooled equipment.
These are links to parts in the water cooling system.
046686 Water Regulating Valve 3 8
048287 Condenser for Taylor Water Cooled machines Taylor 035174 Scraper BladeReplacement 17
May 28, 2017 | Taylor Ice Cream Makers
What is process to winterize a Taylor ice cream machine?
To winterize a Taylor 794, or almost any water-cooled Taylor machine, we need to get all of the water out of it. Follow the steps outlined here.
1. Remove the supply water hose from the water source.
2. Remove the rear panel of the machine.
3. Locate the water valves. Pictured below.
4. Have one person open 1 water valve. (You can scissor two screw drivers to take pressure off of the spring.)
5. Blow out all of the water with an air compressor until only air comes out of the drain hose.
Repeat step 4 and 5 for the other side.
Sep 15, 2015 | Taylor 794-27 Soft Serve Twin Twist Water...
How do I get the beater out of my soft serve ice cream machine model #152 12
On the front of the machine on both sides the dispensing handle there are large thumb screws (I believe 2 on your unit). Empty the product from the machine then turn the thumb screws to the left to take them off. The screws hold the face plate on the front of your machine. You will then be able to remove the face plate from the front of the unit. The beater will be in the freezing cylinder behind the face plate. You will be able to just pull it out.
May 22, 2015 | Ice Cream Makers
Why is my taylor 8756 - 27 freezing the chocolate side and will not dspense?
This seems like it could be many things. Is the pump coming on when you try to dispense? Can you stick a thin wire up through the feed holes in the chocolate side when you try to dispense to help free the product?
May 04, 2014 | Taylor 754-33 Ice Cream Machine Soft Serve...
My Emerson IM90T is not making ice. It does not have the Add Water or Ice light on. It's not freezing. Help
This is the response from Victoria in the above response
Good afternoon,
In response to your email, this product does not belong to our company. Please contact the correct manufacture. Thank you.
Best Regards,
Customer Service Coordinator
Greenway Home
Nov 17, 2012 | Ice Cream Makers
I loaded the machine with mix and turned it on but machine keeps on turning but mix is still very watery
My small Business had this same problem. The first thing you need to look at is the product you are using. It turns out that if you are making your own soft serve. which Includes water and powder, it will save you a lot of time and stress to switch to cartons of soft serve that you just pour right in. It turns out that there is no consistency in powder icecream. the water will eventually separate from the mix, resulting in watery soft serve once dispensed from the machine. Next, if this isn't the prduct you are using then it can be other problems such as your compressor not working, or turning on when it's suppose to, maybe you have a weak motor, or your machine isn't set to the proper freeze level, Also, make sure that your machine isn't backed up against a wall or I between two other machines. These machines need to Obsorb cool air in order to work properly and not overheat . The machine's fan, which is located on the right side, needs to be have a certain amount Of space from walls or other machines. If this doesnt work you can always call a technition to come and check out the machine, I hope this helped, best wishes with your repair
Jul 16, 2011 | SaniServ 401 20 Quart Ice Cream Maker
No instuctions for my arctic twister which was given to me as is
This product wastes a lot of ice cream in its mechanisms. I would not reccomend its use to anyone who believes in "waste not..."
Here are the instructions for any wasteroos who would still use this product:
Série IC200 Series
Arctic Twister™
Ice Cream Mixer
? U.S.A./Canada 1-800-231-9786
Mexico 01-800-847-2309
www.blackanddecker.com
To Assemble the Ice Cream Mixer:
1. Insert the Twister firmly into the opening on the
Base (A).
2. Slide the Chute/Dispenser over the Twister along the runner
on the Base (B); it will click into place.
Note: Unit will not operate if Chute/Dispenser does not click
into place.
3. Hold the Lid with Ratchet Clip in one hand with the Handle
facing front. With one finger, push the Ratchet Clip on the Lid
forward. In other hand, hold the Plunger with smooth side
facing front, and from underside of Lid, insert Plunger into
Clip opening (C), pushing Plunger up until the Ratchet Clip
rests on top of the Plunger base.
4. Set aside the Lid with Plunger in place. Now you're ready to
start mixing up some fun and delicious ice cream treats!
To Use the Ice Cream Mixer:
Assemble all ingredients before you begin to make your first
batch of twisty treats: Set out an ice cream scoop, the mix-ins
you plan to use, ice cream cones, cups or dessert dishes,
then bring out the ice cream.
For best results, use hardened ice cream, frozen yogurt,
sorbet or sherbet directly from the freezer.
You may want to rinse off the Lid, Plunger, Chute/Dispenser
and Twister before beginning new ice cream flavors or
mix-ins.
Always wash Lid, Plunger, Chute/Dispenser and Twister
between batches, if you have been using ice cream or mix-ins
containing peanuts, to prevent accidental peanut
consumption by those who may be allergic to them.
1. Plug the Cord into a standard 120V wall outlet.
2. Position a flat-bottom cone, dessert dish or cup under the
spout of the Chute/Dispenser.
3. Place 1 scoop of store-bought ice cream into the
Chute/Dispenser. Sprinkle in 1-2 tablespoons of the mix-ins
(see "About Mix-Ins"); add another scoop of ice cream, and
continue layering as above, ending with ice cream, until
Chute is filled.
4. Fit the Lid with Ratchet Clip and Plunger in place (see
assembly instructions #3 above), onto Chute opening,
pressing down slightly and turning the Lid to the right to fit
into position, then to the left to lock it into place on the Chute.
5. Gently pump the Handle up and down a few times to "prime"
the Chute.
6. Press the On/Off Switch to "on" position, then slowly pump
the handle to move ingredients down the Chute. As you
pump the handle, the ingredients will automatically be moved
into the Twister, then out the spout of the Dispenser.
7. When the Chute is empty, turn On/Off Switch to "off" position.
Push the Ratchet Clip forward and pull up the Plunger, then
use the Handle to move the Lid to the right. Lift the lid with
the Plunger in place out of the Chute.
8. Repeat steps 2-6 to make as many batches as desired.
Jul 06, 2009 | Black & Decker IC200 Arctic Twister 2.11...
My newair A1200ss stopped making ice. i tried recycling the unit and it has ample water, but the ice tray just stays in the down position. thanks.
I have had the same problem with two different portable ice makers, the ice tray inside is broken so you will have to send it to them and get it fixed. Hopefully eventually they will make the tray out of a stronger plastic.
Nov 29, 2008 | NewAir AI-200SS Ice Cream Maker
Polar Ice Maker Portable
there is a little sensor inside on the top right, it is a little wire if there is anything on it it will not work, i took at small pair of pliers and gently cleaned it
Jun 21, 2008 | Polar PIM15W Ice Cream Maker
Ice Cream Makers Logo
46 people viewed this question
Top KitchenAid Ice Cream Makers Experts
Ruth summersides
Andrew Taylor
Andrew Taylor
Are you a KitchenAid Ice Cream Maker Expert? Answer questions, earn points and help others
