Question about Microsoft Office Outlook 2003 for PC
Iexlporer probleme When trying to install Internet Connection Sharing, I get the following error message: ?Netconn has caused an error in Netconn.exe?in
    Problem Solver:
  • 35 Answers
Try finding Netconn.exe in your C:\Windows directory and double-clicking it. If the error still occurs, delete Netconn.exe, and then click Start, click Run, type MSCONFIG (hit enter), click the Extract File button, type in NETCONN.EXE as the file you would like to extract, click the button labeled ‘Start’, type the path to your WinME installation files where it says ‘Restore From’ (example: D:\Win9x), and type in ‘C: \Windows’ where it says ‘Save File In’ and click OK.
Naturally, back up registry, move copy of deleted keys to desktop before removing.
Delete HKEY_LOCAL_MACHINE,System, CurrentControlSet, Services,
ICSharing (the whole thing).
In addition to removing the whole ICS Sharing folder,
HKLM\System\CurrentControlSet\Services\ICSharing (entire folder),
Remove HKLM\System\CCS\Services\RemoteAccess\LocalNameResolution (all keys)
Extract ics.inf, icshare.inf and icsharep.inf to a temp folder (like C:\ICS)
Posted on May 10, 2008
Problem with internet connection
These sort of problems are usually caused by malware (Virus or Spyware) I would suggest that you try to setup your router again using the Router installation disc.
May 07, 2013 | Dell Inspiron 1501 Notebook
When i my pc on it show me generic host problem after this msg windows stop network services?anyone tel me
You may occasionally get an error message that reads "This connection has limited or no connectivity. You might not be able to access the Internet or some network resources." It indicates that your PC is having a problem trying to access your network device to connect to the Internet. Very often, a bug that typically affects Windows XP Service Pack 2 causes this error message. This bug causes a loss of your network connectivity in workstations that use Microsoft's L2TP-based VPN (virtual private networking) client to connect to the NAT-based networks. You can fix the "Limited or No Connectivity" problem in a few steps. (If your connection works but you still get the error message, go to Section 2 to learn how to disable it.)
Review the following symptoms and determine if you experience any of them after you install the Windows XP Service Pack 2:
You get the error message "Limited or No Connectivity" when you attempt to connect to your network.
You have a problem connecting to your local area network or to the Internet.
You keep on receiving an error message: "Acquiring IP Address" message. If you experience these symptoms after installing Windows XP Service Pack 2, then this bug is causing the problem. In this case, go to Step 2; otherwise, skip to Section 3 Download the Microsoft patch (KB884020) from the Microsoft website. Run this update to install it. Create a registry fix by launching Notepad and typing: [HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Services\\IPSec] "AssumeUDPEncapsulationContextOnSendRule\"=dword:00000002 Save the file as FixReg.reg to your desktop. Double-click the saved file to install it into your registry. Restart your computer and the error message will likely be gone. If you still see the error message, follow the steps in Section 2. b> If Your Connection Works But You Still Get the Error Message b> Navigate to the "Start" button and select the "Control Panel." Double-click on the "Network Connections" icon. Right-click the "Local Area Connection" icon and select "Properties" from the popup menu. Click on the "General" tab. Uncheck the option that is labeled "Notify me when this connection has limited or no connectivity." Click "OK." b> If the Patch Doesn't Fix the " Limited or No Connectivity" Problem b> Check your DSL router for any malfunctions. Re-configure or power cycle your router. Check your computer's network card configurations and network cabling to ensure that the problem does not lie here. Check your firewall to determine whether it is blocking you from connecting to the network or to the Internet. Disable the firewall and attempt connecting to the network or Internet while with the firewall is disabled. If the firewall is causing connection problems, then reset or uninstall and re-install the firewall. Reduce your connection speed to 10 Mbps and test this to determine if it fixes the problem. To do so, navigate to the "Start" menu and select the "Control Panel," "System" and "Device Manager." Review the properties of your network card. Click the "Advanced tab." Locate the "Link Speed and Duplex" section. Change the settings from "Auto Detect" to "10Mbps/Full Duplex." Hope this helps.
Dec 24, 2012 | Computers & Internet
Email problems: error code 0x800CCC0F,
When you use Microsoft Outlook Express to send and receive mail to a Post Office Protocol 3 (POP3) or Internet Message Access Protocol (IMAP) server running Exchange 2000 Server or Exchange Server 2003, you may receive the following error message. Your server has unexpectedly terminated the connection. Possible causes for this include server problems, network problems, or a long period of inactivity.
Sep 29, 2011 | Microsoft Internet Explorer 7
I have a toshiba satalit x205-sli1. OS is Windows Vista. I am unable to access the internet although the Network and Sharing center show that I am connected I continue to get the message that page Internet...
okay, follow the below steps:
  1. click start menu and go to control panel
  2. Click internet option from your control panel
  3. A dialogue box will pop out, the click connections
  4. Click LAN settings and click "Automatically detect settings" and press OK and try again.
If the problem is not still solved, go back to control panel and click "Networking and sharing center", look by left of the page and click "Manager network connections", right click on your network connection and click properties. Wait for a dialogue box to pop out, click networking, remove "internet connection version 6 (TCIP/IPv6) and select "internet connection version 4 (TCIP/IPv4), press OK and try again.
If it still does not work, go back to the "internet connection version 4 (TCIP/IPv4) double click on it, a dialogue box will pop out, then select "Obtain an IP address automatically", look down and also select "Obtain DNS server address automatically", press Okay and try again.
If your computer still does not browse, then you will have no option than to reinstall windows vista operating system on your computer, by so doing the problem will be resolved, i am very sure of that. Do fresh vista installation and problem will be resolved.
There is a conflict on your network settings, that's why its not connecting.
Good luck.
Jun 08, 2010 | Computers & Internet
Which firewall service is in use ?
The ICS service can be enabled along with teh Port 9000.
start the Windows Firewall/Internet Connection Sharing (ICS) service at the command prompt by using the net start sharedaccess command, you see the following output:
C:\>net start sharedaccess
The Windows Firewall/Internet Connection Sharing (ICS) service is starting.
The Windows Firewall/Internet Connection Sharing (ICS) service could not be started.
A system error has occurred.
System error 16405 has occurred.
Hope this will help you....
Cheers!!!
Vivek
The system cannot find message text for message number 0x4015 in the message file for BASE.
Dec 15, 2009 | Logitech QuickCam Pro 9000 Web Cam
Internet connectivity
TCP/IP network transport not installed
Symptoms: After you run Microsoft Windows AntiSpyware (Beta) or other anti-virus/spyware/adware software, 1) you may receive one or more of the following interactive error messages:
Could not start the Windows Firewall/Internet Connection Sharing (ICS) service on Local Computer. Error 10047: An address incompatible with the requested protocol was used.
or
Windows Firewall settings cannot be displayed because the associated service is not running. Do you want to start the Windows Firewall/Internet Connection Sharing (ICS) service?
or
This application has failed to start because SPORDER.dll was not found.
2) Third-party networking products may not function correctly.
3) Computers may not be able to connect to the network because they cannot obtain an IP address.
4) You may receive the following error message when you are using Microsoft Internet Explorer:
Error 404: Page cannot be displayed.
Cause:
There are known spyware programs that install layered service providers (LSPs) on client computers to gather user data. When Windows AntiSpyware (Beta) removes spyware programs, it also removes the spyware-based LSPs. However, Windows AntiSpyware (Beta) does not restore any LSPs after it removes the spyware.
Resolutions:
How to rebuild the Winsock LSP chain on Windows XP SP2
How to rebuild the Winsock LSP chain on Windows XP, XP SP1, and Windows 2000 __________________
Bob Lin, MS-MVP, MCSE & CNE
How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com
Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net
Oct 17, 2008 | HP PAVILION A6230N DESKTOP PC
Iexloprer prob
Start/Settings/Control Panel/Add-Remove Programs/Windows Setup – remove ICS. Do not reboot.
Click Start, click Run, type Regedit (hit enter)
HKEY_LOCAL_MACHINE,System,CurrentControlSet,Services --
Remove ICSharing key
Under Class, noted number of folders under NETTRANS key.
Don’t close, just go to next step.
Under Network properties:
Add protocol called NETBEUI
Remove all instances of TCP/IP
Click OK DO NOT reboot.
Back to Regedit, press F5 to refresh the screen. Remove all folders under NETTRANS key that WERE there before. Do not remove the new keys. They might be at the end, or in the middle. Don’t remove the new NETBEUI folders.
Back in Network properties, add the TCP/IP protocol. Be sure that File and Printer Sharing is not present (this is a must), and delete the NETBEUI protocols.
Start/Settings/Control Panel/Add-Remove Programs/Windows Setup – Communications – select ICS. Click OK, Click OK.
ICS should run perfectly. Then open network properties and add File and Printer sharing.
May 10, 2008 | Microsoft Office Outlook 2003 for PC
Nintendo usb connector
hi coolsoph,
Firstly, take note that Windows Vista doesn't support the Nintendo USB connector (currently there is now way of making it work on Vista, hopefully this will be resolved with the release of Vista Service Pack 1).
Secondly, and this is if you are using Windows XP as your computer operating system, try these steps to enable XP to share it's Internet connection with other computer (for ex your Wii):
1. Click Start -> Control Panel
2. In Control Panel open the Network Connections applet
3. Right-click on your active connection (will be named something like "Local Area Connection" if you use a cable to connect to your router or "Wireless Network Connection" if you use a wireless technology to connect to your router).
4. Click on Properties
5. Select the Advanced tab
6. Check the box named "Allow other network users to connect through this computer's Internet connection" in the Internet Connection Sharing area.
7. For good measure you can restart your PC after checking the box
I hope this is helpful information and thanks for using the FixYa services
Regards
Feb 12, 2008 | Computers & Internet
Error
This problem is caused by the new security features that are added by SP2and above(for winXP). To prevent the error message and enable Fax Sharing, either update WinFax to version 10.04, or manually reconfigure the Windows XP security settings to permit Fax Sharing to work.
Oct 08, 2007 | Symantec WinFax Pro for PC
Microsoft Office Outlook 2003 for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
