Question about Sony KP-51HW40 51" Rear Projection Television
Ics replacement how to's and parts?
  • Ramblon May 16, 2008
    Does this seem like an ics problem?
  • Sony Master
  • 8,617 Answers
I just posted a response for you you need two STK392-560 ICs they are available at the following link and they provide free instalation instructions with pictures so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 10, 2008
I ve a nokia n72 phone the IC of which is damaged. As a result I am not getting a proper display. what is the cost of getting IC replaced?
Hello SD,
If you have diagnosed that IC is damaged. Then please visit any Nokia service center near by you.They will check it properly and replace the IC with original IC spare part. You will get the IC replacing quote from Nokia service center itself only.
May 10, 2011 | Nokia N70 Cellular Phone
I changed my two IC chips and three resistances on my Hitachi TV to fix color alignments. Now the problems is that yellow and blue double image are seen at the bottom of my screen with no much effect on...
Ur tv still have dead resistors parts,test all 12 resistors parts around the 2 STK convergence ICS and changes some more dead resistors parts or changes all 12 resistors parts for sure.If tv still have the same problems after tested and replaces more resistors parts or all 12 resistors parts.Than some how when u handling and replacing the 2 STK convergence ICS and resoldering the 2 STK covergence ICS u short it out the 2 STK convergence ICS by resoldering without proper grounding ur self not to allow for static electricity to kill the 2 STK convergence ICS or u using a soldering iron to high of a wattage for doing soldering ICS work.
Apr 23, 2011 | Hitachi 43FDX01B TV
I have a panasonic PT-47wxc43 projection tv. I have green and purple halos coming up from the bottom. The screen has purple and green double images which are worse from the bottom up.
This problem is due to convergence output ICs failure and both chips will be replaced to fix the issue.
There are two big black ICs installed with aluminum heat sink on deflection board, these are convergence output ICs and will be replaced to correct the problem, it is common problem of rear projection tv.
Below image of deflection shows ICs (marked in red) that are need to be replaced.
IC number is STK392-110 and available with Part Store for $32 each.
Click above link to see an image of IC.
If you are handy with electronics stuff repair and can replace parts in tv circuit board then can replace these parts yourself or ask local tech to help you.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
May 25, 2010 | Panasonic PT-47WXC43 47" Rear Projection...
Convergance problem on lower half of screen.smeared red and orange double vision,but only on bottom ofscreen.top appears out of focus,but not double visioned.
Howdy,
The TV has a convergence problem; the IC’s for that circuit will need to be replaced. The part(below) Number is from Toshiba, they provide good advice on replacement parts. Make sure what type of IC's your TV uses first. The cost for this repair runs around $450.00 or more.
Replace the defective Convergence Output IC Part Number
23905094 (STK392-110) using the revised “T” version IC Part Number
23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
version. Inspect the Convergence Output IC’s for the “T” type version as
shown in Figure 2. Replace the Convergence Output IC’s using the “T”
type version Part Number 23135090 (STK392-110T).
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for choosing FixYA, Big Irish.
Nov 23, 2009 | Televison & Video
WANT 2 KNOW 43FDX20B HITACHI TV IC NUMBER NAD PART NO
You can find OEM IC's for this model (43FDX20B) from a major Hitachi parts distributor on the link below:
Hitachi 43FDX20B Replacement Part IC
If you contact them and provide the generic number or location number of the IC, they should be able to provided you with the needed parts.
Apr 02, 2009 | Hitachi 43FDX20B 43" Rear Projection...
Color outlines on screen almost appears as 3D
Yes, you need to replace two ICs, STK392-560 on D board of TV
Above ICs are available in Part Store.
Mar 27, 2009 | Sony KP-51WS500 51" Rear Projection...
Convergence IC replacement
No as long as the STK number is the same they will work. Just be careful where you get the parts as alot of places online sell cheap chinnesse made ICs and they wont last. I usually get mine at the following link, and I havent had any trouble with their ICs.
Jul 14, 2008 | Zenith R57W46 57" Rear Projection...
WS-55819 Mitsubishi Rear projection TV Picture goes blurry
Convergence ICs are bad need to be replaced. You will need to replace both of them also check the resistors right next to the IC often 1 or 2 of them burn out when the IC goes.
Feb 26, 2008 | Mitsubishi WS-55819 55" Rear Projection...
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Part number for IC module Hitachi 50EX12BA?
The Hitache 50EX12BA uses 2 IC's labeled STK392-110. If you are looking in the back of the set, the convergence IC's are mounted on the large heat sink on the right side. If one of the IC's has burned out, go ahead and replace both IC's with the newer improved STK392-150 IC's. These IC's are very common and can be ordered from almost any electronics parts supplier. When installing the new IC's you will need to clean off the old heat sink compound and apply fresh compound to the back of both IC's.
Aug 18, 2007 | Hitachi 50EX01B 50" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
