Question about GE Zoneline AZ25E12D3B Air Conditioner
Water is leaking out the front, even though the unit is slanted towards the back
    Genius:
  • 1,970 Answers
Mcdevito75 Here You"ll have to make sure the rear drain hole/s are not clogged.
Posted on Sep 01, 2010
Water leaking out the front right edge of the case.
the window unit should be 'slanted' (just slightly) to the rear so that the condensation water can drain out the back of the unit.
Check and make sure the drain hole is open and not clogged too.
Aug 09, 2011 | Samsung AS1293L Air Conditioner
Hi. one of the 4 legs to my meile coffee water tank broke off. now the "fill watertank" comes on even though the tank has water. is it the broken pin ( or leg) or is it a computer issue and...
it is probably now that it is slanted registering empty even though there is water in it. Try making it level with a book or something and see if that helps
Dec 29, 2010 | Vacuums
Water is leaking out the front of the unit
Water is a normal byproduct of the refrigeration process, Just like a glass of icewater has condensation on the outside of the glass.
The unit is designed to run the water outside. Check the slant of the unit, if it slants inside water will not exit outside..needs slight downward tip towards the outside.
Also check that the drain system is not plugged.
Nov 21, 2010 | GE AJHS08ASB Thru-Wall/Window Air...
There is a leak of water in front of the Air Conditioning unit
Clean floor of unit under coils so front coil water can drain under the coils to the back drain.
Don't forget to tilt them unit a bit to the back to allow the water to drain towards the back.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 23, 2010 | Frigidaire FAC084N7A Air Conditioner
My window air conditioner keeps spitting water out the front
check for clogged drain in back of the unit and make sure the unit is level or slightly slanted toward outside.
May also be caused by debris clogged in evaporator coil.
Jun 27, 2010 | Heating & Cooling
Freezer leaking
open the freezer panel in back. unclog drain hole where water collects. defrost unit first. put a towel in front of unit for some water
Feb 25, 2010 | Refrigerators
Unit is leaking water
What is causing this is when you have something cold, the moisture in the air condenses to becomes water. Kinda like when you sweat in the sun. They call this condensation. The unit should be collecting this and draining the water through a hose, or out the back. If there is a hose inside the unit, check that the hose is able to completely flow downwards at least 1/4" per foot. Otherwise, if the unit is a box in a hole or window, slant the unit so the water flows towards the rear.
Aug 18, 2009 | LG Heating & Cooling
LG 18000 ac leaks water in the front of unit indoors.
the drain pan is either clogged or the unit is not mounted properly. If the drain pan is clogged simply clean it and the problem goes away. In the case of the unit mounting, check the angle of the unit and the drain pan inside, if it tilted to the front even just a little then water would leak. the drain pan should lean toward the drain and away from the front.
I hope this helps.
Jun 05, 2009 | LG LS-K1830CL Cool Mini Split Air...
Mothers AC unit
That has nothing to do with the water. Sounds to me like it needs cleanning, (the water is not drainning toward the back of the unit) ,,(dirty filter, which its trying to **** air anywhere it can even thru the drain hole, or not enough slope, leanning toward the back so gravity can flow the water to the back of the coil! Thank you-very-much!
Aug 28, 2008 | GE Zoneline AZ38H12DAD Split System Air...
GE Zoneline AZ25E12D3B Air Conditioner Logo
124 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
