Question about Bosch Nexxt WTMC 6300 Electric Dryer
Brand new Dryer with loud noise and hot
The dryer is brand new and within 3 minutes of it running it makes a rumbling sound that doesn't sound normal at all. The inside seems really hot too but that may just be me. The longer it runs the louder it gets and after 40 minutes it sounded like it was going to blow up and had a funny smell so I shut it off and unplugged it. The exact model is Bosch WTMC6321US Nexxt 700. Thanks
    Genius:
  • 1,073 Answers
Contact bosch for factory service on the unit
Posted on May 11, 2008
Dryer occasionally makes a loud vibrating sound
Under warranty - contact retailer or manufacturer - check user manual or receipt for procedure.
May 30, 2016 | Blomberg DV17540 NBL00 Vented Dryer with...
Dryer gets loud as it heats up
You have not mentioned the brand or year or model number, but most dryers have one of 2 systems.
One older system has a bearing back there, inside the machine, but outside the drum.
That bearing can fail, causing this.
I have had several of these, and am using one now.
The dryer must be completely disassembled and the bearing replaced.
The second type uses pulleys in the back and plastic bearings (nothing more that flat pieces of plastic) in the front.
The wheels or plastic plates can wear out, also causing these symptoms.
In either case, now is the time to fix it.
God bless your efforts.
Nov 02, 2017 | Dryers
My dryer is making a very loud squeaking sound when I turn it on. Also inside is very hot within minutes.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Dec 27, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
My Maytag Bravos dryer is brand new. It is the quiet series 300, but is the loudest dryer I have ever owned. It makes like a loud vibrating, humming noise. Is this normal? I am now drying my second load of...
People, the first words the poster said were that the dryer was "brand new". All of your suggestions assume the dryer had extensive use. This sounds like a factory defect issue!!!! My brand new Maytag Cabrio gas dryer is also making an obnoxious buzzing sound that seems to cycle on and off as the gas ignites. The buzzing sounds electronic not mechanical. What would buzz when the burner is active?
Oct 31, 2010 | Maytag Dryers
Ge dptg750ec make loud rumbling noise after replacing blower
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 09, 2009 | GE Profile Harmony DPGT750EC Electric...
Loud rumble sound, Vent hose vibration
That model of neptune dryer had a problem with the blower housings cracking. When the housing cracks, it binds forward into the blower wheel making a loud "rumble" noise and vibration. If you open the door and manually turn the drum and you hear a rubbing noise and feel alot of resistance, then you have a cracked blower housing and need to replace it. It is not an easy job to replace, so if your not familiar with dryers, you should have a technician replace it. Let me know if you have any further questions. shane
Oct 01, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Loud rumbling noise with slight vibration
Normally the noise you hear is caused by the drum rollers having flat spots on them or needing lubricant.
If this is what is wrong It will make a kind of thumping noise.
When they need lubricant they will normally make a squealing noise also. You would lube the shaft and bearing area of the roller, using a good machine oil...something like "3 in One" oil.
Sep 26, 2009 | GE DBXR463ED Electric Dryer
KENMORE DRYER
Hello ENRIGHT11 Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD (ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal of noise coming from the blower area of the dryer when it is running, then the blower wheel could be defective.
The are many different designs for blower wheels and just as many unique failure modes. Vanes (fins) can break off the wheel and bounce around in the blower breaking more pieces. The blower can break around the coupler with the shaft. This can cause the blower to spin loosely on the shaft. The blower can form cracks which cause it to vibrate, etc.
You should also not be surprised to find foreign debris in the blower. The occasional bird, rodent or squirrel has been known to bypass the out vent cover. If they crawl into the exhaust tube the first thing they come into contact with is the blower wheel.
If the blower wheel is not spinning, or if it is missing vanes, it is not moving air efficiently. As a result, heat is not removed from the heat source and it can trip the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch and/or become brittle with age. The belt can then slip on the drum or motor to cause squeaking. If this is the case, the solution is to replace the worn belt.
The belt is not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, worn drum glides or worn drum rollers depending on brand and style.
When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are economical easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some dryer models are equipped with Drum Glides. The front of the dryer rests on these glides. They provide a low friction surface on which the drum spins. After time however, this glides wear down. Much like an automobile brakes, these glides make a load grinding noise when they wear thin. This griding against the drum usually leaves a bare metal stripe that is visible at the point of contact. If the glides are worn, the solution is to replace them.
The drum glides not the only items that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, a worn belt or worn drum rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some dryer models are equiped with a Rear Drum Bearing. The rear of the drum rests on this bearing. It provides a low friction surface on which the drum spins. After time however, this bearing will wear down. If the bearing is worn, the solution is to replace it.
The rear drum bearing not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum glides, a worn belt or worn drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change the drum glides, drum support rollers, drum belt, idler pulley and clips depending on make and model. All of these items are economical and easily changeable when replacing the rear drum bearing. The upside is that your dryer will operate like new.
Worn Drum Support Rollers
Some dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum Support Rollers. The weight of the dryer drum rests on these rollers. They provide a low friction surface on which the drum spins when in operation. After time however, these rollers wear down. When they wear, often times they begin to elongate and form a non-round 'cam' shape. The result is that when the dryer is turned on it creates a rumble that sounds as though you are trying to dry a pair of tennis shoes. This sound is usually the drum being forced up and down on the non-round wheels. If the rollers are worn, the solution is to replace them.
When replacing the Drum Rollers it is a good idea to also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new. Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a
solved rating before you leave!
Jan 21, 2009 | Kenmore 63942 Dryer
Noise from dryer
drum has worn drum bearing dryer top AND rear panel must be removed to acess the rear of drum to replace drum
Sep 24, 2007 | Zanussi TC7102W Electric Dryer
Bosch Nexxt WTMC 6300 Electric Dryer Logo
292 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
